3rd gen twin turbo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mdelg16, Mar 27, 2018.
  1. Apr 5, 2018 at 1:13 PM
    #101
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    I hear you, but they do mention it fits 2013-2017. Haven't followed up with them on the 16+ applications yet, but they do mention it on their site.
  2. Apr 5, 2018 at 2:17 PM
    #102
    ramirj2
    ramirj2 Active Member
    Jose
    2018 TRD OFF-ROAD 4x4
    What about the 2018 Lexus LS500?
    It is a 3.5L TT V6 but couldn't goggle any info on engine or code.
    "Lexus designed an all-new 3.5-liter V6 engine specifically for the new 2018 LS 500, using twin
    turbochargers developed through the company’s F1 technology".
    On the LS 500h the brochure points to the 2GR FKS
  3. Apr 6, 2018 at 10:31 AM
    #103
    OVTune
    OVTune Well-Known Member
    OVTune
    the LS500 3.5L shares some things, but majority of things are different, better / more complex designed than the FKS. Right now information is limited but I did get to inspect one up close. It has the same single port cylinder head, possible chance of the same flange type, which would mean OEM turbos would bolt to the tacoma engine.
    Wero94, 05Taco4x4, SContiVT and 2 others like this.
  4. Apr 6, 2018 at 10:41 AM
    #104
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    At this point, if you want more power and are set on keeping the truck you're best off dropping in an LS. You'll be so far down this rabbit hole for self discovered R&D and components it will be more economically feasible to outright buy a crate engine with a stand alone ECM. You'll get a far more capable engine with all the reliability of the stock unit. Unless you have a literal bucket of money and a great independent tuner shop that specializes in new Toyotas, I'd not even consider this, it's so far outside even the enthusiasts capability.
  5. Apr 6, 2018 at 12:51 PM
    #105
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    sure you can, just like you can turbo charge a turbo with a sport..in case of land speed records being broken..
  6. Apr 6, 2018 at 2:00 PM
    #106
    mauidogg
    mauidogg Well-Known Member
    16 DCSB TRDOR
    As far as the trans goes, I believe that it has been confirmed that it is the same trans used overseas mated to a V8 with more power than we would likely see with a mild boost turbo setup.
  7. Apr 6, 2018 at 2:29 PM
    #107
    yarberrymt
    yarberrymt Well-Known Member
    I think OP is an obvious troll, but if not, why on earth would you buy a 4,700 lb truck with a economy sedan motor stuffed in it in order to spend 10k more to add turbos???
    wrong platform to make fast IMO.
  8. Apr 6, 2018 at 3:31 PM
    #108
    mauidogg
    16 DCSB TRDOR
    Different strokes. Some like to be different. Some just think it’s cool. My buddy put a Mercedes diesel into a 1gen 4Runner. It was fantastic off road. He loved it. He grew out of the motor and swapped in a 1uz. Why did he do it? Because he could and he wanted to. Some would have said just swap an LS motor and be done...he didn’t want to. OP wants to twin turbo, ovtune has already brought up he is looking into that exact option. Why? Because some people would like it.
  9. Apr 6, 2018 at 4:04 PM
    #109
    ramirj2
    Jose
    Hell yes!
    I would sent $8,000 and boost it!
    I like to play with my toys. I like the sleeper factor.
    I own 2 boosted cars, do my own builds and race them.
    Warranty, what is that?
  10. Apr 9, 2018 at 5:40 PM
    #110
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    I like this guy! We think alike sir. I like the build aspect as much as I like driving around in a modded vehicle. Especially when you have mods that make the vehicle objectively better like turbos. Or chassis/suspension/brakes mods for more :burnrubber:
    ramirj2[QUOTED] likes this.
  11. Apr 9, 2018 at 5:53 PM
    #111
    Falconsfan
    Falconsfan Well-Known Member
    2017 sr dcsb v6 4x4 black
    Yes I have seen all the 3.5 internals thoroughly(I have worked in the 3.5 cam, crank, and connecting rod machining lines @tmmwv) the crank is forged steel the rods I'm not sure I think they are forged as well but I really don't know they come in as blanks from a supplier.
    yota243[QUOTED] likes this.
  12. Apr 9, 2018 at 5:57 PM
    #112
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
  13. Apr 9, 2018 at 6:01 PM
    #113
    stevotivo12
    Stephen
    any update on this project? I would be so down for a twin turbo taco when its available
  14. Apr 9, 2018 at 6:09 PM
    #114
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Why is the new 18 camry with the same motor making 301hp
  15. Apr 9, 2018 at 6:13 PM
    #115
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    TRD Pro tacoma $44k
    TRD Sport tundra crewmax $46k
    You want faster. Buy tundra.
  16. Apr 9, 2018 at 6:35 PM
    #116
    stevotivo12
    Stephen
    ehh I already OWN my tacoma though so its like 8K for turbos and other impending supporting mods im guessing, or 46k for a whole new truck. Id rather just make the taco faster and then watch people's faces when they see a flying taco
  17. Apr 9, 2018 at 6:47 PM
    #117
    xola3que
    xola3que Well-Known Member
    Long Valley, NJ
    2019 Tacoma Sport
    I would wait a little for those LS500 TT to hit the salvage yard in a couple years. By then you’re already out of warranty and payments. $2500 $3000 straight dropping engine comes with hpfp, intercooler and ecu . Sell your old engine back on cl to recoup. Solid
  18. Apr 9, 2018 at 8:04 PM
    #118
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I'd go LSx before all that mess.
    Lt. Dangle likes this.
  19. Apr 10, 2018 at 5:35 AM
    #119
    SContiVT
    SContiVT Back in a Toyota
    Central Vermont
    2010 Tundra Rk Wr/2023 WRX/2023 Ford Exp
    Seeing as the OP has abandoned the thread, I vote that @OVTune takes over this thread...lol
  20. Apr 10, 2018 at 10:51 AM
    #120
    OVTune
    OVTune
    Different tune. pretty much only difference
    bshammer0, dYL0n and xola3que like this.
