3rd gen TRD OR suspension on 2nd gen SR5
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PNWTacoTruck, Feb 17, 2025.
  1. Feb 17, 2025 at 9:56 AM
    PNWTacoTruck
    PNWTacoTruck [OP] Well-Known Member
    Brent
    I read the threads on this swap. Somehow I still have questions.
    1. Will 2022 OEM TRDOR leaf springs change ride height vs stock leafs that may be 217k miles old? I'm not sure if the 1st owner ever changed em out, he had it til 205k. I'm assuming they are original.
    2. I'm trying to sell the truck this year. I really don't want the vibration issue. Is that issue only caused by the two diffs angles in relationship to each other changing? therefore solved by doing a 1" AAL in the rear?
    3. What's the best option to balance out the rake?
    I want the smoother & firmer ride, my old suspension feels rough compared to the newer trucks I test drove. I don't care about the lift. 1" lift is fine with me if the rake is maintained. I can get the whole 2022 setup for $250, but I don't want a can of worms, and I want to maintain the value of the truck which is running perfectly right now.
  2. Feb 17, 2025 at 10:47 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    If it were my truck and I knew I was going to sell it, I'd put on the 2022 OEM stuff for $250 and then do a block in the rear for the rake. Shouldn't have vibration issues from that small of a lift.
  3. Feb 17, 2025 at 11:04 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If it raises the rear, it's because your old springs are worn and settled down.
    But it should not, they are the same springs in the rear.
    It's the front coils that are different. Not the rear.
    SomeGuy_GRM likes this.
  4. Feb 17, 2025 at 12:22 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    3rd gen afaik has the same leafs as the 2nd gen post tsb. Front coils might get you a 1" lift up front.
    I run 3rd gen coils and General Spring HD leafs for a very small lift.
  5. Feb 17, 2025 at 5:06 PM
    PNWTacoTruck
    Brent
    thanks! Any issues with the differential vibration that others have mentioned?
  6. Feb 17, 2025 at 5:15 PM
    SomeGuy_GRM
    With my setup, I'd guess the rake is slightly more pronounced than stock. Never noticed any unusual vibrations, and I look for it. But I'd wager the tolerances are slightly different on every truck, so ymmv.
  7. Feb 19, 2025 at 10:26 AM
    TacoTuesday1
    FL
    There is no point.
    You would be removing pencil shocks, to install pencil shocks.
    In the threads on doing this, supposedly it raises the front a bit. In which case, the rear may not raise. If you find it does not raise, it is not hard or expensive to put an AAL that will give it a tad bit more height in the back. Question is if you will need extended brake lines. I went with some just to be safe. 1. when adding more lift and travel, I didn't want to rip the old lines.
    2. the old lines are old, and rubber. Wise to replace regardless.
  8. Feb 19, 2025 at 11:23 AM
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    First thing that popped in to my mind, if you're selling in a few months...is it really worth the bother?
    Regardless. I gained probably +1.25/1.75 with 3G OR takeoffs and a 1/2" block in the back, but this was replacing old pre-TSB springs in the rear which most likely doesn't apply to you. I also replaced what appeared to be sagging aftermarket stock replacement front struts. I was expecting a touch more, but people's outcomes vary a bit.
  9. Feb 19, 2025 at 12:48 PM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    I did this and would do so again and have zero vibrations. The only lift in the rear was from replacing my sagging rear springs. The front is raised some but it looks good for just swapping out old parts for new. Rides better as well and still wont ride like a "new" truck.
  10. Feb 22, 2025 at 8:27 PM
    PNWTacoTruck
    Brent
    Anyone know if 3rd gen limited suspension would yield the same results?
  11. Feb 23, 2025 at 6:11 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    I don't believe that suspension is any different. The only differences between the years and models are the struts themselves. The rest can be chalked up to age of springs. I'm sure there are model number differences in the springs, but it's negligible.
    I think you are over thinking this. Throw them on, drive for ~200mi and then measure.
  12. Feb 23, 2025 at 6:40 AM
    MSgt O
    2013 Tacoma
    They will not. the Offroad is a progressive spring, hence the slight lift in the front
  13. Feb 23, 2025 at 6:42 AM
    MSgt O
    2013 Tacoma
    The SR5, Limited and Sport do not use the progressive spring like the OffRoad.
    ZColorado[QUOTED] likes this.
  14. Feb 23, 2025 at 7:45 AM
    ZColorado
    13 DCSB OR 6MT
    I did not know that, cool.
  15. Feb 23, 2025 at 8:53 AM
    PNWTacoTruck
    Brent
    ok!
    So if I can get 20k miles 2022 limited suspension, I would likely get a freshly improved ride, with no change to ride height?
  16. Mar 3, 2025 at 5:30 PM
    MSgt O
    2013 Tacoma
    correct!
