3rd Gen Transmission Oil Warning Message, Check Engine Light, and other warnings
Discussion in '3rd Gen. Tacomas (2016-2023)' started by northwest_inferno, Jan 4, 2017.
  1. Jan 4, 2017 at 6:07 PM
    northwest_inferno
    northwest_inferno [OP] Active Member
    Long Beach, WA
    2017 Inferno Tacoma SR5 4x4
    FORTIN EVO ONE Remote Start
    Got some weird issues guys.
    Just a few hours ago, I put the taco into reverse. It immediately stalled and gave me a "High Transmision Oil Temperature" message. Right after this I tried starting it and it just wouldn't fire until serveral turns later. I noticed a hissing sound coming from the rear but I couldnt identify exactly where. Now it starts, but 90% it stalls when I put it into reverse or back into drive. I get the trans temp message, And sometimes even "Check charging system" or "check brake system" and then the brakes freeze up.
    What the hell is wrong with ny taco?
    I've already made an appointment at the dealer. (Two fn weeks away)
    Thanks for any input!
  2. Jan 4, 2017 at 6:11 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    That's definitely a new one. I would call back and insist someone look at it. Driving a new vehicle that stalls and warning lightsigns coming on should not have to wait that long. IMO
  3. Jan 4, 2017 at 6:12 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    :bananadead: Call roadside assistance and have it towed to another dealer? Sorry man it sounds like you got a shaft on the third gen. Could be a bad crankshaft position sensor. Need to let dealer troubleshoot but 2 week wait is ridiculous. I'd call corporate and see if they can escalate your appointment
  4. Jan 4, 2017 at 6:16 PM
    clomeli13
    clomeli13 Well-Known Member
    christian
    Ontario Cali
    2017 White Tacoma TRD Sport
    Don't bother with appointments, just have it towed as a walk in....
  5. Jan 4, 2017 at 6:49 PM
    J0mes
    J0mes Active Member
    James
    16' TRD Off Road
    Holy crap man... This is some sheeeet.... There isn't another dealer in the area? N' 2 weeks what kind of service is this for a non opp new vehicle?
    Keep us updated would be interested to see how this goes for you.. Hopefully just a bad sensor. Good luck!
    smitty99 likes this.
  6. Jan 4, 2017 at 6:50 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    This...
    vinkon235 likes this.
  7. Jan 4, 2017 at 6:53 PM
    Taco16LB
    Taco16LB Well-Known Member
    Ouch, I would hope they put this in first . 2 weeks is out of line !
    127.0.0.1 and shakerhood like this.
  8. Jan 5, 2017 at 5:05 AM
    DJ TonyT
    DJ TonyT 2017 TRD 4x4 Off Road DCSB - Sunroof and JBL
    TonyT
    Jacksonville, FL
    Morning everyone, not sure if this is the place but I wanted to ask about an issue I have been having to see if anyone else knows about it..........
    When my truck is cold, like it sits over night or sits while I am at work, so when I start it and put the truck in drive, they is a small delay.....its weird.
    Its like someone is tugging the truck for a few seconds and then lets go, after that the truck is fine, it shifts fine, only seems to happen on fresh starts.
  9. Jan 5, 2017 at 5:13 AM
    backtrack2015
    backtrack2015 Well-Known Member
    Austin TX
    2016 Silver DCSB OR 4x4 AT Tech (sold 8/17)
    Pop-n-lock tailgate. New radio knobs. Rear step.
    There is a TSB for the auto that helps with the shift delay and you should also have them check the fluid level in the transmission. See the sticky threads for info on TSBs (Rev 1 now).
    2016Tacoman likes this.
  10. Jan 5, 2017 at 5:21 AM
    DJ TonyT
    TonyT
    Jacksonville, FL
    TSB?
  11. Jan 5, 2017 at 5:38 AM
    backtrack2015
    Austin TX
    Technical service bulletin.
    T-SB-0077-16 Rev 1.
    Software update for transmission.
  12. Jan 5, 2017 at 5:40 AM
    DJ TonyT
    TonyT
    Jacksonville, FL
    Thanks man!
    backtrack2015[QUOTED] likes this.
  13. Jan 5, 2017 at 11:17 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Wait ... what? OP posts about a possible CPS sensor and another post asking about the transmission lag... I'm missing something.
    OK fine.. OP tow the truck to a DIFFERENT dealer. Have them look at the crankshaft position sensor... even tho this issue was supposed to be fixed at the end of 2016 model year production those are the symptoms.
  14. Jan 5, 2017 at 12:43 PM
    DJ TonyT
    TonyT
    Jacksonville, FL
    Thanks, I will say something about both of these - the software update and the sensor.
  15. Jan 5, 2017 at 1:32 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    2 different guys. OP has the stall and another member tranny.
  16. Jan 5, 2017 at 8:18 PM
    northwest_inferno
    Long Beach, WA
    Thanks (everyone) for the quick input. I really do appreciate it.
    So after sitting 12 hours through a cold night, I'm no longer having issues. I'm still going to keep my appointment, though. Just in case I get the issues again. Even before the problems, I was going to go into the dealer for a Trans. firmware update, anyways. So I'll have them flash the new firmware and hopefully I wont have anymore issues.
    This is weird, though. Makes me feel quite uneasy. I haven't done anything to even attempt a fix, so I'm assuming I'll have the issues come back eventually. What's really strange is NO ONE else has seemed to report anything like it. I cant even find a single thread mentioning a "high transmission oil temperature" alert. I'll certainly keep everyone updated on this issue.
    Has anyone else gone into the dealer for transmissions problems?
  17. Jan 9, 2017 at 9:59 AM
    DJ TonyT
    TonyT
    Jacksonville, FL
    I am with you about being uneasy.....I am not sure I really 100% trust anyone to mess with my truck!
  18. Jan 9, 2017 at 10:01 AM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    I had the same thing happen. Crackshaft Position Sensor.
  19. Jan 15, 2017 at 9:58 AM
    northwest_inferno
    Long Beach, WA
    Here we are, 11 days later, and I have no issues. :bananadance:
    Weird...
  20. Aug 22, 2019 at 2:48 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Did you get this taken care of? My girlfriends truck just did this to her and she freaked out, she is also on the beginning of a 9 hour road trip so it’s understandable, CPS?
