3rd Gen White Tacomas - Post them up!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dean724, Sep 30, 2015.
  1. Apr 28, 2021 at 6:45 AM
    #8681
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
  2. Apr 28, 2021 at 3:43 PM
    #8682
    pescadoman66
    pescadoman66 Pescadoman66
    CJ
    Livermore, CA
    2017 TRD OR 4X4 Pro Wannabee Stormtrooper
    Tacoma Pro Front Grille Tailgate Letters Console Organizer Clazzio Seat Covers TRD front Grille Emblem Westin Drop Steps Front Widow Tint Tow Strap LED lights Sunshade Prinsu Rack BackFlip Cover rack accessories crutchfield speakers Front Tweeter speakers Tuffy box sound deadening mat Westin LED light bar Led switch Light bar bracket TRD Pro Tail lights TRD Pro Wheels BF Goodrich KO2 tires from America's Tire Old Man Emu Lift Coils - Coil Selection: 2887 Bilstein 5160 Rear Shock with Reservoir Bilstein 5100 Adjustable Front Struts HeadStrong 3 leaf progressive Add-a-leafs JBA UCA's Low Range OFF-Road 1.25" Cast aluminum blocks in the rear
    AND YOU LIKE THROWING MONEY AWAY WHY? :facepalm:
  3. Apr 28, 2021 at 4:26 PM
    #8683
    pescadoman66
    CJ
    Livermore, CA
    Any rubbing on those tires yet?
  4. Apr 28, 2021 at 4:28 PM
    #8684
    pescadoman66
    CJ
    Livermore, CA
    Are you sure those aren't 16" rims not 17 as you say 285/70/17 Those look like 16" rims.
  5. Apr 28, 2021 at 4:34 PM
    #8685
    pescadoman66
    CJ
    Livermore, CA
    NICE Truck!
    21taco.or[QUOTED] likes this.
  6. Apr 28, 2021 at 5:59 PM
    #8686
    21taco.or
    21taco.or Well-Known Member
    2021 Super White Tacoma OR
    71tattooguy, vivid02, ETBA and 2 others like this.
  7. Apr 28, 2021 at 6:34 PM
    #8687
    Mblev2
    Mblev2 Member
    Michigan
    Sure enough. They are truly 17” rims with 285/70 tires. Those giant tires just make the rim look smaller.
  8. Apr 28, 2021 at 7:14 PM
    #8688
    irANTHONY
    irANTHONY Well-Known Member
  9. Apr 28, 2021 at 7:55 PM
    #8689
    Rook82
    Rook82 Member
    Mark
    2020 TRD PRO
    2020 TRD PRO. 2 inch lift front and 1.5 back. SPC Upper control arms (waiting t install). 285/75-16 Yokohama MTG on 16/8 Method MR 305 wheels. Love this truck
  10. Apr 28, 2021 at 10:56 PM
    #8690
    RobertOchoa3
    RobertOchoa3 Active Member
    2018 White Tacoma TRD
    Here’s mines
  11. Apr 29, 2021 at 5:02 AM
    #8691
    Sleeperram
    Sleeperram Member
    2020 OR DC/LB
    Leer 100XR, Elka 2.0 w/Deaver Stage II, ECGS 5.29s, KDMAX 10, 275/70-17 BFG K02
    Very minimal on the front mud flap prior to alignment and under perfect conditions (hard compression in a turn). I refuse to remove the mud flaps, so I did a little bit of heat gun remolding. Since the alignment (and remolding) I haven't noticed any rubbing, but then again it's mainly a pavement princess.
    pescadoman66[QUOTED] likes this.
  12. Apr 29, 2021 at 8:18 AM
    #8692
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    Because I'm an idiot... I won't even try to justify it :rofl:
    Krocku81 and 4x4Taco2012 like this.
  13. Apr 29, 2021 at 12:31 PM
    #8693
    Bob1971
    Bob1971 Well-Known Member
    Tim
    KY
    White 2020 Trd OR
    Bed cover, step bars, SCS SR8 wheels
    Which lift is on her? Good looking truck.
  14. Apr 29, 2021 at 5:00 PM
    #8694
    Stuck Sucks
    Stuck Sucks Aerodynamic styling with functional design
    Jim
    Pacific Plate
    Matomi Wash, Baja California
  15. Apr 29, 2021 at 7:22 PM
    #8695
    Rook82
    Rook82 Member
    Mark
    2020 TRD PRO
    It is just a cheap Rough Country spacer lift up front (the type that goes above the coilover). And Icon 3 leaf add a leaf in the rear. I wanted to keep the stock shocks. Maybe at some point I will do a coilover setup in the front. But this setup seems to work and ride and all very well. I know it is often frowned upon. But in my experience so far, it works great. Take it as you will as I do not bash it off road. It is too new and expensive. But for what "I" need, it is perfect. I would have liked more lift in the back. As it is almost Bro like and seems nose high. I may do a Deaver spring set in the back at some point. I am trying to decide between a truck cap or box or even a rack in the back. And I want to decide that before I decide on what I need to change spring wise. For now the truck rides and drives amazing. No rubbing anywhere at all with the tires which measure over 33 inches (they did rub body mounts in front before lift). I am sure they probably will offroad flexed out. But I pushed the castor cams forward when I installed the lift which helped. It is a second vehicle for me so it doesn't get daily driven. I am happy with it.
    vivid02 likes this.
  16. Apr 30, 2021 at 5:31 AM
    #8696
    Bob1971
    Tim
    KY
    White 2020 Trd OR
    Well you sound like me. I don’t want to take mine off-road like a lot the guys on here. I just like the look of bigger tires and lift. Yesterday I delivered a package that fedex mistakenly left on my porch. It was a rural road that turned into a muddy road. It was the worse road my truck had been on. I honestly could’ve driven my wife’s Camry on it. But it was quite muddy and now my truck is.
    So the ride quality didn’t suffer that much with the lift? I would like about 2” up front and enough out back to make it level or a little high.
  17. Apr 30, 2021 at 6:45 AM
    #8697
    Coacht
    Coacht New Member
    T
    NoCo
    2021 White TRD Sport
  18. Apr 30, 2021 at 5:38 PM
    #8698
    Rook82
    Rook82 Member
    Mark
    2020 TRD PRO
    It actually rides amazing. I think the rear feel actually improved. The front is the same as nothing much changed there. If there is any change in ride or drive, it is mostly unnoticeable. I think the most noticeable change overall was the extra stopping distance. I equate that to the fairly heavier and larger wheel and tire combo. Power is not to me anyway, changed. I am basically very happy with the mods and especially the price to benefit ratio. When these shocks wear out, I will probably do un upgrade. But for me, there would be no benefit to spend the cash for a King or Elka or whatever setup. The stock shocks work very well. I do have a diff drop and carrier bearing drop and ECGS needle bearing to bushing parts all here for if I need them at some point. I have no vibes as of yet. So I am not putting them in until I feel I need them. All of it is fairly inexpensive stuff. So no biggie if I don't use them. The thing I am closest to wanting to change is to raise the rear height up. Measuring wise, it is basically level. But to me and my friends, it seems a little nose high. Many people like that look. I prefer the rear a nip high. I may try putting the stock overload spring in (instructions noted to remove it). That would give a little lift. I know some people have done that. I just like the ride so much now that i am hesitant to change anything.
  19. Apr 30, 2021 at 5:53 PM
    #8699
    cbner
    cbner Well-Known Member
    2018 Tacoma trd sport
    New tires on.
  20. Apr 30, 2021 at 8:57 PM
    #8700
    Bob1971
    Tim
    KY
    White 2020 Trd OR
    Thanks for the honest review. Yeah if it ain’t broke don’t fix it goes a long ways. I read the negative comments about that type of lift and think I should avoid it but at the same time I want the ride height and the looks. I need to check with my mechanic and see about the bearing to bushing swap. If I install a lift I may go ahead and do that at the same time.
    Considered the toyota lift but the best quote I got around here was $2k installed. Seems a bit high for shocks and grill. But now with the stop sale order it may be off the table anyway.
