3rz detonation sounds
Discussion in '4 Cylinder' started by smmarine, May 28, 2016.
  1. May 28, 2016 at 9:27 AM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Does anyone else get a detonation/diesel sound from their 3rz upon acceleration. I hear it every time a press the gas from a stop, I hear it if I'm in 4H off-road and load the engine. I pulled a Tahoe out of a ditch a few minutes ago and heard it then. I would swear I had a diesel under the hood when I pulled the Tahoe
  2. Jun 1, 2016 at 7:30 AM
    smmarine
    Melbourne FL
  3. Jun 4, 2016 at 2:01 PM
    smmarine
    Melbourne FL
  4. Jun 4, 2016 at 2:32 PM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    I don't have a 3rz taco but if its detonating that loud its not normal. I would be looking for a defective EGR valve or plugged one if that engine has one. Detonation or excessive pinging can be also caused by carbon build up in combustion chamber, too much timing, EGR system not working, bad fuel
  5. Jun 4, 2016 at 9:42 PM
    smmarine
    Melbourne FL
    Should mention this truck has 63k miles on it. Not really enough to plug up anything with carbon
  6. Jun 4, 2016 at 9:46 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    63k miles shows a lot of short trips in the vehicles life. its possible to have excessive carbon build up due to the engine running richer for the warm up period
  7. Jun 4, 2016 at 9:49 PM
    smmarine
    Melbourne FL
    No, it just sat. It was bought from an old guy with 43k on it. He didn't drive much. The lady I got it from her daughter drove it as a DD till she went to college. I've looked in the combustion chamber. I can still read the marks on the top of the pistons
  8. Jun 5, 2016 at 8:30 AM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    Damn you lucked out how much did you pay? I got mine last Friday with 134k on it and that was the lowest one I could find even the Toyota dealers would have them with 118k
  9. Jun 5, 2016 at 10:29 AM
    smmarine
    Melbourne FL
    $6,000
  10. Jun 5, 2016 at 10:30 AM
    smmarine
    Melbourne FL
    It's at initial acceleration. Once I get above 1000rpm it goes away
  11. Jun 18, 2016 at 6:08 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    I have the exact situation with my '02 Tacoma 3rz , just recently started making the same noises as you've described only on takeoff from a dead stop. No noises when at idle or cruising speed? Mine sat & was only run briefly on the weekends to keep things warmed up through last winter. Any updates on what it may be ? Thanks
  12. Jun 18, 2016 at 8:24 AM
    smmarine
    Melbourne FL
    No updates but I find it interesting you have a 2.7 auto as well. How many miles?
  13. Jun 18, 2016 at 8:43 AM
    Keep on Truckin'
    Jarvis
    Indiana
  14. Apr 27, 2020 at 10:41 AM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    Did the OP ever get this figured out?
  15. Apr 28, 2020 at 12:23 PM
    smmarine
    Melbourne FL
    Nope. OP said screw it, pissed away a bunch of money on the truck, slapped a supercharger on it, had to run 91 octane from them on, and never heard the noise again after doing so.
    OP spent way too much money on the truck and then sold it. Now he regrets buying a Ford.
    Don't be like OP.
