3rd Generation Coolant bypass leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco motion, Mar 30, 2023.
  1. Aug 13, 2023 at 3:24 PM
    #81
    InThePlains
    InThePlains Well-Known Member
    Started at 41k back in April, gradually got worse. It has been sitting for a while between my work travel and summer vacation days.
    I just spent an hour trying to put the new bypass back on, the two center bolts are very tough to get back in and started. Quite bit of coolant spilled out when the old bypass was removed, everything is wet and slippery.
    I dropped the bolt few times, luckily I put a cover over the clutch, otherwise I would have to take the clutch out to find it.
    danny15l, JmsWms and Junkhead like this.
  2. Aug 13, 2023 at 4:10 PM
    #82
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Oh man, what a pain in the neck.
  3. Aug 15, 2023 at 6:57 PM
    #83
    InThePlains
    Put everything back together today.
    Couldn't find the coolant bleeder, had to do it the slow way, still not sure if all the air is out of the system.
    Again, it sucks.
    Junkhead and JmsWms like this.
  4. Aug 15, 2023 at 7:21 PM
    #84
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Are y'all replacing with the same part? My coolant was low at 6 years 80k miles but I just topped it up and carried on. I guess I'll have to look up in there and see if I'm leaking at this bypass.
  5. Aug 15, 2023 at 7:34 PM
    #85
    InThePlains
    It takes all about 5 seconds to check it, lay down on the passenger side, look up pass the catalytic converter.
    Another even easier way to tell is if you have pink coolant residue on your bell housing, chances are, it's the bypass.
    Junkhead likes this.
  6. Aug 15, 2023 at 7:58 PM
    #86
    Doggman
    Alabama
    2017 TRD OR MT
    Looks like I'm good? Hard to get a decent pic with the angle but I didn't see anything pink on or around the black plastic thing in the back or on the bell housing.
    poopshute and rtzx9r like this.
  7. Aug 15, 2023 at 8:06 PM
    #87
    InThePlains
    It's good.
  8. Aug 16, 2023 at 8:43 AM
    #88
    coolrunning39
    coolrunning39 Well-Known Member
    Central Park/North Aurora
    2017 Toyota Tacoma
    It’s very good
  9. Aug 17, 2023 at 6:45 PM
    #89
    InThePlains
    I'm a Level II NDT examiner certified to run Dye Penetrant test and interpret indications on pressurized vessels.
    I ran an quick one on the failed coolant by-pass joint over lunch break today. It shows where exactly it cracked which can not be seen easily even with magnifying glasses.
    Note: of all the pictures I've seen on the internet forums, the cracks are only appearing at the Right/Passenger side flange.
  10. Aug 17, 2023 at 6:54 PM
    #90
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    send a report to Toyota along with an invoice and sign it from all of us
  11. Aug 17, 2023 at 8:48 PM
    #91
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    Sounds like a beach to do.. i was losing a quart every 4K miles and I still didn’t see anything on top of the transmission or behind the engine. Must’ve been drying fast enough as it’s leaking where it forms a crust rather than dripping. Truck only had 11k when I had the work done. It was leaking from factory I’m sure if. Install error most likely.
  12. Aug 18, 2023 at 5:57 AM
    #92
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Thats cool stuff! That is the original plastic pipe right, your dying process just makes it look like aluminum?
  13. Aug 18, 2023 at 2:50 PM
    #93
    InThePlains
    It is the original part I removed from my truck.
    The Dye Pen process uses a fine white powder developer which comes in aerosol can.
  14. Aug 18, 2023 at 3:27 PM
    #94
    John3976
    John3976 Well-Known Member
    Bill
    2023 Tacoma SR 2.7 4x4
    The difference is with a coolant leak you have a temp gauge on your dash and you will likely see steam once the engine has overheated, a rear end would just seize up without any prior warning. The two are nothing alike, I know you want a recall so you can try and get your money back but is it not going to happen.
  15. Aug 18, 2023 at 3:34 PM
    #95
    John3976
    Bill
    A frame buckling driving down the road is another no warning issue, a coolant leak is not a safety item. Toyota could put out a TSB and handle it on their own but it seems they are not going to do that. NHTSA is not going to step in and issue a recall for this no matter how much you want them to.
  16. Aug 18, 2023 at 10:14 PM
    #96
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    @InThePlains thank you for sharing your experience. I need to do mine as well… 2016 with 90k. Does the new crossover pipe come with the o rings or do you need those or any other seals separate?
    thanks!
  17. Aug 18, 2023 at 10:49 PM
    #97
    InThePlains
    Yes, gaskets on both ends, and temp sensor.
    I didn't pay attention to the center pipe, not sure if there is an o-ring on it. If there is, with 90k miles, I'd replace it.
    On my old 2004 Sequoia with 4.7L V8, had the coolant leaking from the o-ring into the valley of the engine.
    rtzx9r[QUOTED] likes this.
  18. Aug 19, 2023 at 8:53 AM
    #98
    rtzx9r
    Bueller
    2016 TRD Sport
    Awesome, thanks!
  19. Aug 19, 2023 at 10:53 AM
    #99
    InThePlains
    Here is the O-ring part number:
    Junkhead, rtzx9r and Canadian Caber like this.
  20. Aug 20, 2023 at 7:08 PM
    #100
    rtzx9r
    Bueller
    2016 TRD Sport
    Snagged a few pics… looks like cotton candy. F8F9E915-4CE8-44B1-9854-133F7F70F7BA.jpg 145C3651-4650-4068-AB96-9234B86631AE.jpg
    Canadian Caber and thomasburk like this.
