3rd problems after Full Suspension lift/Adding ECGS Carrier Bearing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Breaky0self, Jan 30, 2017.
  1. Jan 30, 2017 at 8:52 PM
    Breaky0self
    Breaky0self [OP] Well-Known Member
    Jupiter fl
    2011 Trd Sport metallic grey 2wd
    Blacksheep670 likes this.
  2. Jan 30, 2017 at 10:05 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    I've yet to do any mods myself but I can't tell you how many posts I've read over and over. Lol. As far as I can tell, definitely install the ecgs bearing. You may not notice vibration right away and it will come soon after. You may get instant vibration. If I'm correct the BP51 is a 3" lift? I plan on doing the bearing when I lift this summer because I've read about vibrations on everything from a spacer kit to a full lift with uca's and everything. Just my 2 cents take it how you will! Good luck
  3. Jan 31, 2017 at 12:31 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    ECGS is not the carrier bearing, its the driver CV Inner bearing. Requiring the shaft to be pulled to install.
    Millions of threads on this already. If you lift you will need the bearing. Most people don't think they have the bearing vibration, till they replace it with the ECGS one and then notice how quite the ride is.
    bullaculla, ZachMX and Pportera like this.
  4. Jan 31, 2017 at 12:33 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    It's not a bearing....it's a bushing.
  5. Jan 31, 2017 at 12:35 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    Good point, I probably should be asleep instead of replying to TW posts. :frusty:
    ZachMX likes this.
  6. Jan 31, 2017 at 6:21 AM
    99superduty
    99superduty Well-Known Member
    2016 DCSB OR 4x4 OME LIFT W/886 and DAKARS 265/75/16 Duratracs C4 lo pro bumper
    Do it. Installed mine a few weeks ago....noise and vibes are gone. Rides smooth like before the lift.
    stevotivo12 and bigshane like this.
  7. Jan 31, 2017 at 6:38 AM
    Bossman14
    Bossman14 Well-Known Member
    2016 white Tacoma TRD OffRoad access cab
    Stock
    Installed icon stage 3 and ECGS Bushing and noise is still there.
  8. Jan 31, 2017 at 6:42 AM
    Breaky0self
    Jupiter fl
    This is the first time I've seen someone say this, maybe it was installed incorrectly? What are the symptoms your experiencing?
  9. Jan 31, 2017 at 6:44 AM
    Bossman14
    Stock
    it was installed correct i double checked lol and the same that everyone else is, hmmm/vibration at about 25-30 mph goes away in 4WD
    Breaky0self[OP] likes this.
  10. Jan 31, 2017 at 7:37 AM
    Breaky0self
    Jupiter fl
    Well i went ahead and bought the ECGS Bushing, will throw it in regardless. What other issues (if any) are ppl experiencing after 3in lifts?
  11. Jan 31, 2017 at 8:35 AM
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    Do the ECGS bushing. I did it on my 2nd and 3rd gen- IT WORKS. A little labor intensive because I did it after I installed the lift.
  12. Jan 31, 2017 at 8:57 AM
    Breaky0self
    Jupiter fl
    Im gonna put it in while installing the lift. any other issues w/anything else after the lift?
  13. Jan 31, 2017 at 9:01 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    id strongly recommend doing the bushing with the lift. i didnt and ended up taking it all apart a couple months later to do the bushing when i couldnt stand the humming anymore
    Marcoc and Breaky0self[OP] like this.
  14. Jan 31, 2017 at 10:14 AM
    Marcoc
    Connecticut
    No issues, I like the slightly firmer rideQuality of the 5100's.
  15. Jan 31, 2017 at 10:24 AM
    99superduty
    Is there a similar bushing on the passenger side? Wonder if you need to do that side as well?
  16. Jan 31, 2017 at 10:30 AM
    Breaky0self
    Jupiter fl
    You only need to do the driver side/ replacing the needle bearing w/the bushing!
    TacomaTech likes this.
  17. Jan 31, 2017 at 10:31 AM
    99superduty
    That posted stated he did that and still had the vibe....thats why I was asking. Mine went away with the ECGS bushing.
  18. Jan 31, 2017 at 10:34 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Yes, you could experience rear driveline vibrations. I recommend measuring the angles of trans and pinion flanges along with driveshaft angles as they sit stock, then compare them to after you lift your truck. The before measurement is a good reference to go by.
    sorgon82 likes this.
  19. Jan 31, 2017 at 10:36 AM
    Breaky0self
    Jupiter fl
    my bad!
    Thanks for the info, is this a problem you experienced?
  20. Jan 31, 2017 at 10:38 AM
    magnus 15
    magnus 15 Well-Known Member
    Kevin
    017 TRD offroad
    Lifted my 017 TRD offroad this past Saturday with an OME kit and everything is good, no problems at all. The only thing I did was use the center bearing spacers to lower the driveline.
    Pportera and Breaky0self[OP] like this.
