3rd gen transmission Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by houndhunter111, Aug 12, 2020.
  1. Aug 14, 2020 at 9:16 PM
    #41
    houndhunter111
    houndhunter111 [OP] Member
    Idaho
    2017 Tacoma OR & 2015 Tacoma OR.
    3” lift All the rest is stick 3” lift TRD Exhaust Cali raised pod lights SOUTHERN STYLE OFF-ROAD SLIM FRONT BUMPER WITH WINCH MOUNT
    UPDATE:
    So we got the truck back from the transmission shop. It was just under 1 gal low on oil. Yeah 1 gallon. The damn dealership told me the oil level was good. As of right now it drives like new. The color of the oil was tinted light brown but he said still looked good enough to not worry to much about severe damage done. Time will tell. But even if it goes to shit he can rebuild the trans for around $2000 and that’s with a brand new oem valve body. Thanks to all for your input, I hope this will help anyone in the future. Make sure your off-roads have enough trans fluid..
    The Mink, DMel, jmauvais and 10 others like this.
  2. Aug 14, 2020 at 10:18 PM
    #42
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Why are so many Toyota dealerships incompetent? Ugh. Glad your truck is going again, did you change the fluid and filter? I would
    cryptolime and oconnor like this.
  3. Aug 15, 2020 at 6:01 AM
    #43
    houndhunter111
    Idaho
    No idea. I just think it’s there way of doing things don’t think it will ever change. Yes changed the oil and filter.
    AKGSD[QUOTED] likes this.
  4. Aug 15, 2020 at 9:26 AM
    #44
    FLA_Hoosier
    FLA_Hoosier Well-Known Member
    Rick
    Space Coast
    2017 White TRD Sport AC
    New tech. Probably loosened the engine oil plug a bit, oil seeped out, so he said to himself "tranny fluid level is good".
    :rofl::rofl::rofl::rofl::rofl:
  5. Aug 15, 2020 at 9:48 AM
    #45
    Alby22
    Alby22 Well-Known Member
    Ashville, Ohio
    Cement 2020 Toyota Tacoma TRD Sport 4x4 Double Cab, Long Bed
    Are you going to drive it to the Toyota dealership that tried to rob you???? I would want to show the service manager
    gsubioguy and EZE like this.
  6. Aug 15, 2020 at 10:25 AM
    #46
    houndhunter111
    Idaho
    Yeah I going to drive it this week to be 100% we took care of the problem. Then I’m going to drive it right up front so they can pull anything in until some refunds the $150 they charged to tell me the oil level was fine and tell me the check engine light was on.
  7. Aug 15, 2020 at 10:31 AM
    #47
    Timmcc02
    Timmcc02 Well-Known Member
    Tim
    2017 TRD OR
    Your probably not going to get very far doing that but if you really want to hurt them go on Yelp and any other rating websites and write them a nasty review about everything that happened and trust me that will hurt them far worse. They will probably call you and offer a refund to take down the reviews.
  8. Aug 15, 2020 at 2:35 PM
    #48
    Dsmitc90
    Dsmitc90 Member
    2016 Tacoma SR 4WD 5MT
    Because the dealerships have pretty much ran off all of the good, knowledgable technicians and replaced them with $12 parts changers.
    AKGSD[QUOTED] and Dirk Diggler like this.
  9. Aug 15, 2020 at 4:32 PM
    #49
    AKGSD
    Joe
    Alaska
    Having worked in a dealership... yeah. Not nearly enough of that $150/hour fee went to the technician
  10. Aug 15, 2020 at 4:39 PM
    #50
    MunchTIME
    MunchTIME Well-Known Member
    SD, CA
    If I were you I would dispute the transaction on the credit card. They did not provide the service that you paid for.
    I hate that dealerships and greasy mechs get away with fraud like this. Once you find a reliable shop tell everyone you know about it and take care of them. Speaking of, anyone in the middle GA area in need of a shop let me know, ASX is the best hands down.
    AKGSD likes this.
  11. Aug 15, 2020 at 4:40 PM
    #51
    MunchTIME
    SD, CA
    Did you find any evidence of a leak by the way? Wondering if it was that low from the factory I’m going to check my tranny fluid and change diff fluids this month. I have 36 K
  12. Aug 15, 2020 at 4:56 PM
    #52
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    so we went from a salvage yard buy with a poorly designed auto transmission from Toyota, to a miss diagnosis by a Toyota dealership whom said the ATF fluid was up to the correct level, to a rediagnosis by another who says your a gallon low on ATF! why didn't you check the ATF level yourself before you did anything?
  13. Aug 15, 2020 at 5:05 PM
    #53
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Wow. You were 1/3 empty? Are you original owner? Hard to believe you made that far..
    Edit. Never mind. Salvage title explains.
    cryptolime and BillsSR5 like this.
  14. Aug 15, 2020 at 5:12 PM
    #54
    BillsSR5
    bill
    2014 SR5
    the real question is where did 1 gallon of ATF go?images_0f64c36be6748c4bd4465038bd6cc8b09371b51b.jpg
    Dirk Diggler likes this.
  15. Aug 15, 2020 at 5:31 PM
    #55
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Could you throw out that shop ? In in middleish GA
    Edit: nevermind I did a Google
    MunchTIME[QUOTED] likes this.
  16. Aug 15, 2020 at 7:05 PM
    #56
    AKGSD
    Joe
    Alaska
    Well what’s strange, is you’d think the fluid was low from the wreck & likely radiator replacement — but why would it have shifted fine for the last 32k?
    May be worthwhile to check the transfercase fluid levels to make sure the transmission isnt leaking into it
  17. Aug 16, 2020 at 8:15 AM
    #57
    BillsSR5
    bill
    2014 SR5
    cause troll post:alien:
  18. Nov 23, 2023 at 3:05 AM
    #58
    The Riddler
    The Riddler Well-Known Member
    Boston, MA
    17 Sport
    Ok. I had a feeling a thread was going. I had my transmission go on my 2017 Sport this past spring. I figured it was from pulling a 20' boat all over mew England fishing. The extended warranty covered the replacement at 85k miles. Rebuilt.
    My boss who has a 2017 Off-road had his trans fail last week. Apparently the cooler lines corroded from the inside prevented a flow to cool. It was only a matter of time. He was at 119k.
  19. Nov 23, 2023 at 12:18 PM
    #59
    Pista1
    Pista1 Well-Known Member
    Pedro
    Ensenada, Baja, MX
    3rd Gen 18 4x4 TRD Sport
    TRD intake, TRD exhaust, Tuned, 6112's/5160's
    3yr old thread I know, my truck started doing the exact same thing, so I've been searching here for some info... def going to check fluid level 1st before doing anything else, good to hear you got it resolved and way cheaper...
