3rd Gen vs 4th Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by willconltd, Apr 24, 2021.
  1. Apr 24, 2021 at 9:32 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    I will be still driving my 3rd gen if it lets me . I purchased my truck not leased it . I can only image the prices are going to get more stupid.
  2. Apr 24, 2021 at 9:34 AM
    Crobran
    Crobran Well-Known Member
    Texas
    `21 DCSB 2.7L Silver Sky
    Trifecta 2.0, Ionic Nerf Bars, Tailgate anti theft device from @christian06, Husky Weatherbeaters, Bed lights, OEM bed mat, Derped badges and grille bezel
    Exactly, and I got a Tacoma because they're rumored to go 400-500K miles or more if taken care of. I fully plan on making that happen.
    JWILL10, grogorat and Junkhead like this.
  3. Apr 24, 2021 at 9:36 AM
    12 TRD OffRoad
    12 TRD OffRoad Well-Known Member
    Robert
    South Carolina
    2018 Tacoma SR 4x4 utility package
    The absolute earliest we will hear much or even see anything about a 4th gen would be in 2024 I would bet. They’ll run the update they did in 2020 for about 4 years. They did the same thing in 2012-2015.
    BSFord likes this.
  4. Apr 24, 2021 at 9:42 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I'm gonna drive this until Toyota makes my electric one. Hopefully
    200-300k would be a little more realistic.
    jsi and Kahpo like this.
  5. Apr 24, 2021 at 9:42 AM
    GrievousAngel
    GrievousAngel Well-Known Member
    2019 Tacoma SR 4x4 V6 DCSB Super White
    I see you drive a 21. What's the longest you've kept a vehicle? A lot of people say they're going to "drive it until the wheels fall off." Very few of them do.
    I'm guilty, too.
    I think it's going to be the transmission that limits the life of the 3rd gen. It's shit. And Toyota doesn't offer a manual in reasonable enough numbers/trims to compensate for it. And at some point when it goes out it won't be worth repairing.
  6. Apr 24, 2021 at 9:45 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Other than shifting like it's supposed to... what makes it shit? I've yet to hear of a transmission failure on these trucks.
  7. Apr 24, 2021 at 9:50 AM
    4×4×4
    4×4×4 Well-Known Member
    I can't wait for the gen 4, because then a lot of the idiots in the 3rd gen section will trade up for the new new and get outa here :p
    tonered, 44-16 Taco, DanoTay and 3 others like this.
  8. Apr 24, 2021 at 9:50 AM
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    1st gen was 95 to 2004 2nd gen was 2005-2015
    davidstacoma and kyledamon like this.
  9. Apr 24, 2021 at 9:53 AM
    Crobran
    Texas
    We've still got our `97 Civic that we bought brand new. Other than having to install a new compressor it's still running great, though I do have a power steering pump out in the garage waiting for me to install it.
    I hope you're wrong but I fear you might be right. I totally would have got a manual if it was available in my SR5 trim.
  10. Apr 24, 2021 at 9:53 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Um, no. For the body, the only change was sheet metal. For the inside, no dimensions changed, only surfaces. Wheelbase length and width the same. Engine changed, driveline didn't. @Jeff Lange is correct, the changes are mostly cosmetic with a different engine.
    MR E30, tonered and Jeff Lange like this.
  11. Apr 24, 2021 at 2:47 PM
    old_and_in_the_way
    old_and_in_the_way Well-Known Member
    Somewhere hot, flat and brown.
    Agree completely. It was essentially a new coat of paint. Effectively no new engineering or tooling. They "changed" the engine, but it is far from "new".
    Jeff Lange likes this.
  12. Apr 24, 2021 at 4:33 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I mean, I'm not just making stuff up. It's a slightly updated version of the same cab - with the same fender aprons, rad support, same floor, same roof - and not even all of the exterior body panels are new (the rear doors are the exact same part number in fact), same box with new outer panels, reinforced version of the same frame, same suspension, same rear interior trim panels, same pedals, same front diff, same front axles, same knuckles, same tie rods, same steering, same hubs, same wheel bearings, same brakes. They kept the same overall dimensions (and not just major things like the wheelbase either, I mean like the measurement from this bolt hole to that bolt hole down to the tenth of a mm). The 2.7L engine is mostly unchanged, as is the 5-speed manual transmission, it even uses the exact same exhaust, front to back. They didn't even change the chassis code, TRN245/TRN265. Internal documents from the time referred to it as an MMC, or mid model change, and not a FMC, or full model change.
    Essentially, they took the existing Tacoma and updated the sheet metal and lighting, as well as the interior forward of the B-pillar, then swapped out the engine, transmission, and rear axle for newer equipment, and mounted it onto the same frame with some stronger steel and bracing. It is exactly what Toyota did for the Tundra in 2014 with the exception of the powertrain updates.
    Typically when there is a new generation of a vehicle, I wouldn't expect to be able to grab doors, a roof rack, window glass, interior trim panels, suspension, brakes, etc. from the last generation.
    It's not just a typical mid model change either, it was pretty extensive. Similar to the 2014 Tundra I mentioned, the 2013 Avalon, 2015 Camry, and the 2013 LS and 2021 IS on the Lexus side.
    In Toyota land, if you're using the same chassis code and can swap stuff like glass and body panels, you're probably not dealing with a new generation. You can argue consumer and marketing definitions all you want, but it's just how it is, and it's not like I have no experience in the area either.
    Jeff
  13. Apr 24, 2021 at 5:06 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    I heard the next get you can pick between free oils changes for the first 2 years or free strippers and cocaine for the first 6 months.
    tonered, Junkhead, Bronxguy and 2 others like this.
  14. Apr 24, 2021 at 5:07 PM
    old_and_in_the_way
    I'll take hookers 'n blow for $400 please, Alex.
  15. Apr 24, 2021 at 5:15 PM
    #35
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    4th gen may be an underpowered whale because it will share its platform with the Tundra (which is why the next-gen Tundra has tiny tires on 6-lug wheels).
    shakerhood likes this.
  16. Apr 24, 2021 at 5:16 PM
    #36
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    Dont expect to see a 4th gen until atleast 25’ 26’. They are going to use this brand new engine for as long as they can.
  17. Apr 24, 2021 at 5:18 PM
    #37
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    But the second option requires the optional towing pkg:
  18. Apr 24, 2021 at 5:23 PM
    #38
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    Like you guys, I feel like we only have 12 years before this planet explodes from fracking done by the USA. Wait what were we talking about? Let's take off our tin foil hats and get back to reality.
    There has been none. The power of the Farce is strong in this thread. Opining on non existent generations yet to come, false comments on transmissions.
  19. Apr 24, 2021 at 5:24 PM
    #39
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Will we be sad, and jealous of the new gen like the 2nd gen guys are?
    tonered and 4×4×4 like this.
  20. Apr 24, 2021 at 7:19 PM
    #40
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Evening all,
    I have seen a bit of info here and there about the upcoming ‘24. Nothing definitive.
    I just got my ‘21 last November. I leased it cheap as a second car. I fell in love with it and am now going to refi it since I already modded the heck out of it. It only has 900 miles so far.
    https://youtu.be/v21jck-NpgQ
    Heads up, it is the predator with the TRD pro with 265/70R16. I am swapping next weekend for a new set up with 285’s and will be selling the TRD set with 900 miles as is ready to bolt on if any one interested in NC, Charlotte area. Pics in my build thread.
