3RZ-FE valve adjustment
Discussion in '4 Cylinder' started by nzbrock, Jan 30, 2017.
  1. Jan 30, 2017 at 11:57 AM
    nzbrock
    nzbrock [OP] Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    So I had my local Toyota dealer check my valve clearance on my 99 3RZ with 174k miles recently. I told them that I wanted the valves checked and adjusted if necessary. I was having them replace the valve cover gasket due to a leak and figured they could do the work while the cover was off.
    I got the truck back and all they did was check the clearance and nothing else (other than replace the gasket). I got the tech to give me a copy of what the measurements were. They didn't even pull the two tight shims so I can't even order the shims I need. I was a little pissed off about the whole situation. They just seemed like they didn't want to do the work.
    My question is, are the exhaust valves tight enough to be a concern? How much is too tight? Don't worry about the lack of extra zero in the picture, the mechanic forgot to write that in.
    Exhaust (spec .0010-.0014):
    .0010 .0085
    .0085 .0010
    .0010 .0010
    .0010 .0010
  2. Jan 30, 2017 at 4:58 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Tight on cylinder 2 but that could also be from not being 100% TDC on that cylinder as well.
    That probably won't cause much difference if anything that cylinder would open the exhaust valves just a tad early.
    Are you experiencing any issues?
  3. Jan 31, 2017 at 5:13 AM
    nzbrock
    Noah
    San Marcos, TX
    The only issue is a rough idle that shakes the truck. The rpm is within spec but it definitely shakes more than normal and has gradually gotten worse over the last month.
  4. Feb 2, 2017 at 7:39 AM
    2.7taco
    Texas
    My 2TR-FE does this while under load such as in traffic sitting at the light and standing on the brakes.
    Mine too has gotten worse. I'm planning 4 new injectors soon because spark knock has gotten bad too. It's way too lean.
  5. Feb 19, 2017 at 8:12 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    The reason why they did what they did is because the 3RZ valves wear loose. I talked to my dealer about having mine checked and he said that Toyota tells them that if they aren't ticking don't touch them. I also have a friend that was a Toyota mechanic for 25 years and he backed up what the dealer told me. I asked the dealer about a valve going tight and he said that it's not impossible but it would be highly unlikely. He also said it costs up around $1000 to actually get in there and do a full check and adjustment. I suspect your vibration at idle is something else. Whether or not those valves are too tight I have no idea. It would be better to ask a few other mechanics.
    EdZeppeli likes this.
  6. Feb 19, 2017 at 10:13 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Exhaust valves 2 and 3 are way out of the range (gap is too much). I'm surprised they didn't feel the need to adjust those. At least it won't cause burnt valves (too small of a gap would do that after a while).
    DGXR likes this.
  7. Feb 20, 2017 at 7:34 AM
    nzbrock
    Noah
    San Marcos, TX
    Those numbers are written wrong on the paper, notice the text that I wrote out above the picture. They are .0085" which are too tight. All of the exhaust valves are on the tight side of the range.
  8. Feb 20, 2017 at 7:35 AM
    nzbrock
    Noah
    San Marcos, TX
    My understanding is that the exhaust valves tighten up over time, not loosen. This makes sense since all of mine are on the tight side or the acceptable range. Except for 2 and 3 which are too tight at .0085".
  9. Feb 20, 2017 at 8:54 AM
    tan4x4
    Rick
    Folsom, CA
    :oops: My bad, I didn't catch your correction. I'm surprised that a pro mechanic would make that type of error. Eventually, I'd get those valves adjusted, at least 2 and 3, or you may have burnt valves in your future ($$$$).
  10. Feb 22, 2017 at 8:07 PM
    TRVLR500
    Wyoming
    I'm just passing on what my dealer who I have found to be very honest and a former Toyota mechanic told me. I have heard of cases on this forum where valves have gotten tighter but they usually don't. One of these days I'm going to take mine in and have them get in there and check everything just to be on the safe side. The $1000 would be worth the peace of mind to me. I'll probably wait until I've got 200,000 on mine.
  11. Feb 22, 2017 at 10:13 PM
    tan4x4
    Rick
    Folsom, CA
    Pretty easy job to measure the valve clearances. If they're good, then no need to pay big bucks for an adjustment.
  12. Feb 23, 2017 at 6:27 AM
    nzbrock
    Noah
    San Marcos, TX
    The dealer here quoted me around $400 to do the job but they would most likely have to have the truck multiple days in order to order the correct shims.
  13. Feb 23, 2017 at 6:29 AM
    nzbrock
    Noah
    San Marcos, TX
    Yea the master tech I was talking too pointed it out immediately, but he wasn't the one doing the job. I will most likely have them put all of the valves back into the middle of the range once I can be without my truck for a few days.
  14. Feb 23, 2017 at 8:38 AM
    tan4x4
    Rick
    Folsom, CA
    Thats a good price, mine quoted around $700. However, that might not include the cost of each shim they have to order (around $10 each). With 16 valves, do the math. Hopefully, only 4 valves, or so, may need adjusting.
  15. Aug 13, 2021 at 9:56 AM
    pawit
    pawit New Member
    Jim
    2002 Tacoma Xcab 4wd
    stock + Leer can-o-peas, Smitty SS nerfs
    To unconfuse future readers (like me), the typed chart of measurements above the pic should prolly read (in inches)...
    Exhaust (spec .010-.014)
    Measured:
    .010 .0085
    .0085 .010
    .010 .010
    .010 .010
    So yup, that would put 2 & 3 tight, and the rest at the low-limit of spec.
    Hopefully these measurements were done with the engine stone-cold, if not would explain all being tight.
  16. Aug 13, 2021 at 10:04 AM
    pawit
    pawit New Member
    Jim
    Past experience with pushrod valve engines had exhaust valves getting tighter I understood was due to valve-stem stretch.
    So if true about these overhead exhaust valves typically loosening...
    I assume would be due to wear of components and no valve-stem stretch?
    Components like: cam lobes, valve stem tips etc.
  17. Aug 18, 2021 at 10:29 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    On valvetrains where the cam lobe acts directly on the valve stem/shim/bucket, the clearance *typically* gets tighter as the valve recedes into the valve seat/cylinder head and there are no intermediate parts to wear. Typically it takes 150-200k miles or more for the clearance to become out of spec due to valve recession, assuming good maintenance and no engine abuse. Some engines have clearance still in spec after 300k miles or more, due to good maintenance and no severe use/abuse.
    On valvetrains where the cam lobe acts on an intermediate part(s) such as lifters and/or rockers (e.g. cam in-block or SOHC), the clearance *typically* gets looser because these intermediate valvetrain parts (between the cam and valve) usually wear at a faster rate than the valves will recede into the valve seat/head. In other words, the wear of the intermediate parts cause the clearance to increase at a faster rate than the valve recession causes the clearance to decrease. I hope this make sense.
    Someone please correct me if this is wrong, but it's been my general understanding for decades. And obviously, hydraulic adjusters render this description pointless.
    Thank you thank you thank you.
  18. Aug 21, 2021 at 9:47 PM
    pawit
    pawit New Member
    Jim
    DGXR that's a great explanation, thanks.
    But as you mentioned "hydraulic adjusters", I read a little so now at least know the gist what they are and how they work.
    But reading other sites re. the 3RZ-FE engine, came across this on Engine-Specs.net :
    "The 3RZ-FE engine has four valves per cylinder: two intakes and two exhaust. ....
    This engine does not use hydraulic lifters, so you need to adjust the valves clearances every 30,000 km (20,000 miles) of mileage.
    20K is way more than my old air-cooled VW's...
    But holy crap, I've never adjusted my 02 Tacoma's valves in 245K.
    Am I ruining my engine, or are these guys whacked?
    Recently at a general auto repair shop (all manufacturers), I asked IF I should have the valves checked/adjusted?
    Reply was they only recommend checking/adjusting IF THEY ARE NOISY. $500 to adjust, so I passed.
    Again, are they whacked?
    Anyone recall what the factory service manual advises for when to check/adjust the 3RZ-FE engine valves?
    This thread seems to be all over the map on this.
    cheers
  19. Aug 21, 2021 at 9:57 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    sometimes a check b4 a mechanic helps
    a compression and/or leak down reveals much
    either could reveal a diff cylinder than represented by valve clearance
    at Ur mileage i pull the plugs & check again b4 i go back
  20. Aug 23, 2021 at 4:23 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    As noted by others in this thread the valves will wear into their perspective valve seats resulting in tighter tolerances.
