3rd Gen Transmission Fluid level Check
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FOXY 367, Jan 15, 2016.
  1. Feb 14, 2016 at 6:06 PM
    #141
    miguel2016tacoma
    miguel2016tacoma New Member
    miguel
    2016 TRD Sport 4x4
    none
    Having transmission issues with my 2016 Tacoma TRD Sport 4x4, Had new Trans. put in already with only 1500 miles. And still having issues with it. When its cold in the mornings drops out of drive then slams into gear.
    Other problems are, it will idle irradically in drive and it lunges forward, and when in traffic forget it. It can't seem to find the right gear to maintain and is constantly shifting up and down, also noticed vibration when in idle.
    Any body else with similar issues?
  2. Feb 14, 2016 at 6:06 PM
    #142
    Sola Gratia
    Sola Gratia Well-Known Member
    Len
    San Diego, CA
    2016 Tacoma SR5 AC, 4cyl, Super White
    Doesn't that TSB say it relates to the 6 cylinder automatic, and not the 4?
    Disregard, I just save the designation on the last page and it is indeed the 4cyl.
    Thanks for posting.
    whopper likes this.
  3. Feb 14, 2016 at 6:21 PM
    #143
    TrdSport2016
    TrdSport2016 Member
    This ^. This shifting issue may, indeed, related to software issue. I had a Honda where it would make a loud (I meant loud) clunking sound when shifting to R from P on an incline/uphill. It still does it every time. However, it drove fine and no sign of transmission damage, and etc. I had 83,000+ miles on it until a large box delivery truck finished her from behind.
  4. Feb 15, 2016 at 3:48 PM
    #144
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    Got my truck back home from dealer. Tech could not verify my Concern. But since I Kow the advisor and tech I was able to watch my friend check the fluid level and it was correct. Sucks they couldn't verify but atleast my issue is documented. And I'll see what happens from here.
  5. Feb 16, 2016 at 1:39 AM
    #145
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    My dealer said "if the fluid is low my engine light will come on, its still too new to tell if theres a problem so keep an eye on it"
    Ill check it myself now
  6. Feb 16, 2016 at 2:16 AM
    #146
    linnmarb
    linnmarb Well-Known Member
    2017 Inferno TRD OR DCSB 4WD
    Allright peic
    Just a bit of advice, I live where you do. Don't go to Huntsville to have that truck serviced. Go to Decatur. I got stories about the service department of that dealership that will make your jaw drop. They are the last place I would recommend to anyone.
    3dBdown and BAMA-256[QUOTED] like this.
  7. Feb 16, 2016 at 4:57 AM
    #147
    JHFMX
    JHFMX Well-Known Member
    2016 BBP Tacoma Double Cab Longbed SR5
    I've had the same issue with the dealer, what's worse is that they lie to you and think you're misinformed. This dealer says they CAN replicate the issue, but that they can't check without permission from corporate Toyota. As in leaving pissed off, the service adviser tells me it WAS checked and was good. I had just finished road testing with the service manager. To make things worse, I heard the tech tell the service adviser that there wasn't enough time to check it and that he ran a diagnostic and it wasn't throwing any codes. I called the dealership I bought it from about an hour and a half away and they said bring it in and they would check it. They did say it would be about 5 hours, but that I can deal with. I attached my service ticket from the first dealer for shits and giggles
  8. Feb 16, 2016 at 5:51 AM
    #148
    viking15
    viking15 Well-Known Member
    Joe
    I can't believe Toyota is not putting the right amount of transmission fluids in these trucks at the factory Come on Toyota
    8102 likes this.
  9. Feb 16, 2016 at 10:53 AM
    #149
    BAMA-256
    BAMA-256 Well-Known Member
    Rex
    Huntsville Alabama
    2017 SR 4x4 5 speed manual Past-2016 TRD Offroad 4x4
    Thanks for the heads up! :thumbsup:
  10. Feb 20, 2016 at 2:54 PM
    #150
    P8tron
    P8tron Well-Known Member
    Austin, TX
    2016 MGM DCSB 4x4 OR
    Yep. 1/2 quart low.
    TRD OR 4X4 with tow pkg.
    Received delivery today and told them I wasn't signing or test driving anything until I was allowed to watch them check ATF level. Slipped the tech $20 and thanked him profusely. He wasn't familiar with the issue, but now he is, and was impressed I was correct. I'll contribute to the poll now.
  11. Feb 20, 2016 at 3:55 PM
    #151
    FlyFisher1
    FlyFisher1 Well-Known Member
    NJ
    Thats a GREAT idea! Im doing that too when mine comes in...
  12. Feb 20, 2016 at 4:25 PM
    #152
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    Had mine checked today. When I asked the tech how much was added he told me 1.5 quarts. I'm not sure if that amount is true or not but I can say it drives smoother now. They were familiar with the possibility as they had another come in last week for too much fluid. That's what they said at least. Don't know if it truly was too full or someone heard about this and decided to just add some them self.
  13. Feb 20, 2016 at 9:00 PM
    #153
    P8tron
    Austin, TX
    The poll is currently 36:18, or 2:1 low on ATF.
    Why not ask them to, or make them, check the ATF level, if you have to, especially if you've already agreed on a price and they've ordered it for you.
    Also, be nice to the tech. He's probably never heard of this issue, and tip$ go a long way. Watch him do it once ATF is in temp. range, and look to see if any fluid drips out when he pulls the plug. Mine didn't drip a single drop, and was at 109'F. He was shocked, and then smiled; probably because they all thought I was full of it. (I'll check the U-bolts and differential fluid myself.)
    ATF started at 170'F. Tech. lifted the truck and put a fan right up against and blowing directly on the transmission. We watched the temp. slowly fall, and in about 30-45 min. the whole process was complete.
    Also something interesting I learned from the tech. is that all trucks are lifted and run for 5 hours, without putting any miles on them, before being shipped from the manufacturer. This is how they test them without driving them, to ensure they are working properly. Tech. said no need to worry about a break in period. Just drive normal and the computer will learn and adapt to your style and habits...
    Finally, mine came in after just one week of being special ordered. They quoted me 4-6 weeks with no promises.
    I put $500 on 2/13 and picked it up today! Keep hope alive. It may be sooner than you think.
  14. Feb 20, 2016 at 9:07 PM
    #154
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    C'mon...
    Why lift them?
  15. Feb 20, 2016 at 9:25 PM
    #155
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    I had an issue in the early morning.
    Turn on the truck, waited 3 minutes while I set my GPS and connected my phone. I'm in California so the temperature is 50° F in the mornings right now.
    After, I would drop my truck traight to reverse and slowly remove my foot of the brake and the transmission would slip in and out without pressing on the gas.
    This morning I added 2/3 of a quart and God does it drive 1000x better.
    No more transmission slips, and the down/up shifts are really smooth.
    Update: My brother works in the service department at a toyota dealer. I made him get me a quart of Toyota Genuine ATF WS. So I'm not mixing different fluids, hopefully.
    Cost him $6.75. Cheaper than driving out to the dealer and having them "check" it. Overall time took me 20 minutes. Shorter than me driving up to the dealer.
  16. Feb 21, 2016 at 5:26 AM
    #156
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    So Toyota idles 1000 trucks for 5 hours every day. :facepalm: I don't think so. Heavy dose of bullshit that tech is feeding you.
    billybob50 and Aussiek2000 like this.
  17. Feb 21, 2016 at 6:03 AM
    #157
    gearcruncher
    Canadain bumper technician
    We are still trying to figure out why this happened . Yes we blame the dealers as they are the last line of defense but what is the root cause ?
    Happened to some of the 2nd gen trucks both 2 wheel drive and 4x4 with tow package .
    Do not wait for lights to pop up on the dash . If you are feeling delayed shifting , get it fixed immediately .
    Do not wait for the transmission temperature light to illuminate . You have completely cooked your fluid by then and probably done some nasty damage to your transmission .
    Reports are coming in that low transmission fluid can be found on both 2016 4x4 trucks with the tow package and 2 wheel drive trucks without tow package .
    https://www.tacomaworld.com/threads...be-low-on-fluid-directly-from-factory.405642/
    Our original theory was the transmission thermostat was " NOT " being pinned when the cooler was completely empty .
    If you have thoughts , please share ..................
    All the information can be found in my low fluid poll
    I am trying my best to keep the information as relevant and accurate as possible .
    There are soo many low on fluid posts scattered throughout Tacoma World to read , I have a hard time keeping up.
    If you have new information that may help others , please post at the link below .
    I update this thread daily just as I did with the low fluid poll for the 2nd gen trucks
  18. Feb 21, 2016 at 6:48 AM
    #158
    P8tron
    Austin, TX
    Not sure why he would lie. No reason to. I simply asked him if I should drive it gently for any certain period of time or distance. He said no and that was his reason why. You are purely speculating, and really don't know, I imagine.
  19. Feb 21, 2016 at 7:59 AM
    #159
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    https://carmanuals2.com/toyota/tacoma-2016-owner-s-manual-73379
  20. Feb 21, 2016 at 8:02 AM
    #160
    billybob50
    Bob
    Concur!
