3rd Generation Brake Bleeding for Dummies (Me)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashdb, Apr 3, 2019.
  1. Apr 3, 2019 at 1:23 PM
    crashdb
    crashdb [OP] I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    I've used it. It's amazing.
    BillsSR5[QUOTED] likes this.
  2. Apr 3, 2019 at 1:23 PM
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    Try bleeding an 80 series land cruiser after air gets in the system. With those you need a special tool which is now extinct to run the abs pump. A tactrix cable (not bootleg) and a copy of techstream are indispensable to have with these tacos. That is probabaly what the dealer will use to actuate the abs.
    Having a pressure pot such as a motive brake bleeder supplying brake fluid under pressure to the master also helps. I had to buy one. It is the poor mans version of the BG machine mentioned. If you pair it with the mityvac vacuum bleeder, it can get you out of some binds lol.
    BillsSR5 likes this.
  3. Apr 3, 2019 at 1:24 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    They said they hooked mine up to a machine, I don't think they manually bleed them at the dealer.
    My pedal is pretty damn firm.
  4. Apr 3, 2019 at 1:25 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I've got a pressure and vacuum bleeder. Didn't think to try them both at the same time.
    shakerhood likes this.
  5. Apr 3, 2019 at 1:27 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    whats your opinion on using Speed bleeders on the brake cylinders, I was thinking of trying to use them cause they don't allow any air to get sucked back into the system, really don't want to invest in a MOTIV and I have tried the MITYVAC suction gun didn't help my soft pedal
  6. Apr 3, 2019 at 1:32 PM
    Burro09
    Miami, FL
    They are handy and make conventional bleeding a 1 man job, but they dont really help with the quality of the bleed. If you cant bleed it with the normal bleeder, the speed bleeder wont really help much.
    When you bleed brakes the conventional way you kind of need a disciplined helper that wont let go of the pedal till you have close the bleeder. Also its good practice not to let the pedal go to the floor when opening the bleeder, so as long as the helper doesnt let go of the pedal before you have closed the bleeder, no air should get in.
    Also bleed with engine on so the booster helps you with the pedal.
  7. Apr 3, 2019 at 1:37 PM
    BillsSR5
    bill
    2014 SR5
    good point my helper sucked, thus my idea of using the speed bleeders. my idea is use speed bleeders let my dumb helper(wife) just pump the pedal and me under the truck observing whats coming out and opening/closing the bleeders. I don't trust my helper:D
    EatSleepTacos likes this.
  8. Apr 3, 2019 at 1:40 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I ordered speed bleeders the other week. They show up, and they were sold individually, not a pair. So I have one bleeder for the front, one for the rear and the bag to catch the fluid. I paid $41 shipped but would sell it to you for $30 shipped if you're planning on getting them anyways. All in unopened packaging. I don't feel like forking out another $30+shipping for the other 2 bleeders.
  9. Apr 3, 2019 at 1:40 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Seriously consider a motive bleeder. They're great if you don't have an air compressor. If you do decide to take the plunge get the one with the quick release chuck on the end. Then just get adapters as needed.
  10. Apr 3, 2019 at 1:40 PM
    UKJON
    UKJON Well-Known Member
    Sorry if I overlooked this but I am curious as to why you bled your brakes to begin with? Was it time for a flush or did you have a component failure?
  11. Apr 3, 2019 at 1:42 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Well. First it was braided lines. Then I did a rear disc conversion. And this time around it was for extended rear lines for the lift I said I wasn't going to do.
    upTOPOverland_Drew likes this.
  12. Apr 3, 2019 at 1:43 PM
    BillsSR5
    bill
    2014 SR5
    You should have gotten the RUSSELL speed bleeders from AMAZON all 4 would cost u about $25 non stainless steel, that's what im getting
  13. Apr 3, 2019 at 1:44 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ah, I wanted to go with the name brand for it. Best of luck with your bleeders.
  14. Apr 3, 2019 at 1:45 PM
    UKJON
    Makes sense now, duh.....:anonymous:
  15. Apr 3, 2019 at 1:46 PM
    #35
    BillsSR5
    bill
    2014 SR5
    I think with the MOTIV is that it doesn't come with a specific cap/cover that fits Toyotas master cylinder, its a Universal cover that from what I read doesn't work as good. I would research that a little before dropping the money.
  16. Apr 3, 2019 at 1:46 PM
    #36
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    My wife sure doesn't think it makes sense!
  17. Apr 3, 2019 at 1:48 PM
    #37
    BillsSR5
    bill
    2014 SR5
    the RUSSELLS get very good reviews on AMAZON its worth a try for only $25 to me, If I don't like them ill send them back
  18. Apr 3, 2019 at 1:48 PM
    #38
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    That's why you get the one with the quick release. You can order the specific Toyota adapter in aluminum.
    Burro09 likes this.
  19. Apr 3, 2019 at 1:50 PM
    #39
    BillsSR5
    bill
    2014 SR5
    that's right, extra:spending:tho, its worth it especially if u plan on using it on other vehicles too, investment
  20. Apr 3, 2019 at 1:50 PM
    #40
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    I was planning on doing my extended brake lines but now it sounds like it wont be as easy....
