3Rz connector help
Discussion in '1st Gen. Tacomas (1995-2004)' started by jonathan2986, Apr 30, 2017.
  1. Apr 30, 2017 at 3:42 PM
    jonathan2986
    jonathan2986 [OP] Active Member
    3rz
    Hello, i had a 2.7 3rz supercharged that blew up last summer and spend the winter preparing my new engine, now that it's done I dropped it in the car and connecting everything. By the time i was done I lifted the car to do some adjusting and stuff and realized there was stiff a connector left, i spend hours trying to figure out where it went and my engine cranks but wont start, I have spark and gaz
    This is the connector, any idea where it goes? and if this may be the reason why it doesn't start?
  2. Apr 30, 2017 at 5:15 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    What year is the truck?
  3. Apr 30, 2017 at 5:16 PM
    jonathan2986
    3rz
  4. Apr 30, 2017 at 5:23 PM
    Ritchie
    Get a pic with other things included. What corner of the engine compartment?
  5. Apr 30, 2017 at 5:33 PM
    jonathan2986
    3rz
    that's the thing, it was dangling under the car, it's in the same part of the harness as the cam, crank and throttle sensors
  6. Apr 30, 2017 at 5:38 PM
    Ritchie
    What side of the engine compartment?
  7. Apr 30, 2017 at 5:40 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Looks a lot like an o2 sensor plug?
  8. Apr 30, 2017 at 5:48 PM
    jonathan2986
    3rz
    I thought so at first but since it's cat delete and the other o2 sensor is already plugged in to another connector
  9. Apr 30, 2017 at 5:49 PM
    jonathan2986
    3rz
    could it be the cat wiring just left for dead ?
    ( the guy i bought it from did all the mods so i have no clue)
  10. Apr 30, 2017 at 5:58 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    Where does the harness connect to the main harness at?
  11. Apr 30, 2017 at 6:04 PM
    jonathan2986
    3rz
    i dont know, probably on the other side of the firewall or it's all under the protection casing of the harness as this is a swap and the harness is custom
  12. May 1, 2017 at 5:36 AM
    Ritchie
    The connector resembles the cruise control plug on my truck, although I don't have CC.
    Not sure but, with the oil residue on the connector, it could attach to a low oil sensor near the oil filter.
  13. May 1, 2017 at 6:26 AM
    jonathan2986
    3rz
    I don't have CC either so it may be a left over plug but i'll check near the oil filter and let you guys know
  14. May 1, 2017 at 9:53 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    You have both o2s accounted for? Im still leaning towards o2 plug
  15. May 1, 2017 at 9:54 AM
    jonathan2986
    3rz
    Just to be sure where are they?
  16. May 1, 2017 at 9:55 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    One on either side of the cat
  17. May 1, 2017 at 9:56 AM
    jonathan2986
    3rz
    I have no cat so that solves the problem
  18. May 1, 2017 at 9:58 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    What are the 4 colors of wires? Looks like two are red/black, white/black?
  19. May 1, 2017 at 11:09 AM
    jonathan2986
    3rz
    Red/black
    White/black
    Orange
    White
  20. May 1, 2017 at 11:45 AM
    dually
    dually Low and slow
    What you have there is the Air Fuel Ratio Sensor Plug (Bank 1 Sensor 1). Like others have posted, that actual plug is meant for an O2 sensor. Should be for your pre-cat sensor.
    • A23.pdf
      File size:
      893 KB
      14
    COMAtized99 likes this.
