3rd Gen Transmission Fluid level Check
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FOXY 367, Jan 15, 2016.
  1. Mar 28, 2016 at 2:13 PM
    #481
    Haikin
    Haikin Well-Known Member
    Awesome, I'm gonna take this to my dealership and show them this. I also called Toyota Corpoate and opened a case about the delay from reverse to drive. I urge others to call Toyota and do the same.
  2. Mar 28, 2016 at 11:42 PM
    #482
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    Check your Trans fluid level yourself. I added a quart when it was cold and lubed the drive lines while I was under it. Did the jumper trick and let it warm up. While it was idling, I pulled the jumper. Once it hit 95 and the "D" came on, I pulled the "Check" plug and let the excess run out (2-4 oz). Tightened everything up and took it for a spin. First thing I noticed was that it no longer was hunting for gears. Following morning I still had the R-N-D pause, so when I took it to the dealer a week later for the 10k service, I told the dealer that I was still having problems with the pause and let them enter it into the system, had them reset the transmission computer mapping. No more R-N-D pause.
    Sure I did most of the work, but at least I'm not dealing with it any more and if it does become a problem its still in the system showing that I had been having issues.
    Blazingbluesport likes this.
  3. Mar 29, 2016 at 2:49 AM
    #483
    alf
    alf Well-Known Member
    Alf
    Houston
    TRD OR 4x4
    ^^^^ so you could've just reset it with the battery? Your method seems like how I wanna do it.
  4. Mar 29, 2016 at 4:15 AM
    #484
    pepelconde
    pepelconde Well-Known Member
    2016 Trd Sports Silver
    Added oem running boards,sil protectors,trd shifter,tailgate raised inserts, Toyota exhaust tip,husky liners front and rear lund soft trifold tonneau cover,US Army Soldier for Life rear slider glass decal
  5. Mar 29, 2016 at 4:36 AM
    #485
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    so this morning I tried something different. I drove to work in the ECT power mode.
    The truck drives so much better and I actually got better MPG in that mode then I did in regular. Not alot maybe .4mpg better but it drove ALOT better
  6. Mar 29, 2016 at 5:32 AM
    #486
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    yep feels much different with ECT, need to make that thing stay on! :)
  7. Mar 29, 2016 at 5:34 AM
    #487
    16TacomaSport
    Jon
    Pittsburgh PA
    yea i am probably going to drive it with ECT on at all times now. So far i dont see any negatives. Truck drives night and day better and i am getting better MPG out of it in that mode thats supposed to give you worse. Makes me feel like even more they really butchered up that programming in the normal mode
  8. Mar 29, 2016 at 5:35 AM
    #488
    BlkTaco47
    BlkTaco47 Unhinged
    I use it now and then, never on the highway though as I see no change
    and read mpg's take a big hit but yours is pretty good?
  9. Mar 29, 2016 at 5:36 AM
    #489
    16TacomaSport
    Jon
    Pittsburgh PA
    yea normally when I drive to work I get about a reading of 17mpg for my trip when i park. today i believe it was 17.5mpg when i parked and the traffic was a little worse this morning then past few days of work.
    I probably wouldnt use it on the highway but my commute has zero highway and actually very small areas that i can even get up to 60mph at all
  10. Mar 29, 2016 at 6:58 AM
    #490
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    Just took a seat in the waiting room of my local toyota service department. Fingers crossed they can find a reason to check the fluid, truck has been driving mostly symptom free since I called to make the appointment.
  11. Mar 29, 2016 at 7:59 AM
    #491
    RPain
    Chandler, Arizona
    Dealer couldn't reproduce the issue, but told me they would let the truck cool down and check the fluid anyways. Score.
    TacoJonn likes this.
  12. Mar 29, 2016 at 8:10 AM
    #492
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    When I use the ETC around town, 35-45mph, my mpg is about the same as long as I keep my foot out of it. When I hit the highway though, 60-65, it will be a little worse because it likes to stay in 5th longer. If I have ETC off it'll jump right to 6th as it should and I'll get better mpg. I like the ETC though. It drives better. I wish the normal mode was about halfway between what it is now and with ETC enabled.
  13. Mar 29, 2016 at 1:28 PM
    #493
    RPain
    Chandler, Arizona
    after 6 hours in the toyota waiting room.. tranny fluid was determined to be at the correct level, u-bolts were in spec, and my u-joints were greased properly. Although no fixes were necessary at least I have the peace of mind knowing my truck came out of the factory as it should have.
  14. Mar 29, 2016 at 1:43 PM
    #494
    manofsteele2003
    manofsteele2003 Well-Known Member
    2016 Blazing Blue TRD Sport Double Cab
    17" TRD wheels w/265/70/17 BFG KO2s, Weathertech mud flaps, Gecko LED bed lights, more to come.
    Mm, they told me the same until I checked it all myself and found otherwise.
  15. Mar 29, 2016 at 1:44 PM
    #495
    BlkTaco47
    BlkTaco47 Unhinged
    same here, that would be perfect. in the mean time, someone needs
    to figure out a ECT ALWAYS ON mod. :D
  16. Mar 29, 2016 at 1:47 PM
    #496
    BlkTaco47
    BlkTaco47 Unhinged
    Until YOU check it, you'll have no real peace of mind. They check it with tech stream if they
    check it at all and that doesn't show the proper level. I was told u bolts were in spec to... @ 110 ft lbs. :eek:
    same with the joints, "all greased, good to go!" lol Until I get under there, I don't believe anything they
    said, oh yeah, the vibe many of us feel, "yeah, that's normal, no real issue."
    I did it for 1 reason - so it's documented with Toyota.
    alf likes this.
  17. Mar 29, 2016 at 1:56 PM
    #497
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I don't think they actually checked the tranny fluid..
    Do it yourself and be sure..!!
    alf likes this.
  18. Mar 29, 2016 at 2:00 PM
    #498
    over60
    Muskoka, Ontario
    Just make sure your tranny is full... Then see if you really want the "ECT" button all the time... I bet not.... The tranny actually works well "if" it's full to proper level... try it..!!
  19. Mar 29, 2016 at 2:21 PM
    #499
    BlkTaco47
    BlkTaco47 Unhinged
    I plan on checking it soon, I haven't rushed under there as I've had/have ZERO
    issues with anything other than the weird steering wheel vibe.
  20. Mar 29, 2016 at 2:48 PM
    #500
    JoCoQS
    JoCoQS This until I can afford a REAL truck
    Kelly
    Kansas
    2016 Jeep Cherokee
    And the saga continues. ..
    Today I obtained a copy of the pre-delivery service check sheet and a Diagnostic Report, from the selling dealership,for my truck supposedly performed the day prior to me picking it up. Of great interest is box 1 in the UNDER HOOD section, of the pre-delivery check sheet. Box 1 states the engine oil and ATM fluid levels are "OK."
    Yesterday I took my truck to a different dealership and told them to check the ATM fluid level, and advised them if the level was ok that I would pay for it out of pocket, but if it was low then it had better be covered by warranty.
    Shocker! The level was "about a ½ quart low." The level was brought up to specifications and I have not noticed the shifting problems that precipitated my visits to the initial dealership's service center.
    I called Toyota National to speak with the case manager for the case open on this issue, but he was "busy" and could/would not accept my call. I was advised to leave a message. I then requested to be elevated to the next, higher person. The advisor rudely advised me there were procedures and that I would need to leave a message if I wanted to speak with anyone from Toyota.
    This pretty much ticked me off so I called the initial dealership to speak to a service manager to ascertain why I was lied to about the ATM fluid level. Both service managers there were "busy" also. Toyota must have the hardest workers in the WORLD.
    I know what action I would like to take, but I am open to suggestions on how to deal with Toyota's lying about a new vehicle.
