3rd gens with aftermarket wheels & NO LIFT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sirm, Sep 26, 2018.
  1. Jan 30, 2020 at 11:36 PM
    #501
    j10munoz
    j10munoz Well-Known Member
    Jacob
    2018 Toyota Tacoma White SR5
    Window Tint
    The setup looks sweet!! What kind of running boards do you have??
    Jnieto10 likes this.
  2. Jan 31, 2020 at 4:21 AM
    #502
    iDrew
    iDrew I spend too much on vehicles...
    Andrew
    Edmond, OK
    '16 TRD Off-Road DCSB
    STOCK AF
    N-Fab whatever the hells. It's supposed to have the predator steps, but I guess the PO changed them.
  3. Jan 31, 2020 at 11:23 AM
    #503
    j10munoz
    Jacob
    Window Tint
    Hahah you don’t like them?? I think those and the predator steps are sweet!
  4. Jan 31, 2020 at 11:28 AM
    #504
    USMC - Retired
    USMC - Retired No Better Friend, No Worse Enemy
    Gunns
    Ty Ty, Georgia
    2018 DCSB Quicksand
    Not really aftermarket wheels but not 3rd Gen wheels either. 17 inch 2nd Gen OR wheels that have been professionally powdercoated black. Wrapped in Toyo AT II's
    Van_island and Cazman13 like this.
  5. Jan 31, 2020 at 11:37 AM
    #505
    strongrob
    strongrob Active Member
    Rob
    2018 Beige DCSB TRDOR
    SCS F5s
    F5s with stock tires. Plan on a Dobinsons 3” lift once it’s paid off. But until then there are plenty of cheap tires on Craigslist.
    Crikeymike likes this.
  6. Jan 31, 2020 at 3:46 PM
    #506
    iDrew
    Andrew
    Edmond, OK
    STOCK AF
    I don't dislike them, but I wouldn't buy them either. I'd rather have sliders.
  7. Jan 31, 2020 at 3:54 PM
    #507
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    Replika R213, 17”x8”, +5 OS. 265/70/17 Falkens152E0398-93E3-4721-9DF6-90456417E1EF.jpg
    Dogbird likes this.
  8. Jan 31, 2020 at 3:57 PM
    #508
    treyfive
    treyfive Well-Known Member
    Brandon
    New York
    2017 PEARL BLUE TACOMA TRD OFF ROAD
    spray paint or what? looks clean
  9. Jan 31, 2020 at 4:01 PM
    #509
    pandonsf
    pandonsf Well-Known Member
    Brandon
    Millbrae, CA
    2019 Tacoma TRD Off-Road
  10. Jan 31, 2020 at 4:01 PM
    #510
    treyfive
    Brandon
    New York
    fuck yeah!
    imaiami and Hiker trash[QUOTED] like this.
  11. Jan 31, 2020 at 4:04 PM
    #511
    treyfive
    Brandon
    New York
    you switched out the stock 16''s? impressions going up a size?
  12. Jan 31, 2020 at 4:13 PM
    #512
    treyfive
    Brandon
    New York
    which on this methods?
  13. Jan 31, 2020 at 4:24 PM
    #513
    treyfive
    Brandon
    New York
    do you like the 17'' better than the 16''? Trying to make the decision myself... 2017 off road
  14. Jan 31, 2020 at 4:35 PM
    #514
    treyfive
    Brandon
    New York
    any noticeable difference going from the 16's to 17''? I like these TRD better than the 16'' glossy
  15. Jan 31, 2020 at 5:23 PM
    #515
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Powdercoat, and thank you!
  16. Feb 1, 2020 at 5:43 AM
    #516
    JagoTaco
    JagoTaco Well-Known Member
    2019 OR AC Cavalry Blue
    Wheel offset is different widening the stance, setup is 1” taller than stock yielding 1/2” more ground clearance, and better tires than stock. Slight increase in weight. Same tread width n sidewalk height. Truck feels much more “planted” on road despite being taller. So yeah, noticeable difference but multiple factors going on besides just going from 16” wheels to 17”.
  17. Feb 1, 2020 at 7:27 AM
    #517
    treyfive
    Brandon
    New York
    you the man thanks for the response...I'm trying to educate myself on tires..Just to make sure the 1'' taller is only from the tires right? no lift on your set up?
  18. Feb 1, 2020 at 8:33 AM
    #518
    JagoTaco
    No lift, currently stock OR suspension.
    1" is the larger diameter tire/wheel combo. 1/2 of that increase (in this case .5") is the amount of height increase for entire truck including ground clearance underneath. Gap between outside edge of tire and wheel well/fender is reduced by .5".
    If you want to go from 16" to aftermarket 17", recommend reading up on wheel offset and backspacing. Those 17" 4R wheels are very popular here not only because of the looks but because many feel the offset is ideal for our trucks.
    Happy for now with the wider stance, ride on rough roads, and mpgs with this setup. Eventually a slightly longer travel suspension lift might be nice.
  19. Feb 3, 2020 at 7:55 AM
    #519
    treyfive
    Brandon
    New York
    you're the man..Thank you for the response..I'm going to read about wheel offset and backspacing like you said...I do like the 17' 4R better than the 16' pro (glossy).
    JagoTaco[QUOTED] likes this.
  20. Feb 3, 2020 at 8:13 AM
    #520
    turbomilk
    turbomilk Well-Known Member
    Brian
    2018 Inferno DCSB TRD Off Road
    17 x 8.5 0 offset 265 70 17 wildpeaks no rubbing at all
