3rd Gen TRD Sport - TRD 17Inch OEM Rims - Rubbing Issue
Discussion in 'Wheels & Tires' started by B-GR8FUL, Feb 1, 2024.
  1. Feb 1, 2024 at 9:51 AM
    B-GR8FUL
    B-GR8FUL [OP] New Member
    I have a 3rd gen TRD Sport and have made the following two modifications to my wheels.
    • 1 inch Rough Country Wheel Spacers
    • TRD PRO 17 Inch OEM Matte Black 6 Lug Rims (Tires are Firestone Destintation P265/65R17)
    Tires came stock and not changing them until they wear out but want to get something meaty!
    I would like to know if anyone has comments/suggestions on what I could do so i no longer have rubbing when i make a sharp turn or the suspension compresses.. This will likely get worse when i finally upgrade the tires in the not to distant future.
    Is a lift the only answer? Would a leveling kit work? All feedback is appreciated. Thanks
  2. Feb 1, 2024 at 10:36 AM
    Admiral Snackbar
    Admiral Snackbar Well-Known Member
    If you take off the spacers it won't rub.
    Canadian Caber, Discount Tire and 661 like this.
  3. Feb 1, 2024 at 11:08 AM
    Bishop84
    Bishop84 Well-Known Member
    High caster alignment will help, you ask the shop to max the rear eccentrics to get the wheel more forward.
    most of the time simply removing the front mud flaps is all that’s needed though
    DavesTaco68 likes this.
  4. Feb 1, 2024 at 11:23 AM
    B-GR8FUL
    no mud flaps.. not sure if its rubbing against the lower trim on the front of the bumper which i believe is specific to the sport models..
    I would also clarify, these are OEM Rims but i believe the off-set on TRD PRO rims is greater then the offset on the stock TRD rims the truck came with.
  5. Feb 3, 2024 at 6:54 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    You negated the positive offset when you added the 1” spacer. I believe the Pro offset is +4 . So with the added spacer the wheel is now -20 offset.
  6. Feb 11, 2024 at 3:04 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Remove the spacers……
