3rd gen trans driving me nuts !
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco-dude, Mar 9, 2023.
  1. Mar 10, 2023 at 7:24 AM
    #121
    remote
    remote Well-Known Member
    Minnesota
    2021 DCSB Sport Cement
    Toyota will probably solve this issue on the Fourth Generation by going to a CVT. Then I will blow my brains out.............
    (sarcasm)
  2. Mar 10, 2023 at 7:27 AM
    #122
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Even Subaru has (I heard at least) changed their CVT to have a REAL first gear for take-off, then the rubber-band takes over.
    Taco-dude[OP] likes this.
  3. Mar 10, 2023 at 7:31 AM
    #123
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    More like: "Raced a 4th gen and got my ass handed to me. Now I want a 4th gen."
  4. Mar 10, 2023 at 7:33 AM
    #124
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    The factory tune is 100% intentional and works fine for most. Totally understand where many don’t like it as it’s clear that for some it hits a real nerve.
    The dealer won’t be able to tune your prior expectations or driving habits, so if you’re reading these posts & considering a purchase, take a long test drive around town and on the highway.
    If you own it and it’s making you crazy, you’re in luck b/c the truck is currently #2 in KBB resale. It will not offend anyone if you check out the competition & be sure to share your experience.
  5. Mar 10, 2023 at 7:39 AM
    #125
    RichochetRabbit
    I am not part of the complaining crowd. I could have (maybe) repaired my Corolla, but I wanted a truck for off-road (I am in Arizona) that even my ignorance found to be highly recommended. I saw the window sticker and knew my "easy to get" mpg would drop from 30. Pick your poison.
  6. Mar 10, 2023 at 7:54 AM
    #126
    MrWrestlingII
    MrWrestlingII Well-Known Member
    It’s definitely not driver habit. For whatever reason some of these trucks run fine and others don’t.
    My 2021 OR was a complete POS on the factory tune. KDmax came out with their 1st tune when I was at 1,800 miles. In that time there had been no “learning”. The thing was crap and I’d resorted to manually shifting my AT truck, what a joke. Driving into a wind at freeway speeds was miserable. With a 10mph headwind it would have a hard time holding 5th gear (6th was useless),with a 15mph headwind I’d just give up and go the 4th gear.
    The initial KDmax 6.0 tune transformed my truck but it wasn’t perfect by any means. Since then I’ve flashed every one of their updates and noticed significant improvement with each one. Currently I’m running a customized version of 9.0 and am amazed at how well the truck runs and shifts. Constant Speed Cruise Control could still be improved but otherwise the tune is about perfect now.
    PapaRee and Taco-dude[OP] like this.
  7. Mar 10, 2023 at 8:08 AM
    #127
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Try having the dealer, if you trust them to actually do it, clear learned values. It will wipe the learned memory in the ecu. Basically after restarting and driving it will be as if the transmission hasn’t learned anything yet. And since it’s no longer new drive it the way you drive all the time until it learns your driving style all over again. In other words don’t drive it like it’s new and on break in time.
    Friend has a taco and went this route and it fixed a lot of his shifting issues.
    Taco-dude[QUOTED][OP] likes this.
  8. Mar 10, 2023 at 8:24 AM
    #128
    pndwind
    pndwind Identifies as a Clown.
    Bret
    Heart of Dixie
    Gas Guzln Pig
    I think it should adjust to a new driver over a period of time.
  9. Mar 10, 2023 at 10:38 AM
    #129
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    If you do all highway around 65 mph, you'll see that after 150 mile trip.
  10. Mar 10, 2023 at 10:45 AM
    #130
    PTSDTherapy
    22 SR5 DCSB
    Can verify that. Traveling 800 plus miles I kept it around 65 to 70. On the flats hit 24 plus. At the end with mountains and hills I was at 23.3. And that was figured by miles on the odometer and gas in tank at fill ups removing 8 percent for variations in when the clicker turned the pump off.
    In Wyoming where speed limit is 80 and I did 80 it dropped significantly to around 17.3 at lowest and 18.9 at highest.
    Sixty five to 70 is definitely mpg area.
  11. Mar 10, 2023 at 10:52 AM
    #131
    RichochetRabbit
    My Corolla, weighed down with my first installment of moved possessions, when driving 80 as a test in deep-West I-20 Texas saw a plummeting MPG. That experiment stopped fast and 70 became the speed.
  12. Mar 10, 2023 at 11:32 AM
    #132
    Taco-dude
    Taco-dude [OP] Well-Known Member
    when I make my next appt I’ll mention this, see if they’ll do it
  13. Mar 10, 2023 at 11:45 AM
    #133
    Taco-dude
    wish I could say the same friend, I drive this one as normal as one would, I don’t floor it to get to 50mph nor does it take me 5mins to get there, all I want is to be able to drive at a steady speed wether 40mph or 60 without it feeling like the engines missing out, not really asking much out of a $43k truck
  14. Mar 10, 2023 at 11:54 AM
    #134
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Someone didn’t do their homework. It’s only been a problem since 2016
    3TMaverick and LeakyAC like this.
  15. Mar 10, 2023 at 12:24 PM
    #135
    Taco-dude
    Being a Toyota you wouldn’t think homework was needed, thought wrong
    usmc2msu likes this.
  16. Mar 10, 2023 at 12:31 PM
    #136
    khine13
    khine13 Well-Known Member
    New Hampshire
    2022 MGM Pro Auto, 2002 SR5 DoubleCab (Sold)
    Lomax Tonneau Cover, Wildpeaks
    KDMax tune. Just do it.
  17. Mar 10, 2023 at 12:34 PM
    #137
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    ^^THIS^^
    Then you'll be back here smiling ear to ear saying how great your truck is.
    Do it!
  18. Mar 10, 2023 at 1:36 PM
    #138
    Taco-dude
    Yea agreed, tacoma holds its value.Im going to give it some time, if in 8months or so I’m still unhappy it’s either a tune or it’s gone. “If” I decide on the competition I will inform, thanks
  19. Mar 10, 2023 at 1:47 PM
    #139
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Why do these "i hate my automatic transmission " threads always evolve into tune commercials? One has to wonder. :confused:
    jsinnard, MadKatt, VB25 and 1 other person like this.
  20. Mar 10, 2023 at 1:52 PM
    #140
    Fatback17
    Fatback17 Masshole
    Billy
    2020 TRD Pro MGM
    Uhh cuz thats what fixes it. :thumbsup:
