3rd Generation Coolant bypass leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco motion, Mar 30, 2023.
  1. Apr 12, 2023 at 4:34 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    The 2GR-FKS is the first of the long running GR series engine to have a plastic bypass. All other versions of the engine utilize a proper aluminum piece.
    VB25, shakerhood and jmneill like this.
  2. Apr 12, 2023 at 5:28 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    They have a new Tacoma coming out, so chances are they won't create a permanent fix. Add this to list of issues they have ignored since 2016.
    Lt. Dangle likes this.
  3. Apr 12, 2023 at 5:37 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    It's rather obvious then toyota hasn't had the number of problems with this if they have done nothing to correct it. I thought they came out with an updated part number after 2018 for this pipe.
    Canadian Caber and Junkhead like this.
  4. Apr 12, 2023 at 8:59 AM
    Taco motion
    Taco motion [OP] Active Member
    2017 Tacoma SR5
    You never know until you try, They did a recall on a simple rear differiental leak, Theres alot of power in numbers the more complaints the better, They also give you a follow up number to keep track on.
  5. Apr 12, 2023 at 9:20 AM
    fourfourone
    I never got a recall notice for my 2018 for a diff leak.
  6. Apr 13, 2023 at 4:08 AM
    Taco motion
    2017 Tacoma SR5
    I have a 2017, They may have corrected the issue by 2018, You can also look up recalls on the NHSTA website
  7. Apr 13, 2023 at 9:19 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Not really simple.
    Differential leak is a safety issue as it can lock up if fluid leaks out.
    Big difference.
    shakerhood likes this.
  8. Apr 14, 2023 at 3:22 AM
    Library unicorn
    Library unicorn New Member
    Anyone make an aluminum replacement yet?
  9. Apr 14, 2023 at 3:56 AM
    Taco motion
    2017 Tacoma SR5
    Is it a big differance? Given the right cercumstances an engine can sieze up if coolant is lost?
  10. Apr 14, 2023 at 4:03 AM
    Taco motion
    2017 Tacoma SR5
    I have not checked into a aluminum replacement, Like Tacoman said its a piss poor design,
  11. Apr 14, 2023 at 8:01 AM
    fourfourone
    Yea but your dash will light up like an xmass tree before it gets to the seize point. Diff could lock up without any sort of warning.
  12. Apr 14, 2023 at 8:15 AM
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
  13. Apr 14, 2023 at 3:45 PM
    InThePlains
    InThePlains Well-Known Member
    Sent mine to the dealer yesterday.
    Here is their quote:
    Parts(coolant bypass joint, gaskets, coolant) $175.26
    Shop supplies: $32.27
    Labor: $2160 (13.5hr @$160/hr.)
    Total: $2367.53
    Not covered by the 5yr/60k warranty.
  14. Apr 15, 2023 at 3:54 AM
    Taco motion
    2017 Tacoma SR5
    True, But because of the number of owners complaining to Toyota and NHSTA about rust they also did a recall on Frame corrosion from date of first use with no mileage limitations for 2011 thru 2017.
    I would think the coolant leak and bad design of using plastic would be a more important issue than frame corrosion.
  15. Apr 15, 2023 at 4:01 AM
    #35
    Taco motion
    2017 Tacoma SR5
    Sorry to see that! Its all labor and its too bad because i think most of us would have replaced it ourselves but the location of it is what stopped me so i had to shell out the money too.
  16. Apr 15, 2023 at 4:11 AM
    #36
    Taco motion
    2017 Tacoma SR5
  17. Apr 15, 2023 at 4:22 AM
    #37
    VTi EG6
    VTi EG6 Well-Known Member
    TX
    2017 Taco TRD Sport
    Canadian Caber likes this.
  18. Apr 15, 2023 at 10:25 AM
    #38
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    I thought people were taking the plenum and intake manifold off to get to this pipe from the top? Is it easier to just drop the trans?
  19. Apr 15, 2023 at 1:12 PM
    #39
    InThePlains
    I have never spent that kind of money on car repairs, specially on labor.
    Finally I got a legit cause to justify a Quick Jack 7000TLX portable lift. Originally I was eying for MaxJax since my garage ceiling height is 11'3", but their prices have jumped the shark.
    petethemeat likes this.
  20. Apr 15, 2023 at 1:33 PM
    #40
    JamesV1
    JamesV1 Well-Known Member
    2017 TRD Off road
    Mines getting replaced Tuesday under warranty!
    Dfpftw and thomasburk like this.
