3rd gen Toyota Tacoma V6 Checking or Reading the Engine Oil Level with the Dipstick
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yo_traigo_una_tacoma, May 10, 2025.
  1. May 11, 2025 at 3:20 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I should do that before I goto work...which means, I need to leave 5 minutes earlier.
    Granted, the oil needs to drain even from the dip stick tube.
    I believe there's residual oil hiding in there especially if the tube is angled towards the oil pan...which I believe it is.
  2. May 11, 2025 at 3:56 PM
    Yo_traigo_una_tacoma [OP] Member
    2018 Tacoma TRD Sport
    Yeah i have posted some pictures now
    yotadust[QUOTED] likes this.
  3. May 11, 2025 at 4:48 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Are we supposed to check the oil?
  4. May 11, 2025 at 4:48 PM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Absolutely best way for me. Just sticking it in and out was absolutely frustrating and surprisingly difficult to get a good read. I just wipe it down. Re Insert and give it a few for oil to settle within the tube. Noticed better results when using the dimples in one orientation. Can't remember for the life of me, but think it is actually dimple side down.
  5. May 11, 2025 at 5:05 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Just once when you change the oil.
    If there are no leaks, you're GTG. lol
    t0p_d0g[QUOTED] likes this.
  6. May 11, 2025 at 6:03 PM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    What a ....dipstick !
    TacoTime55 likes this.
  7. May 11, 2025 at 7:50 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    The correct wait time is ‘e’ seconds or 2.72 seconds. (Euler’s number). As you can see from the OP‘s results, this would have resulted in a correct oil level reading. And as everyone knows, Euler is Swiss for “oiler”. And the natural log of ‘e’ is one. [ ln(e)=1 ] So, obviously, 2.72 seconds is the correct wait time for 1 full measure of oil.
    No worries, Buck. Since ‘e’ is natural constant, you’ve probably been waiting the correct amount of time without even thinking about it!
    davidstacoma likes this.
  8. May 12, 2025 at 11:44 AM
    yotadust
    yotadust Well-Known Member
    pulling the dip stick when they put the dam hood prop rod right in front of it.
    ljflex likes this.
  9. May 12, 2025 at 3:25 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    The more times you pull the dipstick out then back in then out then back in you are just coat1ng the inside of the dipstick tube with more oil to come off on the dipstick when you pull it out each time.IMO
    t0p_d0g likes this.
  10. May 13, 2025 at 9:27 AM
    gologit
    gologit Well-Known Member
    In the redwoods.
    2023 SR5 4x4 long bed
    Nothing major or fancy. Just stuff to make it work better for me. Running boards, seat covers, BakFlip
    The OP makes me wonder what else I've been doing so horribly wrong in over fifty years of driving. Maybe I've just been lucky?
  11. May 13, 2025 at 4:21 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    50 years ago we could see the yellow colored oil on the dip stick.
    Now the oil is clear and hard to define exactly where it is on the dip stick, IMO
