3RZ drive belt tension info
Discussion in 'Technical Chat' started by sgtlethargic, Jul 31, 2008.
  1. Jul 31, 2008 at 2:27 PM
    sgtlethargic
    sgtlethargic [OP] Well-Known Member
    Hi,
    I'm looking for drive belt installation info that shows what amount of deflection they should have. I'm not finding the info in the online manuals. It's for a 3RZ engine with A/C and P/S, so there are 3 belts.
    Thanks,
    Kurt
  2. Jul 31, 2008 at 2:50 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Take this for what its worth - I'm not a mechanic.
    They should twist to be perpendicular to its original position.
  3. Jul 31, 2008 at 9:43 PM
    sgtlethargic
    I'm not sure if what you're saying applies to what I'm asking, and what I'm used to. I'm asking for the deflection, which is the distance you can push the belt when pushing halfway between the pulleys.
    Thanks,
    Kurt
  4. Nov 17, 2009 at 7:02 PM
    fukthacubs
    fukthacubs Well-Known Member
    wisconsin
    v6 sr5 4x4 5 speed
    i would really like to know the answer has this been solved
  5. Nov 18, 2009 at 1:23 AM
    Janster
    Jandy
    Lancaster, PA
    Take your finger & thumb and grad the edges of the belt. Twist.....
    The rule of thumb is it shouldn't go past perpendicular to its original location. If it goes past that point, it needs to be tightened.
    Each accessory belt has an adjusting point.
    These are V belts. If they aren't kept tight, they'll slip. As long as you can keep adjusting the tension, you're good. If you've reached the Maxium adjustment - then its time to replace the belt.
    EdZeppeli likes this.
