3RZ High Mileage Poll
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jakuku Pahwheenis, Jul 6, 2022.
What's your 1st Gen 4cyl 3RZ mileage?
  1. <150,000
    11.6%
  2. 200,000+
    23.3%
  3. 250,000+
    2.3%
  4. 275,000+
    16.3%
  5. 300,000+
    4.7%
  6. 325,000+
    9.3%
  7. 350,000+
    9.3%
  8. 375,000+
    4.7%
  9. 400,000+
    0 vote(s)
    0.0%
  10. 425,000+
    0 vote(s)
    0.0%
  11. 450,000+
    0 vote(s)
    0.0%
  12. 475,000+
    0 vote(s)
    0.0%
  13. 500,000+
    0 vote(s)
    0.0%
  14. Engine rebuilt
    2.3%
  15. Rusty frame replaced/rebuilt
    2.3%
  16. Died of engine failure
    4.7%
  17. Died of rust
    2.3%
  18. Wrecked (ded)
    0 vote(s)
    0.0%
  19. 150,000+
    11.6%
Multiple votes are allowed.
  1. Jul 7, 2022 at 6:54 AM
    Watterdog
    Watterdog Active Member
    Mine was running great when it sprung a catastrophic oil leak, between the timing chain cover and the block, at 327,000.
    Jakuku Pahwheenis[OP] likes this.
  2. Jul 7, 2022 at 7:30 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    I’ve got a very manageable leak (less than 1/2 quart between changes) here. Did you remedy it or call it when it happened?
  3. Jul 7, 2022 at 7:30 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis [OP] i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    :itllbuffout:
    Watterdog[QUOTED] likes this.
  4. Jul 7, 2022 at 7:40 AM
    Watterdog
    I had the engine rebuilt. I've got about 19K miles on the new motor and now the manual trans is starting make noise and the front CV Axles need to be replaced.. I just might call it quits now, but still deciding....
    Problem is that I really don't like any of the new "midsize" pick ups as they are the same size as a "full size" was in 1998 when I got my truck.. but I've got 345,000 miles on it now...everything is bound to go sometime!
  5. Jul 7, 2022 at 7:42 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    I'd say rebuilding to keep it going strong indef would be a better investment than a new truck, if you want to stay in an old one. They don't make em like they used to. New trucks will eventually fail too and need the same or more expensive work. Of course, I'm not speaking on authority, just my opinion.
  6. Jul 7, 2022 at 9:56 AM
    Hayrider
    Hayrider Over the hill & going down fast...
    Hey You…
    Convection Oven AZ
    15 DCSB & X-cab SOLD for more than new‼️ Now 05 & 07
    Reg Cabs, 5 lug, 5 spd, Magnuson & LS Swap, StopTech’s, Yada Yada Yada…
    So you want more HP? Is 600 enough?
    https://www.youtube.com/watch?v=j4aw71rej0k
  7. Jul 7, 2022 at 4:11 PM
    CharlieTaco
    CharlieTaco '95 long travel - Korea to Kentucky
    Charlie
    Lexington, Kentucky
    95 Tacoma Xtra Cab 2.7 L 4X4
    Solo Motorsports LT & UCA double-shear Fox Factory Series 2.5X8" coilovers and hydro bumps Anonymous Fab uniball-converted LBJs Heavy Friction Works gusseted spindles All-Pro cam tab gussets Advanced Fiberglass 3.5" fenders OME Dakar leaf pack and OME bushings OME greaseable Tundra shackles Bilstein 5125 10" stroke in factory location BFG KO2 33X10.50R15 Husky front floor liners ACC carpet - Oak color '01-'04 style side-view mirrors black door handles Hella H4 E-Code headlight housings/Philips X-treme Vision H4 bulbs BH3D Printing double cup holder Siless sound deadening 72 sq ft Noico Red 72 sq ft Custom stereo - removed
    That is insane haha
    I'd like to get somewhere in the 250 to 300 range. But it'll probably be a while before I get around to it.
  8. Jul 7, 2022 at 6:24 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    94,750. Runs like a Swiss watch. Occasionally get some vibrations at stop lights but that’s about it. If I get ambitious one day I will clean the IAC and see if it makes a difference but it runs so darn good now I won’t mess with it.
    Edit: Garage kept Florida truck its whole life so no rust, original frame and no fading of original paint.
  9. Jul 7, 2022 at 9:25 PM
    ekul310
    ekul310 Well-Known Member
    Luke
    Pennsylvania
    2002 Lunar Mist Regular Cab 4x4
    Stock stock stock
    My current 2002 had a very rough life before I got it. Must not have had any kind of regular oil changes as the original engine sounded like a jar full of marbles when i bought it. Still made it to 175k before I pulled that engine and put a junkyard engine in. This engine probably has about the same number of miles (unknown) but runs great! I have always loved the 4 cyl 5 speed combo in little Toyota trucks. Had a 1984 22r, 1987 22re, 1994 22re, and 2003 5vz auto before the current truck.
  10. Jul 8, 2022 at 8:43 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    My dads 98 is running strong at 350k + he drives it all the time to work. I'm afraid the rust will be the death of it. Not much left in the rear and the shock and left spring mounts.
  11. Jul 8, 2022 at 1:38 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Where is yours leaking? There’s a few spots on these engines that are notorious for oil leaks that are a simple O-ring replacement to fix, such as the oil filter to block connection and oil pump cover. Had to do both of those on mine.
    TWJLee likes this.
  12. Jul 8, 2022 at 9:38 PM
    noodles93
    Charleston, SC
    I’m almost 100% certain it’s the timing chain cover. I’ve replaced the filter housing gasket with no change and it seems higher than the cooler. Valve cover gasket is also new and not leaking. Seems to be from that cover, it’s very manageable and doesn’t leave even a drop on the ground just coats the engine over time.
  13. Jul 9, 2022 at 5:02 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    My in laws had a ‘99 pre-runner with a bad leak. Had to top off with a quart once a month. About 160k. They sold it several months ago.
  14. Jul 9, 2022 at 6:43 AM
    vern650
    brandon
    hyrum, ut
    if it’s towards the bottom front of the engine, I wouldn’t rule out oil pump cover. It’s right behind the balancer and mine covered the whole bottom half of the engine in oil. I replaced the front crank seal and balancer 2-3 times thinking it was that before I finally bought a die kit and seen the die glowing at the oil pump seam. Got another buddy with a 3rz that also has the same leak.
