3rd gen upper control arm change
Discussion in 'Suspension' started by Hiluxski, Jun 13, 2017.
  1. Jun 13, 2017 at 10:01 PM
    Hiluxski
    Hiluxski [OP] Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    I have a 2017 Tacoma , want to install some light racing upper control arms. it was very easy on my 15 4runner bolt slid right out but on this Tacoma it looks like the fender is in the way. I've heard of people cutting the heads off or bending the fender. was thinking of maybe grinding the side of bolt flat. It seems so stupid Toyota with design it this way. Does anybody have any tips or suggestions for changing upper control arms . Thank you
  2. Jun 13, 2017 at 10:18 PM
    tcjacado
    tcjacado Well-Known Member
    Sliding the bolt out is a pita. I recommend you have 2 people. One loosening from the top and the other moving uca up and down to help take the load off it. Or you will need to grab the bolt with vice grips and have to hammer it out. I just helped a friend replace the bushings in his TC uca's
    GL
  3. Jun 13, 2017 at 10:30 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Cut the bolt head off with a body saw: The replacement bolt can be inserted from the rear.
    Mully, Hiluxski[OP] and tcjacado like this.
  4. Jun 13, 2017 at 10:38 PM
    Tombiology70
    Tombiology70 Well-Known Member
    San Diego
    2008 4Runner V8 Limited (Formerly 2017 Tacoma)
    Just did this last weekend but used a 4" angle grinder with a cutting wheel and took no time at all...
  5. Jun 14, 2017 at 12:31 AM
    Hiluxski
    Ventura California
    What did you grind ? Can you explain thanks
  6. Jun 14, 2017 at 12:37 AM
    tcjacado
    The head of the bolt. Either cut it off or grind it off if your confident that route wont hit anything else down there with the grinder. I would use a dremel withave cut off wheel. Small bosch sawzall or the harbor freight body tool posted above.
    Hiluxski[QUOTED][OP] likes this.
  7. Jun 14, 2017 at 1:50 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Like others said, cut the head off. I use a sawzall with a really short blade. Grab the threaded end with vice grips to keep it from spinning while you cut. Clean up all the metal chips so they don't rust on your frame.
    Mully, tcjacado and Hiluxski[OP] like this.
  8. Jun 14, 2017 at 12:18 PM
    Hiluxski
    Ventura California
    Thanks everyone, I have all those tools . might try the Dremel that sounds interesting but I have a sawsall have to get short blades and I'm not confident enough to put my 4" angle grinder in there lol
    Thanks agin everyone.
    tcjacado likes this.
  9. Jun 14, 2017 at 12:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    80+% of the Tacomas on the road will never have this touched in it's lifetime, so it doesn't matter service wise.
    Since it's assembled as a sub assembly, then mounted to a frame with no body on it, it's likely easier for the robots to manipulate that way.
    #robotsmatter #longliveassemblybots
    :D
    buckmaster243 and bullaculla like this.
  10. Jun 14, 2017 at 12:32 PM
    Hiluxski
    Ventura California
    That's interesting , so Toyotas view is that's a lifetime part. hmmmmm
    One things for sure you can't modify your truck without them knowing about it. Anyway you do that bolt they're going to know you were tampering with it
  11. Jun 14, 2017 at 12:40 PM
    Tombiology70
    San Diego
    Once you've got everything removed you'll be surprised how much space there is to work with. The passenger side was still a PITA to get the new bolt in...
  12. Jun 14, 2017 at 12:42 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Ive installed a bunch of UCA's I always just bend the fender a little with some channel locks. no big deal.
    YE2KA likes this.
  13. Jun 14, 2017 at 12:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    Aren't the joints replaceable w/o removal of the UCA?
    So the only reason to remove the mounting bolt would be to repair a bent unit or replace blown out bushings?
    Yes, bushings go bad, but how many actually get replaced by the DIY crowd, as a % of total repairs? I mean we're likely looking in the 150-200k mile range before problems present.
    I agree things like this are a pain in the pa-toot. But it's mostly the DIY crowd who ever figures that out. There has been many a part I've left off, relocated or modified to make future service work easy over the years.
    Flat rate guys in the shop have time allowance for the issue, so they don't care as much.
    Zacoma77 likes this.
  14. Jun 14, 2017 at 2:19 PM
    Hiluxski
    Ventura California
    No , that whole upper control arm is an assembly. I had a bad ball joint and they changed the whole arm. They won't even change just the dust boot they'll change the whole arm. So even a tech in a Toyota dealership if he did this , he would have to remove the fender or bend it. Just doesn't seem right
  15. Jun 14, 2017 at 2:25 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    i just bent the fender out of the way
    YE2KA and Mademan925 like this.
  16. Jun 14, 2017 at 2:29 PM
    bullaculla
    Da big big island!
    A lot of people say to bend it, and I'm not sure how much is in the way on the third gens, but when I did my UCAs, my truck was pretty much brand new, so I cut the bolt. New bolt is like $12 from the dealership. Kinda surprised.
    On my wife's 2016 4Runner, no need to cut or bend. Slides right out.
    Hiluxski[OP] likes this.
  17. Jun 14, 2017 at 2:32 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Would you guys recommend some blue loctite on the new bolt since it's installed with gravity working against it? I probably would just to be safe.
  18. Jun 14, 2017 at 2:40 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    For all you guys who eventually plan to wheel semi hard. Do not bend the sheet metal. The wheel well/ radiator support entire front end is very soft metal and can eventually start to tear over time in the area where you initially bent as you have weakend the metal when you do so.
  19. Jun 14, 2017 at 4:12 PM
    Hiluxski
    Ventura California
    That's a great point!, Also I don't like the idea of bending the fender because then the dealer or Toyota knows for sure you tampered with the suspension. I'm sure they would also be able to tell with the bolt being in backwards but? Toyota really messed up Tacoma , on my 4runner it was so slick with the engineering it slid right out between everything.
    I can't imagine what a dealer might do if they remove the fender that'll never be the same. how weird and stupid of Toyota
    12TRDTacoma[QUOTED] likes this.
  20. Jun 14, 2017 at 6:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Being that the 2nd and 3rd gen share a lot of the same characteristics and even frame I actually put my bolt back in the same way it came out when I did my arms. It wasn't too bad but I do regret bending the inner fender metal. It is tearing in that spot now but I have not been nice to my truck I. The years that AI have owned it.
