3rd Gen Transmission Fluid level Check
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FOXY 367, Jan 15, 2016.
  1. Feb 5, 2016 at 5:05 PM
    #81
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Sorry to ask again but, I am trying this now and, my D indicator only stays lit for a few moments after I put it back in park. The other indicators on the tach keep flashing. If take the jumper out at this point the flashing indicators go out and I assume I am no longer in temp check mode.
    Should the indicators keep flashing with the jumper removed or do those not matter and I can still be in temp check mode? Though the D goes away there is no P.
  2. Feb 5, 2016 at 5:19 PM
    #82
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I believe you had in the temp sensing mode once the D light came on momentarily.....you then must let run to warm up....then the D light comes on and stays on....NOW check the level by pulling the plug.....
  3. Feb 5, 2016 at 5:22 PM
    #83
    over60
    Muskoka, Ontario
  4. Feb 5, 2016 at 5:28 PM
    #84
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    If the D goes out then you are not in temp check mode. As long as the jumper is in place all the indicators on the dash panel will continue to flash like a Christmas tree. Once you remove the jumper then they will revert to normal. However, the D should still be lit - flashing if not in the proper temp range or solid if in the temp range. Note that the flashing occurs when the temp is either too cold or too hot. If the D doesn't stay lit or flashing when back in Park then you are *not* in temp check mode.
    If you have driven even a little while the transmission is probably over temp. It's best to start this procedure when you are sure that it's below temp, like first thing in the morning after the truck has been parked overnight. It can take a few hours to cool down after you have driven even a few miles.
  5. Feb 5, 2016 at 5:30 PM
    #85
    swimmer
    Tucson
    2016 TRDORAC4WD
    Yep. I read that but missed this important tidbit.
    After the 6 shifts are completed the red AT TEMP light should illuminate for 2 seconds (important to note).
    So, I gather the cessation of the flashing lights when I pull the jumper is not of consequence.
  6. Feb 5, 2016 at 5:32 PM
    #86
    swimmer
    Tucson
    2016 TRDORAC4WD
    OK. Truck was sitting all day. I commute by motorcycle. So this info about the D staying lit is a difference from that 2nd gen post where the AT TEMP indicator goes out after a couple of seconds.
  7. Feb 5, 2016 at 5:32 PM
    #87
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Yes, this is a great thread. For anyone who simply wants to check if they are low, just add a 3/4-1 quart of oil first, then follow the procedure to get into temp check mode before pulling the check plug. Let any excess flow out until the "trickle" then button things up.
    Pportera likes this.
  8. Feb 5, 2016 at 5:54 PM
    #88
    over60
    Muskoka, Ontario
    It is if you pull the jumper BEFORE the D light stays on.... Don't pull the jumper until you have the solid "D" light showing..now you are on the right temp range....
  9. Feb 5, 2016 at 6:03 PM
    #89
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Just to clarify, you can be in temp check mode with the oil too cold or too hot (flashing D) or in the correct range for pulling the check plug (solid D). You can remove the jumper any time it is in temp check mode.
  10. Feb 5, 2016 at 6:04 PM
    #90
    swimmer
    Tucson
    2016 TRDORAC4WD
    I appreciate the info you guys. But, one person is saying the D should stay lit (or flashing) after it goes into park and the other (and that other thread) is saying it will just stay lit for a moment and not go back on until at temp.
  11. Feb 5, 2016 at 6:05 PM
    #91
    swimmer
    Tucson
    2016 TRDORAC4WD
    I've never seen the flashing D. Just the brief D. Have not let it warm up enough to get at temp since I wasn't sure I was in temp check mode.
  12. Feb 5, 2016 at 6:07 PM
    #92
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Just stating what happened in my experience.
  13. Feb 5, 2016 at 7:25 PM
    #93
    swimmer
    Tucson
    2016 TRDORAC4WD
    Yes sure, and I appreciate that. Just conflicting info. I don't know what the point would be of removing the jumper once the temp is in the check range as posted above. I'll just have to let it get warm after getting the brief D and see if I end up with a steady D.
  14. Feb 6, 2016 at 4:03 AM
    #94
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    To be safe, I'd wait for the solid D before removing the jumper. Since there appears to be conflicting info and I'm old and feeble maybe I'll try again with the tranny cold. When I did this previously, I had to wait for a few hours for things to cool down as I had driven to the store for a quart of oil and a hand pump. It's possible the temp was a bit high when I started it up again and the D was flashing (over temp) but as things began to circulate from the tranny cooler and the extra that I added it cooled down to be in range (solid D).
  15. Feb 6, 2016 at 5:48 AM
    #95
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Doesthe tranny feel any different after the OP Coded update?
  16. Feb 6, 2016 at 6:24 AM
    #96
    Justin85
    Justin85 Well-Known Member
    Justin
    It feels like it's back in learning mode. I really haven'thad a chance to drive it much since i picked it back up. I will be taking a 60ish mile round trip this evening and I'll be able to pay better attention.
  17. Feb 6, 2016 at 6:49 AM
    #97
    swimmer
    Tucson
    2016 TRDORAC4WD
    I got this to work. D only shows momentarily. I left the jumper in until steady D. Really, I do not see the point of removing the jumper. Once you get the solid D you are pretty much done. Just need to drain out any access reasonably quickly.
  18. Feb 6, 2016 at 7:10 AM
    #98
    Swampcollie
    Swampcollie Well-Known Member
    Greg
    2017 DCSB TRD sport 4x4 white
    Well, this does it for me. I was planning on trading my 14 for a new one this spring. I am an old fart and not prone to crawl around under my truck any more. Went thru hell with brakes on my 13 without it ever resolved. The 14 has been perfect. Hard to believe all the high tech in the truck, yet they dont know how to put right amt of tranny fluid in it and make it almost impossible to check it.
    Pportera and Old School like this.
  19. Feb 6, 2016 at 7:33 AM
    #99
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    I tried again this morning before heading out to the store. Sure enough, the D showed for 2-3 seconds then went out. After idling for 15-20 minutes it came back on steady. My only guess regarding my previous experience is above.
    BTW, was yours low, and if so by how much?
  20. Feb 6, 2016 at 8:01 AM
    #100
    Old School
    Old School You are ignoring covfefe by this member.
    This! ^
