3rz ext cab with no power
Discussion in '4 Cylinder' started by Stout890, Oct 3, 2011.
  1. Oct 3, 2011 at 9:49 AM
    Stout890
    Stout890 [OP] Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    Anyone else have issues with there 3rz having no balls? My 99 ext cab with 31" BFG a/t's has absolutely no power. I can't even pass a 85 Honda piece of shit from a red light. I get mini vans honking at me entering the freeway. I was driving up some hills the other day and was pinned! Pedal to the metal and my truck was slowly loosing speed, I couldn't accelerate at all. It's horrible, I wanted to tow a sea doo one day but my truck can barely pull it's own weight.
    It has 3 inch suspension lift with a 3 inch body lift so my 31's are small and look dumb compared to the lift. It makes me wonder if the previous owner had 35+ tires on it before and a regear? Oh and my speedo is off +20mph so when I'm doing 70 it shows 90
    Anyone have any experience with this?
  2. Oct 3, 2011 at 10:08 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Are you regeared? And I would loose the body lift, aerodynamics have a big affect on 4 bangers.
  3. Oct 3, 2011 at 10:10 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Ever had your catalytic converter checked?
    Cleaned the injectors?
    Fuel pump not at full psi?
    Just throwing some ideas out there.
  4. Oct 3, 2011 at 10:33 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
    So basically this is not the case for everyone's taco? I had a 3rz 2001 reg cab taco a few years back and I don't remember ever hating it's power. But that one was bone stock and single cab
    I do not know if I am regeard. I hear there is a way to Check it but need to research that unless anyone here can chime in.
    I also intend to remove the body lift as soon as I can. Iv been researching that for months now and I just need some blocks of wood and another jack. And some new body mount bushings.
  5. Oct 3, 2011 at 10:36 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Nope never had it checked but it passes smog. Fuel pump I haven't check either. How would one do that? As far ad the injectors I sea foamed the engine when I bought it and put it in the oil before I changed it and entered it into the vacum line as well. Maybe I should throw a can into a full tank of gas?
  6. Oct 3, 2011 at 12:07 PM
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
    The only time I've lost speed with my foot to the floor, my catalytic converter was blocked internally.
    Also, how's your mileage? Are you firing on all cylinders?
    I run seafoam in my tank.
    Based on your speedometer reading so much higher, my guess is that you have a much lower rear gear. That really doesn't make sense though as once you have a speed, you should be able to at least maintain it. With a lower gear you should be able to maintain it while even pulling a boat or something.
    Sounds as though there may be a few things going on here.
  7. Oct 3, 2011 at 1:16 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Yeah I'm wondering myself if it's a combination of things. I need to deduce things though. I should figure out how to check my gear ratio. Maybe even match my tranny serial numbers with my motor and see if that's been swapped.
    So what were all the symptoms of a blocked cat? How can I go about checking that?
    Im at just under 140k miles and I changed all my plugs and wires when i bought the truck a few months back but I have wondered about timing. Iv heard if your timing is off by a degree it will sound like it's running fine to the untrained ear but have no power.
    Would a obd 2 be able to tell me any info if there is no check engine cell going off?
    I wonder if because my speedometer is off that my ecu thinks I'm doing 100mph when I'm only at 80 that it is feeding fuel and air ratios for that speed? Like not giving it enough because it thinks I'm already going fast enough??
  8. Oct 5, 2011 at 8:44 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    bump same prob minus the speedo
  9. Oct 6, 2011 at 10:33 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Ok so if your having the same issue with out the speedo being off than the ecu getting a bad reading isn't the issue.
    What are your symptoms?
    I would describe driving my truck as "feeling bogged down at all times" it doesn't coast well it's like I'm driving into a head wind all the time, or driving through knee deep mud.
  10. Oct 6, 2011 at 10:38 AM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    first get rid of the body lift and that will help you some. I had a ext cab 3rz before my current 4.0 dbl cab and i've gotta tell you they have no power haha. Same thing with me coming onto highway ramps and climbing hills too, used to lose power all the time haha. There is really nothing you can do about it when its a relatively heavy and high vehicle with only 150 hp and 180 ft/lbs. It was ok stock but once i lifted and put on 32's it was a total slug. If i were you just get rid of the body lift as stated previously since its hurting you and somewhat dangerous, but keep your tires and suspension lift as atleast it'll look good cuz it will never have any balls lol
  11. Oct 6, 2011 at 10:39 AM
    TacomaGus
    Gus
    Morgantown, WV
    also i just noticed you have an auto, atleast mine was a 5 speed so i had the ability to downshift at times
  12. Oct 6, 2011 at 1:20 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Yeah automatic sucks. And I am in the works of getting all the stuff ready to remove the body lift. I'm about to order new stock body mount bushings today
    I really wanna drive another 4cyl tacoma ext cab, because i can not remember my STD cab 4cyl 01 taco feeling so shitty.
  13. Oct 7, 2011 at 6:35 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    can i see pics of the 31's with the 3x3 lift? just wondering how weird that looks. have you check your plugs make sure your not running to lean? also does the actually Check Engine light work? is the bulb burnt because you might be getting codes and just not know it
  14. Oct 7, 2011 at 7:01 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
    ImageUploadedByTapatalk1317995913.843936.jpgImageUploadedByTapatalk1317995939.260929.jpg
    No check engine light is good It comes on for a second or two when I start the truck. I have changed plugs and wires just 4 monthes ago so should be no issues there. How would I check for a lean mixture on these trucks? It's not running hot.
  15. Oct 7, 2011 at 7:31 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Why are we talking about a V6 in the 4 banger section?
  16. Oct 7, 2011 at 8:15 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Who is talking about a v6? It's a 3rz bro lol
  17. Oct 7, 2011 at 9:05 AM
    4Wheelin4Banger
    Randy
    I don't claim to be a Toyota Yoda But I thought the 3's were V6s. And never heard of TRD 4 banger. Must be a 1st gen thing. I've had 20R, 22R still have a 22RE and a 2TR-FE all 4 bangers.
  18. Oct 7, 2011 at 9:06 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    have you checked your oil level by chance? it may be over filled?...
  19. Oct 7, 2011 at 9:15 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    http://www.v6z24.com/mods/howto/images/plugs/plugs19.jpg
    there is no way that 6 inches that doesn't look bad at all are you sure on your lift setup??
  20. Oct 7, 2011 at 1:26 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    You know I'm not sure exactly iv never measured from ground to bumper but my body lift is 3 for sure cuz iv measured the pucks. As far ad my suspension lift I have an AAL in the year but don't know the size plus some shitty Fabtech coilovers up from that claim on there website 3 inches of lift. They have a built in lift spacer on top it looks like that's at least 2.5. Don't know if that is actually lifting at all or if it's all in the preload.
