3rd Generation Tacomas will eventually smell like old socks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by denver osborne, Nov 21, 2020.
  1. Nov 21, 2020 at 10:49 AM
    denver osborne
    denver osborne [OP] Octoyota
    Deej
    California coast
    toyotatruckonly
    I am hoping someone can please help me, i have a 2016 early model Tacoma and this problem is getting worse and worse every year. Actually, i dont think there is a solution to this problem, i believe Toyota made a major design error in this truck. Basically the truck smells like an old sock when the fall hits and it starts to rain here. Perhaps i have a leak in the roof of my truck, but it cant yet be found.
    In the fall when the temp is a little cooler and there are rains here in CA this problem starts and does not start to clear up till spring temperatures rise enough to keep the dew point for water condensation much higher.
    I have looked at many cars and truck in my neighborhood at night and my tacoma and a few old trucks are the only ones that have this problem. the problem is the wind shield on my truck collects condensed water not only on the outside (all the cars collect dew on the outside), but my tacoma collects major amounts of water on the inside of the windshield and the outside of the windshield. This water inside the cab is causing mold and smell, and i have tried removing the water at 8 pm and again at 11 pm but by morning there is more.
    A friend told me that his Tundra when it shuts off opens the outside air vent. I believe the tacoma must be doing the same thing. Then the outside air vents in and eventually collects on the coldest surfaces (aka the windows) where the dew point occurs. I did see a tacoma in the neighborhood that was a 2020 or perhaps 2019 and it did not have internal window condensation.
    Has anyone else with older 2016's found a solution to keeping their truck from smelling like old socks. Please dont tell me to change the cabin air filter, i tried that first and on more than one occasion, it has nothing to do with the cause of the problem. Sure the carbon prefilter ones can slowly slightly help the mold smell but changing this filter is not the source of my problem.
    hoping someone else out there has solved this issue, i cant keep the truck if it is going to have this issue. thanks so very much for any input you guys have,
  2. Nov 21, 2020 at 10:51 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  3. Nov 21, 2020 at 11:10 AM
    MyDogsTruck
    MyDogsTruck Well-Known Member
    W. Canada
    2020 TRD Sport
    If there is condensation on the inside, there has to be moisture getting in somewhere. Knowing that there have been issues with leakage through the 3rd brake light, have you ruled that out?
    Does the truck have a roof rack? that can be a source of water entry as well. Even if it doesn't have one, lift the roof channel weather stripping and confirm the mounting holes are covered (there should be body-colored tape covering the holes).
  4. Nov 21, 2020 at 11:18 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Most common is the 3rd brake light. If you have a sun roof, clogged drains or leaking from roof rack mounts. Had anything replaced in the trucks lifetime like the windshield?
    Once you get the leak fixed, good carpet shampoo and dry, then ozone generator to eliminate the odor. May need to replace the carpet if the leaks been ongoing.
  5. Nov 21, 2020 at 11:28 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Also check drains, under wiper cowl. If they are clogged, it will leak into cab.
    RedWings44 likes this.
  6. Nov 21, 2020 at 11:33 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    don't use the recirculate button
  7. Nov 21, 2020 at 11:37 AM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    All depends on what the sock was used for
  8. Nov 21, 2020 at 12:04 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Why not?
  9. Nov 21, 2020 at 12:07 PM
    BillsSR5
    bill
    2014 SR5
    clean fresh air will sanitize the duct work and CAF bacteria
  10. Nov 21, 2020 at 12:19 PM
    CrispyTacoLover
    It depends where you live, outside air temps, humidity, etc.
    Nothing like driving around in the city sucking in diesel fumes, pollen, spores, and covid 19. :rolleyes:
    But you do you.
  11. Nov 21, 2020 at 1:15 PM
    BillsSR5
    bill
    2014 SR5
    we scare cause we care
    e6400ultra, Dryfly24, jmneill and 4 others like this.
  12. Nov 21, 2020 at 1:48 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    clear drain holes/hoses for sunroof if equipped, cowl, CHANGE YOUR CABIN AIR FILTER, check the third brake light for leaks, and reseal. Viola, problem addressed, problem solved. Ski
  13. Nov 21, 2020 at 1:50 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Yeah, I hear a bunch of people got COVID from driving with their windows down.
    You realize the irony? We live in a world of polluted air, and you think it’s less polluted because you recirculate the same polluted air around a car instead of pulling in polluted air from the outside continuously?
    If it wasn’t so sad it would be amusing. Make sure you stay inside and lock your doors bro. :rolleyes:
  14. Nov 21, 2020 at 1:57 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Mine does this. I usually run the heat all the time to dry up the moisture and kill off the musty smell.
    cryptolime, Dryfly24 and TacomaUSA like this.
  15. Nov 21, 2020 at 1:59 PM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Try a rental ozone generator. It will help. Kills bacteria, and mold. Not saying it won't come back but it will get rid of the smell.
    Before shut off switch to recirculation on the hvac system. That close the outside air vent in the dash/cowl. Maybe it stays closed maybe it doesn't but try it and see if there is any change. I live in extremely humid, large temp swings Kentucky and this is not happening to me. Maybe you have a leak.
    cryptolime and Mark77 like this.
  16. Nov 21, 2020 at 3:29 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    You have a leak somewhere. Windshield seal etc.
  17. Nov 21, 2020 at 3:50 PM
    CrispyTacoLover
    You realize I threw that in there just for fun, right? I guess we need a font to denote idiocy starts here -> or something. Sheesh. Have a drink or something already.
  18. Nov 21, 2020 at 4:09 PM
    SWOR17
    SWOR17 Well-Known Member
    WA
    Check the AC drain. Passenger side firewall towards the bottom on the engine bay side. After mine started draining again the smell went away.
    cryptolime likes this.
  19. Nov 21, 2020 at 4:26 PM
    BillsSR5
    bill
    2014 SR5
    kgilly, Dryfly24 and davidstacoma like this.
  20. Nov 21, 2020 at 5:53 PM
    El_rojo_grande
    El_rojo_grande Well-Known Member
    Carson
    Savannah GA
    2021 TRD OR MT
    easy fix. Just get a dog. They'll overpower the old sock smell.
    WallyIAm, vnix, kgilly and 16 others like this.
