3rz engine swap and coolant path diagram?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Devonoco, Nov 16, 2014.
  1. Nov 19, 2014 at 3:49 PM
    BamaToy1997
    Bill
    Navarre, FL
    With the knock sensor disconnected you will have a SERIOUS loss of power, as the engine will not advance the timing at ALL. The harness should come right out of the main branch I believe under the injector wiring.
  2. Feb 26, 2015 at 11:04 AM
    scootn2nature
    scootn2nature ttora member since 2001
    orinda
    2000 2.7l sr5
    bentup sliders, tjm t17, badland rear,custom leafsprings, fabtech performance co's,
    new head bolts are a must.......did they pressure test the head for cracks,,,,,,,,,,,, check do a leak down test get some dye and find the problem..........alot of variables
