3RZ Compression Check
Discussion in '1st Gen. Tacomas (1995-2004)' started by sonoran, May 20, 2013.
  1. May 20, 2013 at 11:40 AM
    sonoran
    sonoran [OP] Big Loop
    Brob
    Flagstaffrica, AZ
    Tacoma 4X4 3RZ
    Tires: BF Goodrich TA KO2 235/85-16 Matching Spare (in rotation) Rear Suspension: King 2.5 shocks Custom Alcan springs OME greaseable shackles Front Suspension: King 2.5 coil overs Total Chaos UCAs New OEM LCAs Total Chaos Steering knuckle gussets Total Chaos Steering rack bushings Rear Diff: ARB locker (Zuk-Built diff) ARB HD Compressor Rear diff breather extended Armor: Custom full-coverage skid plates Stubbs sliders CBI rear bumper CBI Frame plates Engine: 3RZ Custom over leaf spring exhaust LCE Heavy Flywheel, Pro clutch LCE Stage 1 Head LCE Stage 1 Cams LCE Balance Shaft Delete Bed: Flip-PAC Camper Spray-in bed liner Footman’s loops Canyon Cooler KIST bottle opener Recovery: Custom and very complete tool/service kit including angle grinder and impact HiLift (I know how to use it) and/or Solo skid floor jack depending on trip Glock e-tool (shovel) Strap Interior: Fire Extinguisher Saddle Blanket seat cover Alpine sound Exterior: Anza Headlights WeatherTech wind deflectors “One Less Sprinter” bumper sticker
    Did a compression check in my wife's Honda Civic Si with 222,000 mi to try to identify a power problem. With that problem identified and fixed in short order I decided to pull the plugs on my '02 3RZ Tacoma with 150k just to see the numbers.
    Pulled all plugs with the engine cooling down from operating temp. Pulled the EFI fuse so the pump wouldn't run (just like I did with the Honda) and turned over cyl 1 for a few seconds. Psi came up to 162. Cool. Now to cyl 2. Psi much lower, around 150. Hmm. Ok, Cyl 3, even lower around 140. Cyl 4 was even lower than that, around 125. WTF!?
    So, I go back to Cyl 1 and it was even lower that 4 this time: 120.
    What am I doing wrong here?:confused:
  2. May 20, 2013 at 6:32 PM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    It's sometimes nesscary to supliment the battery with a charger in order to keep the voltage up while you test each cylinder. The average starter pulls like 300 amps so it doesn't take long to run down a marginal battery. Unless you have the throttle blade closed in which case you're running out of plenum volume.
  3. May 20, 2013 at 7:18 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    how would you go about supplying additional power?
  4. May 21, 2013 at 6:00 AM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    A large (think roll around)battery charger will have a quick charge setting 30-40 amps or also a 200 amp + engine start. If the battery is just marginal I would leave it on the 30-40 amp setting while changing the probe. If it is really bad then use the engine start.
  5. May 21, 2013 at 6:50 AM
    sonoran
    Brob
    Flagstaffrica, AZ
    Tacoma 4X4 3RZ
    Thanks Fordless, I have plenty of juice under the hood and had solid cranking power (big Optima Red top). Plenum volume, though? Yes, that could be it as I never did crack the throttle.
