3RZ Burnt Exhaust Valves
Discussion in '1st Gen. Tacomas (1995-2004)' started by cmj, Oct 26, 2013.
  1. Oct 26, 2013 at 12:51 PM
    cmj
    cmj [OP] Well-Known Member
    Tucson
    98 Tacoma 4x4
    I have reason to believe I have at least one burnt valve.
    One of the valves has gone from .04mm to 0.2mm clearance over the last couple of months (originally it was at 0 but I swapped some shims around). The proper clearance is .25-.30mm.
    What I am trying to decide is whether to rip it all apart and replace a couple of valves or replace the entire head. I don't think it is cracked but I have no way to tell until I pull it off.
    Has anyone had luck with replacing a couple burnt valves, without having to rebuild the head?
    If not, can anyone personally recommend a good source for a new head. I don't want one from china.
    Thanks
  2. Oct 26, 2013 at 4:49 PM
    cmj
    Tucson
    98 Tacoma 4x4
    I ordered the correct shims for now. Going to pull the head in December
