3rd gen tune up question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EatbyduedateTaco, Oct 28, 2021.
  1. Oct 28, 2021 at 3:50 PM
    EatbyduedateTaco
    EatbyduedateTaco [OP] Member
    2016 Tacoma trd sport 4x4 crew cab
    Hi there, just replaced plugs, air filter and cleaned throttle body at 115000. This was last week and engine seems to be running smoothly, yet my mpg seems to be 1 to 2 mpgs lower than before tune up. Any input would be greatly appreciated.
    2016 TRD sport 4x4 dcsb all stock.
    Oem plugs, Fram engine air filter.
    Do these trucks need throttle body to be reprogrammed? If I take it to the dealer I'm sure they'll charge an arm and a leg just to do that or diagnose.
    Thanks.
  2. Oct 28, 2021 at 3:54 PM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    pull your EFI fuse for 5 minutes to reset learned values.
  3. Oct 28, 2021 at 4:00 PM
    EatbyduedateTaco
    Thank for reply. Will try tomorrow and post results after a few miles.
  4. Oct 28, 2021 at 4:22 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    May need a few more than a few miles for things to get back to norm. :)
  5. Oct 28, 2021 at 4:51 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    That won't work.
    It needs to be reset in Techstream.
    Speedfreak likes this.
  6. Oct 28, 2021 at 5:16 PM
    EatbyduedateTaco
    How to go about resetting in techstream, through dealer or any shop. Thanks agaon
  7. Oct 28, 2021 at 5:16 PM
    EatbyduedateTaco
    Thanks again!
  8. Oct 28, 2021 at 5:50 PM
    splitbolt
    NW Arkansas
    Dealer or mechanic that can access it with a capable universal device/program.
    Menu access looks like...
    Powertrain / Engine and ECT / Utility / Learning Value Reset,
    Powertrain / Engine and ECT / Utility / Fuel Density Learning Value Reset,
    I'm inclined to believe you are experiencing winter gas woes.
    Where are you located? What was your fill schedule prior to replacement?
    Junkhead, Tacomaryan18 and Speedfreak like this.
  9. Oct 28, 2021 at 7:08 PM
    cryptolyme
    Virginia
    yea, it will work. you don't need techstream.
  10. Oct 28, 2021 at 7:27 PM
    splitbolt
    NW Arkansas
  11. Oct 28, 2021 at 7:31 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    gman2431 and SpyGoat like this.
  12. Oct 28, 2021 at 7:39 PM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    I second the opinion of winter gas woes. Mine dropped from 22mpg to about 20mpg in the last week. Average temp outside dropped 10-15 degrees also.
  13. Oct 28, 2021 at 9:32 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    As far as I know, no, or any other TOYOTA vehicle. The only thing I’m aware of is the injectors need to be checked and balanced if necessary with tech-stream if you replace any.
    Most likely it’s just a coincidence or chain of events. The weather is changing, fuel mixtures are re-formulated for temperature, and tires need their psi checked. My tire pressure has dropped, and my mpg have too.
    Moreover, it does not seem like you did anything wrong because if you had, chances are a little light on the dash would tell you so.
    Cheers!
  14. Oct 29, 2021 at 5:21 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Thanks for bringing the facts.
    :thumbsup:
  15. Oct 29, 2021 at 6:09 AM
    EatbyduedateTaco
    Forgot to mention, after finishing forgot to plug throttle body sensor back after finishing. Obviously underpowered and lit up like a Christmas tree. After checking and reconnecting tips to throttle body it drove normally and chk engine lights disappeared.
  16. Oct 29, 2021 at 6:19 AM
    EatbyduedateTaco
    But mpg has been 1 to 2 lower. FL truck, no winter gas woes.
    Valuable input from everyone
  17. Oct 29, 2021 at 6:29 AM
    EatbyduedateTaco
    Just spoke to a service representative and was told that numbers could be off bc of new parts replacement and it would reset itself. He said connecting truck to their system wouldn't do anything and close to $200.00 just for connect to it.
  18. Oct 29, 2021 at 6:35 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Pretty hard to tell 1-2 MPG is a pretty small percentage
  19. Oct 29, 2021 at 7:06 AM
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    Me as well went from 18.5 average to 16.3
  20. Oct 29, 2021 at 7:10 AM
    NorNev
    Dave
    A Few
    Did you clear the cel?
