3rd Member Issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by La_Mere, Jun 18, 2025.
  1. Jun 18, 2025 at 10:58 PM
    La_Mere
    La_Mere [OP] Member
    Christopher
    Arizona
    2000 Tacoma 3.4L 5-speed 4x4
    My truck is making a noise from the pinion area of the 3rd member on deceleration, so I have been rabbit-holing this for some time. From what I've read, 3rd member issues seem to be a common problem on these trucks... why???
    For those who have experienced this problem: What did you do to fix it?
  2. Jun 19, 2025 at 5:59 AM
    02hilux
    Planet: EARTH
    Like anything else, nothing last forever. If you got 200k+ on a 20+ year old truck, expect to do some PM.
    Order yourself a third member from ECGS, swap it out, and send your old unit in as core. Unless you’re able to do the work or know a shop that isn’t going to charge a kidney, grab yourself a master bearing kit. Most shop around here charges $500+ for labor if you drop off the third and provide the kit. If they’re pulling the third, 1k+ easy.
  3. Jun 19, 2025 at 7:03 AM
    smyles1632
    smyles1632 Well-Known Member
    2003 Tacoma
    Most likely the front diff bearing is worn; usually you can spot a play if you wiggle that end of the driveshaft. If you have a spare ~$800, ECGS is the way to go. It's also an opportunity to upgrade to e-locker if you don't have one.
    If $$ is an issue, you can continue driving, tolerating the noise.
    I wouldn't say 3rd member is a common issue on Toyotas; aside from the usual high mileage wear, most folks break theirs while mudding/off-roading/rock crawling, i.e. pushing way beyond limits. Exploding diffs on some Cadillacs - now that's common.
