3rd switch search
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Beardlife80, Jul 21, 2024.
  1. Aug 1, 2024 at 6:59 AM
    Beardlife80
    Beardlife80 [OP] Member
    2023 tacoma offroad
    I hunt and there are times I wish I had just footwell lights. The less visible light to set the better. I have rock lights added to outside of roof rack so I get get dressed in the woods when I arrive under green leds. It's just a small feature I'd like to have.
  2. Aug 1, 2024 at 7:31 AM
    Beardlife80
    2023 tacoma offroad
    I just got back from taking care of some medical stuff and my mind is all washed right now. I need to sit down after a bit and really go through all this bc I definitely do want this footwell light and switch to happen.
  3. Aug 1, 2024 at 7:35 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Couldn't you just run them switchless to your dome light wiring, then you just flip the dome light switch to turn them on with the doors, on all the time, or off all the time. Or are you dead set on keeping them separated?
    NVM I see this was already covered.
  4. Aug 1, 2024 at 11:02 AM
    Beardlife80
    2023 tacoma offroad
    This is the initial switch I bought for this project. I believe this should work. I just need to find out the correct wiring diagram for it to work as I'm hoping. On(auto on with any door) ; Off ; On (manually on by itself, not tied into dome light manual on)
  5. Aug 1, 2024 at 4:08 PM
    caribe makaira
    Caribbean, Puerto Rico
  6. Aug 1, 2024 at 5:04 PM
    Beardlife80
    2023 tacoma offroad
    3 wires only? I'm confused now. Footwell lights are only red and black. If black goes to middle of switch, red goes to the pink 15?
  7. Aug 1, 2024 at 5:23 PM
    caribe makaira
    Yes. Or at 19_1D connector.
  8. Aug 1, 2024 at 5:25 PM
    Beardlife80
    2023 tacoma offroad
    Damn. Ok. Great! Hopefully I can get time to work this in this weekend. Thanks for all the help.
  9. Aug 1, 2024 at 5:39 PM
    caribe makaira
    So only one wire sent to the overhead console. Easy peasy.
  10. Aug 1, 2024 at 6:27 PM
    Beardlife80
    2023 tacoma offroad
    One last thing..... This switch has a blue backlight when in either "on" position. Will that come on with this setup or do I need to add anything or will that screw everything up?
  11. Aug 1, 2024 at 6:32 PM
    caribe makaira
    That will be a problem you should avoid.:facepalm:
    Beardlife80[OP] likes this.
  12. Aug 1, 2024 at 6:35 PM
    caribe makaira
    A 3 way switch with independent switch illumination should be the proper choice. Or one without any illumination.
  13. Aug 1, 2024 at 6:37 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Typically the 3 position switches have indicators for both “on” sides when they are on, and no illumination for the switch itself.
    so when you have it on “door” mode and open the doors, power would run through that switch to enable the footwell lights and as such, the door side of the switch’s “on” position would be illuminated.
  14. Aug 1, 2024 at 6:46 PM
    caribe makaira
    There are many 3 way switches with independent illumination. Finding one you like and that fits is another thing.
