3rd gen twin turbo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mdelg16, Mar 27, 2018.
  1. Apr 10, 2018 at 11:12 AM
    #121
    xola3que
    xola3que Well-Known Member
    Long Valley, NJ
    2019 Tacoma Sport
    I'm gonna go test drive the 3.5L camry and swap out the ECU in the process...:D:devil:
  2. Apr 11, 2018 at 11:06 AM
    #122
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    There’s an older post @OVTune made. Basically the Camry 301 HP or whatever isn’t accurate
    Edit:
    Found it
    xola3que[QUOTED] and mZiggy like this.
  3. Apr 12, 2018 at 12:15 PM
    #123
    Argo98
    Argo98 Well-Known Member
    Argo
    2017 Toyota Tacoma TRD-Sport 4x4
    Rough Country 3" spacer lift w/ shocks 285 KO2's wrapped around 16' ProComp Series 7069 Misc. bibbidybob lights
  4. Apr 12, 2018 at 12:20 PM
    #124
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    So the only difference between the two engines is the compression ratio on the pistons (other than the obvious presence of two turbos)? Taco runs 12:1 and that Lex runs 10.48:1
    Argo98[QUOTED] likes this.
  5. Apr 12, 2018 at 12:22 PM
    #125
    Argo98
    Argo
    I guess so... Is the compression something that can be altered with a tune if we adopt the TT kit that Lexus might offer?
  6. Apr 12, 2018 at 12:25 PM
    #126
    stevotivo12
    Stephen
    Complicated question. With the tacos variable atkinson-otto cycle operation most likely there is a way to achieve that. Tune it so the engine runs halfway between both settings. In full Atkinson mode compression drops to like 8.6:1. However, usually that would be a swap for a different piston set. May still require that because it doesn't say if the Lexus has forged pistons. I know the taco has forged rods and crank but highly doubt that it has forged pistons which would be necessary to safely run boost.
    su.b.rat likes this.
  7. Apr 12, 2018 at 12:35 PM
    #127
    Argo98
    Argo
    So prolly better off doing a full engine swap instead?
    Wero94 likes this.
  8. Apr 12, 2018 at 12:45 PM
    #128
    ramirj2
    ramirj2 Active Member
    Jose
    2018 TRD OFF-ROAD 4x4
    Post in the previous page of this thread
    "the LS500 3.5L shares some things, but majority of things are different, better / more complex designed than the FKS. Right now information is limited but I did get to inspect one up close. It has the same single port cylinder head, possible chance of the same flange type, which would mean OEM turbos would bolt to the tacoma engine."
  9. Apr 12, 2018 at 12:53 PM
    #129
    ramirj2
    Jose
    I don't know.
    I would prefer the instant torque of a PD blower (Whipple, Eaton TVS (Magnuson) ect.... ) over turbos or centrifugal for the nature of a Truck
    If I have to swap it would be Coyote powered.
  10. Apr 12, 2018 at 12:56 PM
    #130
    stevotivo12
    Stephen
    Yeah I've been kicking around the idea of a 1JZ swap for plenty of power and reliability to match
  11. Apr 12, 2018 at 12:56 PM
    #131
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Properly sized ball bearing turbos would have no real noticable lag and be way more efficient and capable than any SC
    SContiVT, tonered and Double Phister like this.
  12. Apr 12, 2018 at 1:04 PM
    #132
    tacoking480
    tacoking480 Well-Known Member
    Daniel
    Gilbert,AZ
    2015 Tacoma double cab 4x4 off road
    3" toytec boss lift Icon upper control arms OME Dakar leaf springs Wheelers super bump stops 16x8 SCS F-5 wheels 3 1/2 offset 285-75-16 nitto trail grapplers Cab mount chop BPF grill 20" Baja Designs S8 Baja Designs squadron pair in fog light location. SPOD system Weather tech floor mats Pelfreybilt bolt on rock sliders with kick out. Pelfreybilt rear standard bumper Pelfreybilt front bumper Warn VR10S winch CBI bed rack SOS Front and mid skid plate Prinsu roof rack
    Just have someone make you a custom turbo kit, people do it everyday. Oh and if your interested in a magnuson supercharger, there is one for sale on the Arizona classifieds page.
  13. Apr 12, 2018 at 1:06 PM
    #133
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
  14. Apr 12, 2018 at 1:08 PM
    #134
    tacoking480
    Daniel
    Gilbert,AZ
  15. Apr 12, 2018 at 1:30 PM
    #135
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    For real! "You know what would solve my power problem? If I replaced the 260 horsepower, 3.5L V6 with a 25-year old, 2.5L STRAIGHT six that only made 160 horsepower!"
    Unless you meant the 1JZ-GTE, which has the extra benefit of being both 25 years old and famously being always broken
    CanadaToy[QUOTED] and APynckel like this.
  16. Apr 12, 2018 at 1:34 PM
    #136
    Dom Mazzetti
    Dom Mazzetti Well-Known Member
    Dom
    i don't understand why people are talking about swapping the new LS motor into these cars. Like anyone on here is really going to spend 10-20k buying this motor and swapping it in?
  17. Apr 12, 2018 at 1:34 PM
    #137
    STexaslovestacos
    Sam
    2017 MT TRD OR
    Jesus god this thread
    No. The compression ratio is defined by the pistons and the cylinder head design and they cannot be changed with a ECU reflash you have to take the engine apart and replace or modify either the pistons or the cylinder head
    LooneytuneSR5 and CanadaToy like this.
  18. Apr 12, 2018 at 1:36 PM
    #138
    STexaslovestacos
    Sam
    2017 MT TRD OR
    It is a law of all car forums that some people will discuss the practicalities of an LS swap. It doesn't matter what the car in question is.
  19. Apr 12, 2018 at 1:38 PM
    #139
    SContiVT
    SContiVT Back in a Toyota
    Central Vermont
    2010 Tundra Rk Wr/2023 WRX/2023 Ford Exp
    On the same page you glossed over to write this. Though not an actual change in compression, the Intake VVTiw and Exhaust VVTi of the 2GR-FKS allows for a wide range of simulated variable compression ratios, which is how the Simulated Atkinson Cycle portion of the engine works.
  20. Apr 12, 2018 at 1:39 PM
    #140
    SContiVT
    Central Vermont
    I was confused initially as well, but I believe they are saying a LS500 TT
