3rd Gen Wheels on 2nd Gen 245/75-16 to a 265/70-18
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bswtnss, May 18, 2025.
  1. May 18, 2025 at 2:44 PM
    bswtnss
    bswtnss [OP] New Member
    B
    2015 Toyota Tacoma V6 4x4
    Hi Friends!
    I currently have a 2015 Toyota Tacoma V6 4x4 Manual with factory wheels and 245/75-16 tires.
    I just want to make sure I'm not missing something, but I can swap to 3rd generation wheels with 265/70-18 tires, correct? Some adjustments to speedometer will be necessary, but otherwise should be ok?
    Apologies as this is my first post and I'm a touch anxious about the whole thing, but really love the look of these black wheels to go with my black tacoma and the price is right, plus I need new tires anyway.
    Any insight would be greatly appreciated. Thanks y'all.
    -b
  2. May 18, 2025 at 4:19 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Is 265/70/18 a factory size on 3rd gens? That's a 2" taller tire than factory and it MIGHT cause issues. I use 265/75/16's which are 1" taller and 3/4" wider than what you have. A 265/65/18 would have exactly the same overall dimensions as my 265/75/16's. That is usually considered as big as you can go with no modifications to the truck.
    Use this link to experiment with various tire sizes in comparison to factory. It will also show you how much your speedometer will be off. Unless you're going HUGE on tires I wouldn't worry about the small speedometer difference. You're only talking about 3-5 mph off at 70. Only 1-2 mph at 55.
  3. May 18, 2025 at 4:47 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Tacoma Limited came with 265/70/18 as the stock size. That's a 32.6" tire. I didn't see the offset, but I'd bet they would work.
