3rd Gen water leaking into cab
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kpage6702, Feb 13, 2021.
  1. Feb 13, 2021 at 9:47 AM
    Kpage6702
    Kpage6702 [OP] Member
    Kyle
    2016 Metallic Gray Tacoma TRD Off- Road Access Cab
    Hi
    I have been having issues with my Tacoma. Water seems to be leaking into the cab of my truck. The water ends up pooling on the floor mats. I also check the fuse box under the drivers side and it’s all wet which is concerning. Any advice?
  2. Feb 13, 2021 at 9:49 AM
    Timetraveler66
    Timetraveler66 Well-Known Member
    3rd brake light leaking. Common problem with 2016
    Shellshock and hiPSI like this.
  3. Feb 13, 2021 at 9:50 AM
    Kpage6702
    Kyle
    What’s and where is the 3rd brake light?
  4. Feb 13, 2021 at 9:51 AM
    Timetraveler66
    Up on the back of the roof above rear window
  5. Feb 13, 2021 at 9:52 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  6. Feb 13, 2021 at 10:19 AM
    Kpage6702
    Kyle
    Ok but could the water travel all the way under the dash from the 3rd brake light?
    Skydvrr likes this.
  7. Feb 13, 2021 at 10:20 AM
    Shellshock
    Iowa
    Yeah cuz it’ll get into headliner and run everywhere
  8. Feb 13, 2021 at 10:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Both floor mats?
    Is the AC filter wet?
    Sounds like a windshield or cowl leak to me.
    Pitch black night. Assistant under hood with uber bright light. You under dash looking for said light. That's where the leak is.
  9. Feb 13, 2021 at 10:32 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Windshield maybe?
    shakerhood likes this.
  10. Feb 13, 2021 at 10:38 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Roof Rack, sunroof?
  11. Feb 13, 2021 at 10:41 AM
    Hooper89
    his says access cab so no sun roof or rack i dont think
    shakerhood[QUOTED] likes this.
  12. Feb 13, 2021 at 11:07 AM
    Kpage6702
    Kyle
    No sun roof or roof rack
  13. Feb 13, 2021 at 11:07 AM
    Kpage6702
    Kyle
    How would I test to make sure it would be a leaky 3rd brake light?
  14. Feb 13, 2021 at 11:34 AM
    Timetraveler66
    A hose
  15. Feb 13, 2021 at 11:36 AM
    Timetraveler66
    Remove the mats. Get in the truck. Have someone hit the brake light with a hose. If you see nothing coming in move to the windshield. And so on. Do it in one of the bays at the car wash. Use the high pressure wand on rinse position.
    Hooper89 likes this.
  16. Feb 13, 2021 at 11:38 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Did you have the window defroster set to the on position with truck off . Common problem with moisture leaking in.
  17. Feb 13, 2021 at 11:39 AM
    Timetraveler66
    Water can travel in the craziest ways. It trickle runs down different paths. Makes it hard to trace. But if you take your time. 2 people and a hose you can find it. The 3rd brake light is notorious on the 16s for leaks. Look at the headliner up in that area for a slight stain. Hard to see on grey but in the right light or taking pictures with your phone you should see it if it's there.
  18. Feb 13, 2021 at 1:22 PM
    hrivera007
    hrivera007 Well-Known Member
    2017 Off Road Auto
    Mine was doing the same after I installed a light bar. Somehow water got into the harness all the way from front bumper and it would leak into the cab by the break pedal.
  19. Feb 13, 2021 at 4:59 PM
    RYNO16
    RYNO16 Member
    2016 tacoma TRD Sport
    Prinsu design studios cab rack with 40 inch light bar.
    Its definitely the 3rd brake light. I installed my prinsu roof rack at the same time my brake light decided to start leaking. I for sure thought I didn't put enough silicone in the factory holes when I bolted on the rack. I pulled my hair out trying to find the leak thinking it was the roof rack. Turns out it was the brake light.
