3rd gen v6 start/idle query
Discussion in '3rd Gen. Tacomas (2016-2023)' started by toystory, Jan 22, 2020.
  1. Jan 22, 2020 at 4:25 PM
    toystory
    toystory [OP] Active Member
    RB
    2014 reg cab 4cyl.
    3" fox 2.0 shox, SPC uca's, 3" expedition leaf, Walker Evans wheels, ARE topper
    looking for some insight...
    my 2019 trd o.r. when new, had what I thought was a super high idle after starting the truck. dealer did some diagnostic work, afterwards, seemed to lower the idle. ever since though, the truck seems to gasp when starting, especially in the cold. also have what seems like an imbalance in the fan or something, as the truck has a constant resonance/droning sound from 25-50 m.p.h.
    any thoughts before I take it to the dealer for another diagnosis?
    thanks.
  2. Jan 22, 2020 at 4:42 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    High idle on startup and while sitting is normal. What RPMs were you at? I’m not sure about the droning. You may need a video.
    BSFord likes this.
  3. Jan 22, 2020 at 4:47 PM
    Mopar Mussel
    Mopar Mussel Well-Known Member
    Jurgis
    2018 TRD Sport, 2006 SAAB 9-5 Aero
    The high idle is normal, mine does it too. Not sure about the droning though.
  4. Jan 22, 2020 at 4:52 PM
    ryan760
    ryan760 Well-Known Member
    Can you define "high idle"?
    With respect to the sounds, I think you are being overly sensitive. It's a complex modern engine and does tend to make a lot of unique noises. What you're probably hearing is the cleaning cycle. It does sound a little disconcerting if you don't know what it is.
    GreyBaldTaco likes this.
  5. Jan 22, 2020 at 4:53 PM
    toystory
    RB
    2014 reg cab 4cyl.
    kinda familiar with the initial startup idle being high-ish, but all my previous trucks would settle down after 20-30 seconds...this one stayed a level that I had to make sure I was heavy on the brake before shifting into reverse to back out of garage...can't recall the rpm number at that time, had the adjustment made last March...but since, has seemed lethargic, haven't made note of where rpms have been lately, mild spring temps last year, this is the 1st winter for it, and it's struggling on starts.
  6. Jan 22, 2020 at 4:54 PM
    JoeCOVA
    Joe
    Colorado Springs
    I'd start gathering some metrics so you can compare. RPMs, how long they stayed, what did it drop to, what temp etc
  7. Jan 22, 2020 at 4:58 PM
    toystory
    RB
    2014 reg cab 4cyl.
    I am extremely OCD, maybe am just getting use to the 3rd gen nuances....
    JoeCOVA likes this.
  8. Jan 22, 2020 at 5:00 PM
    toystory
    RB
    2014 reg cab 4cyl.
    I'll collect some actual data...
    thanks gentlemen.
    JoeCOVA likes this.
  9. Jan 22, 2020 at 5:02 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    There is a reset relearn procedure for idle...on warm engine shut off all accessories then key on, key off, key on, start, apply brake put vehicle in drive for 2- 3 minutes back into park key off all done.
    MOC221_ likes this.
  10. Jan 22, 2020 at 5:04 PM
    toystory
    RB
    2014 reg cab 4cyl.
    roger that, will give a try...appreciate your time
  11. Jan 22, 2020 at 5:05 PM
    toystory
    RB
    2014 reg cab 4cyl.
    wait, same procedure for keyless push start?
  12. Jan 22, 2020 at 5:22 PM
    OregontoBajaCA
    OregontoBajaCA Well-Known Member
    2017DCLBOR
    Do you have a 3 inch lift?
    Could it be your needle bearing failing, causing the constant resonance/droning? Does it go away if you shift into 4wd?
  13. Jan 22, 2020 at 5:26 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    :cookiemonster:
  14. Jan 22, 2020 at 5:28 PM
    toystory
    RB
    2014 reg cab 4cyl.
    it is lifted 3", however, only about 5000 miles on it since lift, I'm at 9800 miles total...
    you think they could burn up that quick?
  15. Jan 22, 2020 at 5:31 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    I have a 2019 and when it’s cold, say 32 and below, it will idle at about 1300 rpm for a good while and eventually fall to below 1,000. Doesn’t shift hard into gear after warming up a little either. Personally the higher idle never bothered me and seems normal.
    na8rboy likes this.
  16. Jan 22, 2020 at 5:33 PM
    toystory
    RB
    2014 reg cab 4cyl.
    "cool" thanks...I guess I'll just see if the dealer can put ecu back to original setting, see if that puts it all straight.
  17. Jan 23, 2020 at 10:11 AM
    toystory
    RB
    2014 reg cab 4cyl.
    just learned toyota issued recall notice for low pressure fuel pump on '18-'19 tacomas (in addition to many other models) indicating symptoms I've been experiencing...
    laboured start: fuel starved, possible rough running sounds from engine.
