3rd Gen White Tacomas - Post them up!
Discussion in '3rd Gen. Tacomas (2016+)' started by Dean724, Sep 30, 2015.
  1. Feb 12, 2019 at 11:14 AM
    #5781
    greg8765
    greg8765 Well-Known Member
    Greg
    Utah
    2016 Magnetic Grey Tacoma Sport DCSB
    Custom Grille, Tint, Pop & Lock, Nitto Terra Grapplers, 1 Inch Toytec Spacer on Front, Door Sill Decals, Tailgate Insert Decals, Tonneau Cover
    she's purdy
    Blucuss likes this.
  2. Feb 12, 2019 at 11:35 AM
    #5782
    St.Germain
    St.Germain 5° caster
    would a clay bar treatment work for that? maybe kinda tough cus of the texture..
  3. Feb 12, 2019 at 1:41 PM
    #5783
    xenonsupra
    xenonsupra Well-Known Member
    Joe
    San Diego
    2019 White Pro MT, 1994 Supra TT 6spd
    claybar isn't going to remove the textured surface, but you can clay that area if you're just trying to decontaminate it.
  4. Feb 12, 2019 at 1:42 PM
    #5784
    sethwerks
    sethwerks Member
    Seth
    Elgin, IL
    2016 TRD Off Road Access Cab
    Thanks, yeah just wondering about cleaning up the discoloration.
  5. Feb 12, 2019 at 1:47 PM
    #5785
    xenonsupra
    Joe
    San Diego
    i just clayed my car before putting on a ceramic coating. I used the optimum brand clay with ONR as a lubricant. Worked great.
  6. Feb 12, 2019 at 2:15 PM
    #5786
    St.Germain
    i was referring to the yellowing, not the orange peel texture.
  7. Feb 14, 2019 at 1:07 AM
    #5787
    JohnnyReb
    JohnnyReb Well-Known Member
    Johnny
    Washington
    2018 Tacoma SR5 4x4 dc/sb
    Traded my 2016 Tacoma for my winter white 2018 SR5 DC/SB 4x4 Hoping to do a level kit and new tires and wheels this spring. This is the only photo I have.
  8. Feb 14, 2019 at 1:21 AM
    #5788
    JohnnyReb
    Johnny
    Washington
    @sethwerks If I may, If you look close again at the yellowing along the bottom of the doors ( rocker panel ) there may be a thin plastic strip covering that area. If so that’s what may be yellowing. Should find the same on the bed behind the wheel. Hope this helps
  9. Feb 14, 2019 at 8:08 AM
    #5789
    CLC828
    CLC828 Active Member
  10. Feb 14, 2019 at 2:57 PM
    #5790
    12backvader
    12backvader Well-Known Member
    Houston
    2017 TACOMA TRD OFF-ROAD DCSB
    XD 820 grenades, 285/55r20 Toyo Open Country, leveled, dB customs grille, lightbar, predator steps, OEM tonneau
    I have this discoloring on mine it won’t wash off and I tried clay bar and that doesn’t work either. I did try low spirit mineral oil in a small test section and it did take it off. When I get time I’ll clean it all off clay bar/wax.
    SilverII likes this.
  11. Feb 14, 2019 at 4:36 PM
    #5791
    Taco0331
    Taco0331 Active Member
    AZ
    Cement 2019 TRD OR
    The pros just look so clean. I might have get one next year haha. Where did you get that hood with the black scoop on it??
  12. Feb 14, 2019 at 4:48 PM
    #5792
    xenonsupra
    Joe
    San Diego
    Thanks, It's the factory hood. From what I can see on google images all white pros have it.
  13. Feb 14, 2019 at 5:25 PM
    #5793
    Ligerzero
    Ligerzero New Member
    Javis
    White 2019 Tacoma TRD Off-Road
    My 2019 TRD O/R. Taking time to upgrade!
    SilverII, Flatout110 and bmmjr like this.
  14. Feb 14, 2019 at 6:46 PM
    #5794
    AZn8v
    AZn8v Active Member
    03 TRD OFF-ROAD-----2019 TRD OFF-ROAD
    2016 TRD SPORT 4x4
    RavsTacoma19, Gear, SilverII and 4 others like this.
  15. Feb 14, 2019 at 6:47 PM
    #5795
    Taco0331
    AZ
    Cement 2019 TRD OR
    Looks really good. Nice truck
    xenonsupra likes this.
  16. Feb 14, 2019 at 9:00 PM
    #5796
    JohnnyReb
    Johnny
    Washington
    Nice looking truck, you running a lift? Can I ask what tire and wheel set up you got? I’m trying to deside on bfg’s. Also is that Nfab steps 3in gloss or Texture ?
    Thanks Good looking truck.
  17. Feb 15, 2019 at 6:04 AM
    #5797
    CLC828
    Thanks.
    Yes It's got the readylift 2"/3" leveling kit.
    Wheels are Pro-comp 40 series, 17x9 -6et
    (only about 7/8" clearance on upper A-arm, so if you ever do any real off-roading and air the tires down, it'd rub for sure)
    Tires are 285/70/17 Falken ATW3's
    Part number on the nerf bars is #T1678CC-TX
    Disclaimer, the readylift isn't terrible, but it definitely ain't comfy compared to stock.
    Looking at a real setup currently.
    Connaghan likes this.
  18. Feb 15, 2019 at 7:55 AM
    #5798
    FLA_Hoosier
    FLA_Hoosier Well-Known Member
    Rick
    Space Coast
    2017 White TRD AC
    Here is a pic of mine. Just bought this truck on Tuesday and my plan is to remove and replace the film. Door edge guards look the same. It's just dirt and crud that has gotten under the edge of the film.
    SilverII and 12backvader like this.
  19. Feb 15, 2019 at 8:52 AM
    #5799
    Arcadebrothers
    Arcadebrothers Member
    Mark
    2018 White TRD Off-road
    HiKari LED fogs, Front tint, Plate LEDS, predator bars, bed mat.
    I have used 3M adhesive remover in the past to get tar, line paint and other nasty things that a clay bar would not take off.
    https://www.amazon.com/3M-General-P...550249504&sr=8-5&keywords=3m+adhesive+remover
  20. Feb 15, 2019 at 2:09 PM
    #5800
    ARTST1K
    ARTST1K Member
    Scott
    2018 TRD Sport
