3rz distributor swap into 3rz coil pack
Discussion in '1st Gen. Tacomas (1995-2004)' started by YoungToyo, Oct 11, 2014.
  1. Oct 11, 2014 at 2:15 PM
    YoungToyo
    YoungToyo [OP] Active Member
    Kyle
    Vancouver British Columbia
    97 Tacoma 4cyl 4x4 + 01 DC 4x4
    Camburg 4wd LT King 2.5x8 Deaver F67, King 2.5x16, Fox 2.0 Bumps Heated leather audi seats
    Hi TW!
    I just purchased a 1997 3rz distributor engine very low miles. And I want to swap it into my 525,000km 1997.5 tacoma with 2 coil packs. After removing the dist I see I will need to fab a block off plate to seal and mount my coil packs to. I will be running my coil pack harness and ecu so everything should plug right in after I mount the coil packs. But my concern is the crank position sensor and or cam position sensor not being the same on these two different ignition motors to send the signal to my ecu. Anyone have some input into this swap? I really wanted this to be straightforward and not have to swap my harness and ecu to a dist motor.
    Thanks!
  2. Oct 11, 2014 at 5:29 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I don't know about these engines, but some distributor engines use the distributor shaft and gear to also turn the engine oil pump so if there is a slot in the bottom of the distributor shaft then it turns the oil pump so you may not need to use the distributor for the spark plug fire you may still need to leave it in place to drive the oil pump.
  3. Oct 11, 2014 at 6:16 PM
    YoungToyo
    Kyle
    Not sure about that. Pulled the dizzy out "2bolts" and it has one gear on it that goes into camshaft? And that gear turns a magnetic pickup to send spark.
  4. Oct 11, 2014 at 6:18 PM
    YoungToyo
    Kyle
    1997.5 2 coil pack head
  5. Oct 11, 2014 at 6:27 PM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
  6. Oct 11, 2014 at 6:51 PM
    YoungToyo
    Kyle
    Okay good. I figured I fab a block off plate weld studs or tap holes for the coils. And done. But a friend who owns a turbo shop got me nervous when he asked about the crank sensor and cam pos sensor in the distributor motor. I guess I swap it in and try but don't want to be sol without a dist harness and ecu
  7. Nov 27, 2014 at 10:04 AM
    98yotadog
    98yotadog Member
    north carolina
    98 tacoma
    k & n filter, aftermarket sound system
    I'm in a similar situation. I was wondering how things went? Any tips/advice? Thanks
  8. Nov 28, 2014 at 10:49 AM
    YoungToyo
    Kyle
    My motors rattling stopped itself a day before I planned to swap!! I think it was the hydralic chain tensioners.
    So I have the motor in the garage still.. I pulled the dizzy out and it just runs of the cam with a gear. I compared my coil pack harness to the connections on the dizzy motor and all the sensors are the same. Dose not seem to be missing a crank or cam pos. sensor. So I don't see an issue with the swap.
    My father is a hd mech and commercial transport mech, and he says there shouldn't be an issue. He just tells me to boost it before I swap it in :D
    Only modifications are a block off plate. Make it out of aluminum or painted steel, use a high quality rtv, and weld on some studs to mount your coil packs!
    I hope it works out for you. Sometime when my longtravel is done I will swap it in.
  9. Nov 28, 2014 at 7:59 PM
    98yotadog
    98yotadog Member
    north carolina
    98 tacoma
    Thanks for the info. And +1 on the boost! The one thing I have found is on my coil pack motor, there is a sensor between the 2nd and 3rd injectors, directly under the throttle body, that isn't on the dizzy head. I'm pretty sure this is for the cam pos. sensor. There is a blank spot for it...just not drilled and tapped. FML...lol
  10. Nov 28, 2014 at 11:49 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    yes thats the cam sensor, when I got my '97(coil packs) that sensor wasn't plugged in. It threw a code but the truck ran perfectly fine so might get away without it. Worse case scenario if your coil pack head is in good shape you could probably swap it onto the other block, maybe have it gone through just to be safe.
  11. Nov 29, 2014 at 5:37 AM
    98yotadog
    98yotadog Member
    north carolina
    98 tacoma
    Problem with throwing a code is those damn emissions Nazis! LOL. Old motor has over 300k on it soooo... Might just have to do some redneck-reverse engineering...
  12. Nov 29, 2014 at 6:36 PM
    YoungToyo
    Kyle
  13. Nov 30, 2014 at 7:41 AM
    98yotadog
    98yotadog Member
    north carolina
    98 tacoma
    Possibly...not sure. I thought only Ford changed things like this mid year! lol Guess this means either switch the heads, mill the 97 head or just pull and build my current motor and sell the 97...or swap the harness and all. Decisions, decisions...
  14. Nov 30, 2014 at 11:33 AM
    YoungToyo
    Kyle
    If you build it with a turbo could we not run a stand alone ecu? I'm not familiar with the turbo/ecu engine management world.. But then your could program it all..
    Hopefully someone smarter than me can join this thread
  15. Nov 30, 2014 at 3:56 PM
    vern650
    brandon
    hyrum, ut
    i think swapping the coil pack head onto the other block would be the easiest route.
  16. Dec 1, 2014 at 10:13 AM
    YoungToyo
    Kyle
    Or get a dizzy ecu and harness. I have the harness so I'll look for a cheap boneyard ecu.. That would be easiest imo, a lot of work involved with swapping heads
  17. Dec 2, 2014 at 10:16 AM
    YoungToyo
    Kyle
  18. Mar 31, 2015 at 9:36 AM
    scootn2nature
    scootn2nature ttora member since 2001
    orinda
    2000 2.7l sr5
    bentup sliders, tjm t17, badland rear,custom leafsprings, fabtech performance co's,
    probably have to change the head there are three different heads.....switch the whole motor and just buy the appropiate harness and ecu
