3rd gen torque converter shudder
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MarlonB54, Feb 11, 2021.
  1. Feb 15, 2021 at 12:13 PM
    #141
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    i agree. and i have repeated this experiment many times. it goes away with higher octane gas and comes back when i refuel with 87. also does it a bit even with 89.
  2. Feb 15, 2021 at 12:14 PM
    #142
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    See if you can get some custom tunes with increased throttle limits and adjusted tc locking for your ECU.
    If it does not help, I would go to Toyota and start a warranty process.
    MarlonB54[QUOTED][OP] likes this.
  3. Feb 15, 2021 at 12:14 PM
    #143
    MarlonB54
    MarlonB54 [OP] Well-Known Member
    Fishaholic
    22’ Barcelona Red TRD Off Road
    Will try this out... currently waiting at another dealership for a road test with service manager
    cryptolyme[QUOTED] likes this.
  4. Feb 15, 2021 at 12:15 PM
    #144
    cryptolyme
    Virginia
    doubt this is a warranty issue
  5. Feb 15, 2021 at 12:18 PM
    #145
    MSGulfCoastTaco
    MSGulfCoastTaco Well-Known Member
    Mississippi Gulf Coast
    2020 MGM DBSB OFF-ROAD 4x4
    I also kept an eye on the RPM gauge when moving through the rpm's for 45-50mph. Nothing looked out of the ordinary. Rpm's did not 'Rev up'.
    MarlonB54[OP] likes this.
  6. Feb 15, 2021 at 12:23 PM
    #146
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    If you have an ultra gauge or something and are used to keeping an eye on it, it becomes obvious when the TC locks. It will only lock in 4th gear and above at a certain speed and RPM. 40-50 mph sounds about right.
    If it shudders when locked, it’s probably because the engine is running rough and you now feel it because the engine and the rest of the drivetrain are now mechanically locked together. The misfire is probably present at other times but there is a fluid hydraulic connection between the engine and tranny that softens things up.
    Just my thoughts.
  7. Feb 15, 2021 at 12:24 PM
    #147
    MarlonB54
    Fishaholic
    So what about shudder at higher speeds as well???
  8. Feb 15, 2021 at 12:29 PM
    #148
    Sharpish
    Brian
    Probably locked and the engine is misfiring. Put in some 91 octane, disconnect the battery and reconnect. Then take her for a good long highway rip.
  9. Feb 15, 2021 at 12:33 PM
    #149
    MarlonB54
    Fishaholic
    Dont misfires make the check engine light go on?
  10. Feb 15, 2021 at 12:37 PM
    #150
    Vlady
    Issy, WA
    Have them hook up techstream and reset Tranny learning values or do it yourself via vF or Techstream.
    See if you get the issue disappeared for now. It will drive weird for 200 miles though.
  11. Feb 15, 2021 at 12:38 PM
    #151
    MarlonB54
    Fishaholic
    Has been done twice now. Once at dealership at 4,200 mi and again on saturday after ovtune was installed. Have driven more than 200 mi since then. No changes
  12. Feb 15, 2021 at 12:39 PM
    #152
    Sharpish
    Brian
    Best of luck to you. It would suck if you pressed the issue and the dealership tore your truck apart and replaced the tranny if the solution was 10 cents per gallon more expensive gas.
  13. Feb 15, 2021 at 12:40 PM
    #153
    MarlonB54
    Fishaholic
    Ok... so i guess that is a no to my question
  14. Feb 15, 2021 at 12:59 PM
    #154
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    No. Not necessarily anyways.
  15. Feb 15, 2021 at 1:15 PM
    #155
    MarlonB54
    Fishaholic
    Truck shudders well around 2000 RPMs as well
  16. Feb 15, 2021 at 1:16 PM
    #156
    MarlonB54
    Fishaholic
    Thank you
    Lt. Dangle[QUOTED] likes this.
  17. Feb 15, 2021 at 1:16 PM
    #157
    Lt. Dangle
    Ohio
    Maybe, but my truck has 60k on it and still has quirks. It's fully mine and I've had it for over 4 years now so remorse has never been the issue and it certainly isn't now. I'm at the "dread the idea of having a car payment" stage of ownership.
    Honestly, I've never met anyone in person that had anything bad to say either. But I do tell people if they ask me if I have had any issues that I've had to have all 4 door sills repainted due to rust, A leaky rear end, a howling rear end, a low octane miss and knock, multiple Tranny and an ECU TSB's, and some other stuff (frame recall has yet to be done). It happens some times.
    It's still better than my FJ was though, and a far cry from the quality that my wifes wrecked rav4 is.
  18. Feb 15, 2021 at 1:20 PM
    #158
    Lt. Dangle
    Ohio
    Honestly, I'd just flash the 93 tune and spend a few "extra" bucks and see what happens. If it goes away, great. If not, you can eliminate it and move on to the next suspect.
    I'd suspect you have some other issue since you are tuned and still have the issue. I believe you can log your engine data and send it to Mat and he can check it or tweak your tune to your truck.
  19. Feb 15, 2021 at 1:43 PM
    #159
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    While were on door sills, maybe you know the answer. My black coating on the door sills all peeled and cracked apart on my 2001 tundra exposing the chrome underneath. Am i expected to have the same issue with the new tacoma? I didn't ask the dealer.
  20. Feb 16, 2021 at 1:41 PM
    #160
    Lt. Dangle
    Ohio
    No idea, sorry.
