3RZ-FE timing chain replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tbone80, Aug 10, 2021.
  1. Aug 10, 2021 at 10:11 PM
    Tbone80
    Tbone80 [OP] Member
    Trent
    99 tacoma 2.7 4wd single cab
    Arb bumper
    I blew a head gasket in my 99 2.7 4wd tacoma and while I got it apart I want to change the timing chain since it has 260k. I have the head off and power steering pump off as well. Was hoping someone has done it before and could give some advice on whether i have to drop the pan and take off the ac compresser and water pump or if there are any secrets to it.
  2. Aug 11, 2021 at 10:50 AM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    The water pump can be left alone. AC compressor can be unbolted and laid aside.
    Being able to tell you if it is possible to remove the timing cover is a tough call because this requires attention to detail. In theory I suppose you could remove the timing cover PROVIDED that you maintain the integrity of the seal between the oil pan and the timing cover. Problem is that you would have to pull somewhat straight out. You can work around that and protect the gasket if you are careful and use a thin scraper to separate the timing cover from the oil pan gasket. I think your big question lies with the fact if the chain has enough room to come off the sprocket. Looking at my engine that I have apart and it looks to have the room to remove the chain from the sprocket. Is it possible? yes. Is it difficult? could very well be so be prepared for it if you do it.
    On the positive side if you happen to remove the engine you can do things like a balance shaft delete. I did it on the cheap by removing the balance shafts, removing and rotating the balance shaft seals to stop the oil flow to the former balance shafts.
  3. Aug 11, 2021 at 11:09 AM
    Tbone80
    Tbone80 [OP] Member
    Trent
    Arb bumper
    Thanks. What is the advantage of a balance shaft delete?
    Aldog likes this.
  4. Apr 3, 2022 at 9:11 PM
    Yotamob
    Yotamob New Member
    Stevo
    99' 2.7L 4x4 ext cab
    Centerline rims on 31x10.5xR15 A/T
    Hey did you ever get it done? I'm in the middle of doing it and had a question about the timing marks
  5. Apr 4, 2022 at 4:44 AM
    Tbone80
    Tbone80 [OP] Member
    Trent
    Arb bumper
    I ended up getting a full rebuild done professionally
    Yotamob likes this.
  6. Apr 5, 2022 at 1:45 AM
    Yotamob
    Yotamob New Member
    Stevo
    Ok thanks for the reply. Did you happen to delete balance shafts?
  7. Apr 5, 2022 at 4:13 AM
    Tbone80
    Tbone80 [OP] Member
    Trent
    Arb bumper
    Nope. Got it out and back in as quick as i could
  8. Feb 10, 2025 at 3:20 PM
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    what timing kit did you up going with and how has it lasted? I’m going to be rebuilding my 3rz this week.
