3RZ block compatibility?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Old_Truck, Oct 25, 2019.
  1. Oct 25, 2019 at 6:36 PM
    Old_Truck
    Old_Truck [OP] Member
    Togg
    Eastern Sierras
    Green '98 Tachoma
    Hitch, Inverter, Cam, Alarm, Tradesman Shell
    On pages like this, it says that the 3RZ engine was in production from 1994-2004.
    So I purchased a used 1995-96 engine to help fix my '98 thinking it would work. But now I can see that the head is different on the older engine, especially in that the camshaft sensor is located in a different spot.
    Does anyone know if I can take a '98 3RZ head and put it on a '95/96 3RZ block?
    I'm guessing I can try, but just wanted to know for sure before proceeding in that direction. Thanks.
  2. Oct 25, 2019 at 7:36 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    The block is the same. Only the head is different. You should be good to go
    Old_Truck[OP] likes this.
  3. Oct 25, 2019 at 8:22 PM
    UnderFire
    UnderFire Well-Known Member
    Yep same block. Swapped heads more than once myself.
