3rd Gen TRD Pro what have you done, what will you do. Post it.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacofort, Apr 26, 2019.
  1. Jun 15, 2019 at 1:10 AM
    #141
    4sky
    4sky Well-Known Member
    Kevin Levu
    2018 White Tacoma PRO
    How much of a difference do you think the tweeters do for sound ?
  2. Jun 15, 2019 at 1:15 AM
    #142
    4sky
    Kevin Levu
    Where’d you purchase the hood decal ?
  3. Jun 18, 2019 at 1:56 PM
    #143
    tacofort
    tacofort [OP] Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
    Added a new hatch to the passenger side Another Tern Overland hatch 300 by 300 this time to store dry clothes during showers, keep TP handy for the bathroom, and to provide access to the back corner area of the habitat
    Also finally remembered to take a pic of the full panel I use on the habitat.
    Also got in a Roam adventure case 95L and mounted it to the Prinsu Rack.
  4. Jun 21, 2019 at 10:25 PM
    #144
    hawaii_dave
    hawaii_dave Well-Known Member
    2017 trd pro
    here's my Pro mods up to now.
    AVS in channel vent shades
    window tint 20% front 5% rear
    warn semi-hidden winch bumper 100044
    smittybilt x20 10,000lb comp winch with 95'synthetic rope
    custom made wire harness from stock head unit to amps under front seats no cutting of factory harness ( plug & play )
    rockford fosgate 500 watt sub amp
    jl audio stealth-box 10" sub woofer
    4 gauge amp wiring with 120 amp circuit breaker and fuse
    Soundstream ST4.10000D Compact 4-Channel Car Amplifier
    Kicker 43CSS694
    6"x9" component speaker system front doors
    Kicker 43CSS674
    6-3/4" component speaker system rear doors
    kicker component tweeters in dash
    rough country inline speedometer calibration module
    trail master 3" lift
    front diff dropped
    285/75/16 goodyear duratrac's
    285/75/16 corsa all terrain spare tire mounted in factory location
    total chaos upper control arms
    RCI aluminum trans skid plate
    RCI aluminum transfercase skid
    diamondback se truck bed cover
    3 custom made cross bars mounted to bed cover
    2 4" led side work lights independently switched
    custom 3/4" thick bed mat
    4 Liteway Tracks ( maxtrax)2 red 2 black
    4 tire deflators
    Grit tire deflater set
    Amazon Basics Portable Air Compressor
    pedal commander bluetooth
    Shift Sense pro V2
    300A HEAVY DUTY DUAL AUXILIARY battery ISOLATOR
    auxiliary battery tray mounted on right side
    12 circuit fuse panel
    interstate AGM battery
    6 switch relay/fuse block
    gopro hero w/64gig
    RCI rock sliders with top plates
    2.5lb halotron fire extinguisher for my truck
    4lb dry chem fire extinguisher for others if needed
    factor 55 winch flat shackle
    center console tray
    smittybilt snatch block
    electric lock for tail gate
    K&N drop in filter
    7' whip and flag for sand dunes, custom mount
    Philips H11 CrystalVision Ultra
    trailer hitch cover plug
    4 smittybilt shackles 3/4"
    2 5/8 shackles
    tree saver
    3"x30' strap
    2x usb outlets 1 in rear window other above rear view mirror
    dash camera
    rear window camera
    full under coating
    tail lights costom modififed with
    vled v6 triton changeover bulbs
    vled brake lights now dual brake lights dual running lights . turn signals and reverse lights together in reverse location .
    vled lic plate bulbs, map lights, dome light
    under hood led lighting
    Me-So trd pro coinbox
    Me-So extended fuse panel cover
    Me-So key fob orange
    Streamlight 74350 Strion LED Flashlight, Pink
    Any-time camera mod with front camera
    Any-time gps mod
    hood scoop led light bar
    hood struts ( redline )
    puddle lights in side mirrors
    cam mount chop with plates from BAMF
    CVT Mt.Bachelor rooftop tent
    2X 1/2" soft shackels
    Smittybilt 2722 Universal Trail Jack - 54"
    Lotus Development Slider Adapter for Smittybilt 2722
    Aluminum Rigging Ring ( works as a snatch block 1/10 the weight )
    45QT CAMO Sand Grey Cold Bastard Rugged Series roto molded Cooler
    SEYMOUR MIDWEST STRUCTRON 49632GR shovel
    2 X-BULL Safety Blanket Winch Damper
    20" led white/amber and strobe
    doublethebass and tacofort[OP] like this.
  5. Jun 22, 2019 at 7:54 PM
    #145
    PJTACO
    PJTACO Well-Known Member
    2017 Cement TRD PRO
    Where are the pics yo
    doublethebass likes this.
  6. Jun 23, 2019 at 4:47 PM
    #146
    Foster Imposter
    Foster Imposter Well-Known Member
    Art
    Out in the woods, GA
    2018 PRO MT
    well, after all those mods it's possible he may no longer be able to afford a camera
  7. Jun 23, 2019 at 4:57 PM
    #147
    hawaii_dave
    2017 trd pro
    Is this enough pic's ???
    TK11, PJTACO, Rparker017 and 2 others like this.
  8. Jun 24, 2019 at 2:50 AM
    #148
    Foster Imposter
    Art
    2018 PRO MT
    Very nice! (seems like an understatement).
    That is clean and well-done. One of the nicest on here!
    hawaii_dave and tacofort[OP] like this.
  9. Jun 24, 2019 at 6:04 PM
    #149
    hawaii_dave
    2017 trd pro
    Thank You . More Mods to come
  10. Aug 1, 2019 at 11:30 PM
    #150
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I’ve heard of the anytime front cam. Plan on doing it myself in a month or so. But I had to look up anytime gps. Now I’m curious, do you think it’s worth having?
  11. Aug 2, 2019 at 3:22 AM
    #151
    mchalk13
    mchalk13 Well-Known Member
    matt
    Rapid City Sd
    18 Cav blue TRD Pro
    Where did you get the SW decal. I love SW actually had a lightsaber duel for my wedding as opposed to a first dance (wife's idea, we both can't dance.) but with my Pro being Cav Blue it has become the Captain America build
  12. Aug 2, 2019 at 5:53 AM
    #152
    Impoy47
    Impoy47 YOLO-HA!
    R-nel #KN6UYM
    East bay Tri Valley, Ca.
    Xwing T-19 Pro Voodoo Fighter
    Ebay and Etsy search under star wars decal. Numerous designs. Just depends which side you're on. Dark side or the light side of the force? Bwuhaha..
  13. Aug 2, 2019 at 1:00 PM
    #153
    Juice33
    Juice33 Well-Known Member
    L.J.
    Mass
    2018 6MT Tacoma TRD Pro
    Speaking of lights. Does anyone know if the 2020's lights be easily interchangeable with the current halogen lights we all have?
  14. Aug 2, 2019 at 6:21 PM
    #154
    hawaii_dave
    2017 trd pro
    Yeah I like being able to add a destination while i'm moving.
  15. Sep 7, 2019 at 6:55 PM
    #155
    ZR NO
    ZR NO Well-Known Member
    Andy
    2019 TRD PRO - Super White
    So far just a bed mat and a lighter wallet
    I know its a bit of an old thread. I am new and reading through a lot of threads. What came with your lift kit to make a 3” lift. Is it just larger shackles in the rear. I saw the uca up front, did you put on new coil overs? Thanks
  16. Sep 7, 2019 at 7:19 PM
    #156
    hawaii_dave
    2017 trd pro
    I did not use a kit, I installed a 3" lift spacer in front kept the TRD fox shocks I did use total chaos uca because the stock arms would hit the springs on full drops. I installed bump stops from a 2019 chevy 4x4 (rear) cut them down to 2.5 inches tall. did a cab mount chop. I do get a very light rub on the pinch weld when I'm doing heavy off-roading ( top of the world, poison spider, hells revenge etc. ) In the rear I'm running a 2" block and u bolts (also from a chevy 1/2 ton ) along with a 1.5 add a leaf with fox 2.0 remote res shocks with 3-5" lift. I'm about to change the rear set up to heavy duty old man emu rear leafs my truck fully loaded with fuel, water, recovery, camping, tent, shower, etc was 6600lbs. I have a high clearance rear bumper with swing out on order so have to step up the springs and I'm looking at up grading the rear shocks to Tundra kings IMG_2486[1].jpg
    Impoy47 and Rockefelluh like this.
  17. Sep 8, 2019 at 10:02 AM
    #157
    ZR NO
    Andy
    Hey thanks for replying. I think I got confused because I didn’t see the spacer in the front suspension pics. Great looking truck. I know you worked a lot on keeping that stock pro look while adding a bunch of functionality. Those skids are really nice
  18. Sep 12, 2019 at 6:17 PM
    #158
    pete37
    pete37 Well-Known Member
    peter
    Toronto Canada
    2008 trd offroad aclb 2016 trd sport stolen 2019 TRDORSB
    my truck
    obpmem and PuyallupJon like this.
  19. Sep 17, 2019 at 9:35 PM
    #159
    TRDProOne
    TRDProOne Well-Known Member
    CA
    2019 TRD Pro in Super White
    I plan on having XPEL protective film and ceramic window tint installed next week to help protect my Pro. That’s all folks!
  20. Sep 18, 2019 at 11:58 AM
    #160
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Man good thing you're up in the PNW I thought you had that modded truck in Hawaii based on your user name. Would have been a shame because it would have looked great with limited options of where to utilize it.
