3rd Gen TRD Sport and Off-road Spring Differences?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by baltimorebirds2, May 28, 2022.
  1. May 28, 2022 at 1:40 PM
    baltimorebirds2
    baltimorebirds2 [OP] tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    Hey all, have a quick question for you guys.
    Here’s some background:
    I recently just put on a set of OME Nitrocharger Soft Valved struts and a pair of the nitrocharger rear shocks. The ride is still feeling a little too stiff for my liking, and I’m assuming it’s due to the fact that I have the factory 700-720ish pound springs on there.
    Anyway, I’m obviously trying to find a set of coil springs and maybe leaf springs which will give me the softer and more comfortable ride I am looking for compared to the stock Trd sport ride, but not so soft to the point where there is horrendous body roll (I understand there will be some). I wasn’t planning on lifting, but haven’t completely ruled it out. Just didn’t want to lift if I didn’t have a reason to, plus I didn’t want to change suspension geometry and have it be unreliable, as the truck is my daily driver after all. I am also at stock weight, I have no winch and no metal front bumper.
    Does anyone have any idea if the coil springs between the TRD Sport and the TRD Off-road are any different? I’m assuming the off road one has a lower spring rate to make the suspension more plush. If this is the case, I was thinking about finding a pair of springs, maybe used, or maybe I’ll just buy a pair new from my Toyota dealer. Would this be a decent solution?
    Also are the leaf springs any different between the sport and off-road? I’m not sure since I feel like they need to be stiff enough to carry a decent amount of weight in the bed, and swapping them for softer ones would probably compromise my payload and towing capacity as well. Any thoughts about this as well?
    I’m more concerned about the coil springs in the front for the time being.
    thanks in advance guys,
    Brooks
  2. May 28, 2022 at 1:58 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Coils and springs between the two are identical. Stock coils from my goofy fuzzy memory are only 600-ish pounds. When you say "factory springs," did you reuse the original springs, or dude you buy equivalent OME springs?
    There are two differences between Sport and OR's stock suspension:
    The Sport uses stiffer Hitachi shocks whereas the OR uses "softer" low end bilsteins.
    The OR has a thinner sway bar than the Sport.
    If you want more pliant handling, trade the shocks for 5100s. (Admittedly I have no experience with OME, but a number of reviews on here say that they're almost as stiff as the Hitachis.)
    stftaco and baltimorebirds2[OP] like this.
  3. May 28, 2022 at 2:25 PM
    baltimorebirds2
    Brooks
    Thanks for the info. I’ve heard mixed things about the spring-rate, some have said 600 something and there is a post on TW from toytec themselves saying they tested it and it came back at 720ish, which even sounds a bit high to me for a stock truck with stock weight. When I say I used factory springs, I mean I actually re used the factory springs, but I would love to find some OME equivalent ones with a lower spring rate, that would bring my front end no higher than an inch from what it is now. I’m just confused by which height and rate I would need to get to achieve this. I hear 5100s are great handling, but I heard they’re pretty stiff due to their digressive valving. That’s why I didn’t really consider them in the first place, because I’ve heard that they are valved stiffer since most people buy them to lift their trucks.
    Rock Lobster[QUOTED] likes this.
  4. May 28, 2022 at 3:02 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Yeah, that's where it gets screwy. Bilsteins have digressive valving (good for on-road, not as good off) but that doesn't tell the whole story. I have not seen a side by side comparison showing the dampening curves of each. And that's what would tell you which shock feels "stiffer." :annoyed:If only.
    I dunno. I'm in the same boat but for different reasons. I want a towing-friendly suspension so I settled on the 6112/5160 combo. They're supposed to be quite a bit stiffer than the 5100s. And it's true, they feel like the stock Hitachis on the compression stroke, but they have a much more controlled rebound. The 5100's according to reviews have a compression and rebound behavior that's on par with the stock OR suspension, so long as you don't muck it up by putting heavy springs or put the fronts on a uptravel-killing setting.
    But I feel you. It's tough to muddle through page after page of user experiences, trying to judge their base line of what "stiff" means to them, and how it compares to what they bought. It's kind of maddening.
  5. May 28, 2022 at 7:13 PM
    baltimorebirds2
    Brooks
    Yeah, it gets really weird. It’s almost as if you have to trust people’s subjective interpretations of stiffness, to make some sort of decision. Granted your interpretation and their interpretation are pretty different, and that’s what makes it tougher.
    I hear the same about bilsteins, that their stuff but supposedly handle rebound better. I hear that they suck with small bumps but start to smooth out at higher speeds, and they are affected more by larger bumps. OME is supposedly progressive, which means they respond better to small bumps.
    At this point, I’m debating either lifting a couple inches, which I really didn’t want to do in the first place, but am a little bit more open to it now, but still have reservations. It also seems like they don’t really make softer springs for my application either, so I feel like lifting might be my only option to get softer springs. Or I just sell the OME’s and get the OR bilsteins, even though they’re supposedly not that great, it would at least give somewhat of a better ride. I don’t know, what the hell lol… this kinda stuff can be fun, but a pain in the ass
  6. May 28, 2022 at 7:22 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The Off Road models get front springs P/N:
    48131-04A90
    48131-04B00
    The Non Off Road and Pro Models front springs P/N
    48131-04A80
    48131-04C00
  7. May 28, 2022 at 7:24 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Damn. I got schooled. I wonder what the load ratings are for the two sets.
  8. May 28, 2022 at 7:25 PM
    baltimorebirds2
    Brooks
    Thanks for that. So they must be different, I’m just wondering what the actual differences are, since most people on TW are saying that they’re the same across all models, when they’re clearly not…
    shakerhood[QUOTED] likes this.
  9. May 28, 2022 at 7:28 PM
    baltimorebirds2
    Brooks
    I mean you’re not the only one that’s thought that, most people on this forum seem to think the springs are the same throughout all models, when it cant be the case with different part numbers… IMO it didn’t make sense that the OR would be able to have such a plush ride with such stiff stock springs… I don’t think a shock could be that soft to compensate for a stiff spring to make for such a plush ride… I think there’s a lot of misconception on this forum.
  10. May 28, 2022 at 7:28 PM
    shakerhood
    Southern Ohio
    I just got curious reading this Thread and decided to check a Toyota part source, apparently they do have differences.
  11. May 28, 2022 at 7:31 PM
    baltimorebirds2
    Brooks
    That makes a lot more sense. Did they give spring rates, spring height, and other specs like that?
    I mean at this point do you think winging it and finding a pair of takeoff coils from an OR and throwing them on to see if there’s a difference would be worth it? If there a decent bit softer I feel like it may be worth it but still might be hit or miss…
  12. May 28, 2022 at 7:37 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  13. May 28, 2022 at 7:38 PM
    Bishop84
    Bishop84 Well-Known Member
    It will be softer, but not sure if its worth the time unless you get a brand new set. The damper makes the ride smoother moreso than the spring in this case.
    Switching to the 4600 shock (slightly bigger than the offroad shock) will yield similar if not better results.
  14. May 28, 2022 at 7:41 PM
    shakerhood
    Southern Ohio
    Sorry it didnt list any specs for them, just the different part numbers.
  15. Jun 1, 2022 at 10:26 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    It's damping. My offer still stands. Any shock sent to me will get dyno'd and shared and any spring will get rated.
    I'm about to pull off my stockers so I will rate and dyno those.
  16. Jun 2, 2022 at 5:13 AM
    gudujarlson
    Minnesota
    It would be super interesting to see dyno graphs of the various shocks on the market.
  17. Jun 2, 2022 at 6:12 AM
    coma toy
    coma toy Off Road Taco
    Get the 5100s. Bilstein recommends you keep the stock coils. No brainer.
    Much bigger & better than the stock OR Bilstein's, although I had no issue with the stock issue.
  18. Jun 2, 2022 at 4:45 PM
    ShimStack
    Ben
    NC
    I'm offering it.
  19. Jun 2, 2022 at 4:58 PM
    gudujarlson
    Minnesota
    I have 2020 OR coilovers in the garage i’d ship to you for dyno data. Have you nit already done this test though?
  20. Jun 2, 2022 at 5:08 PM
    ShimStack
    Ben
    NC
    I have my 2016 OR coilovers to do. That would be same trim 4 years apart. It would be a start on creating a database.
