3rz balance shaft chain removal in car
Discussion in '4 Cylinder' started by Taco47, Dec 4, 2013.
  1. Dec 4, 2013 at 3:11 AM
    Taco47
    Taco47 [OP] Well-Known Member
    Norcal
    2016 2TR 5-Speed
    Spun balance shaft bearing now I need to remove the chain that drives the balancers. I dont want to drop the engine so this will be done in the car. My plan is to remove all motor accessories around the timing cover like ac, ps, alternator, fan and rad assembly to gain access.
    The problem I see is the two oil pickup bolts that I need to remove in order to take the timing cover out. My truck is a 4x4 so it has the front drive components obstructing the oil pan. Ill be dropping the oil pan and hopefully that will give me enough room.
    Any potential obstacles Im not seeing?
  2. Dec 4, 2013 at 6:32 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Hopefully BamaToy will chime in here... He's done this exact thing in his truck.
    I'll be of no help, I have the Racing edition of the 3rz with factory-deleted balance shafts.
    Also referred to as the 2rz :D
  3. Dec 6, 2013 at 12:05 AM
    Taco47
    Norcal
    2016 2TR 5-Speed
    ill be ripping it apart in the morning, hope all goes well.
  4. Dec 6, 2013 at 9:08 AM
    MowTaco
    Kansas
    I take it you opted to remove the engine?
  5. Dec 6, 2013 at 10:12 AM
    Taco47
    Norcal
    2016 2TR 5-Speed
    I think I have to since I don't see a way to re seal the oil pan with the tight clearance with out dropping the front diff. Does the 3rz use a oil pan gasket or straight rtv?
  6. Dec 6, 2013 at 11:22 AM
    MowTaco
    Kansas
    Oh I just realized that pic was your Sig haha. I think it's rtv from the pics I've seen in build threads but not sure
