3rd to 1st gen leaf spring conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Owen1stgenTRD, Jun 1, 2018.
  1. Jun 1, 2018 at 4:13 PM
    Owen1stgenTRD
    Owen1stgenTRD [OP] Member
    California
    White 2003 Tacoma TRD SR5 Prerunner
    2.5 Inch Rough Country Lift Kit, custom lettering grill mod, Flowmaster 50 muffler
    My neighbor has a spare set of leaf springs from his 2016 tacoma trd (3rd gen) and I have a 2003 tacoma trd (1st gen), and I was wondering if they would be compatible on my truck. Has anyone done this before?
    NorCal3056 likes this.
  2. Jun 1, 2018 at 4:15 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    No but you could probably use the middle or lower leaf. The pack as a whole will not fit, length are different and center hole position are different.
  3. Jun 1, 2018 at 4:19 PM
    Owen1stgenTRD
    California
    Ok good to know. I have extended shackles that on there from my lift kit, would that solve the fit problem?
  4. Jun 1, 2018 at 4:20 PM
    Speedytech7
    Nope they're a good bit longer (shackles don't let you run longer leafs) and your axle wouldn't be centered in the wheel wells. You could reweld your mounts in new positions to use them but then you just have stock third gen leafs haha.
    Nessal and Bivouac like this.
  5. Jun 1, 2018 at 4:23 PM
    Owen1stgenTRD
    California
    Haha ya, that sounds like for work than its worth. Thanks for the help!
  6. Jun 1, 2018 at 5:28 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    I used 2008 leafs (2nd gen) on my 97 (1st gen) but like stated above you have to use you original main spring and every thing ells works fine. It defiantly improved sag and ride.
    Wulf likes this.
  7. Jun 2, 2018 at 2:15 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    By the time you get done doing all the Fab work may as well just buy New Springs that Fit
    Wulf and Nessal like this.
  8. Jul 17, 2022 at 8:34 PM
    NorCal3056
    NorCal3056 Member
    2017 Silver Tacoma TRD
    91 octane.
    did you try it? Inserting any of the 3gen leafs? Same situation. Have 3gen leaf pack and a broken 2003 Tacoma leaf that needs replacing.
