3rz no spark
Discussion in '4 Cylinder' started by 92LandCruiser, Mar 25, 2014.
  1. Mar 25, 2014 at 12:52 AM
    92LandCruiser
    92LandCruiser [OP] Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    97 4runner 3rz manual
    Cranks, no spark at any cyl
    at coil connectors
    no 1 pin shows no voltage with key on or off
    no 2 pin flashes test light while cranking
    no 3 has 5v with key on
    I'm thinking I have a ground issue, will check all grounds tomorrow
    throwing p0100 and p0115 codes, shouldn't prevent spark though
    maf and ect
  2. Mar 25, 2014 at 10:22 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I should be getting battery voltage at the coil with the key on right?
  3. Mar 25, 2014 at 8:23 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Nevermind, downloaded manual...
    Runs and drives and leaks, fuck
  4. Mar 25, 2014 at 8:30 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    lol @ thread.
  5. Mar 25, 2014 at 8:54 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I'm going to BAJA this thing until it dies. 1600$ joy ride yeah?!
  6. Mar 25, 2014 at 9:04 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  7. Apr 23, 2014 at 4:38 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    So. I got everything figured out. Was throwing a P0115 code and have a very hard start when cold. Would stay running and then start fine once warm. Was having to start it on ether when cold. Found a thread where someone had the same issue and the P0115 code. Had no idea it would cause such a problem. Fixed the wiring to the plug and it fires right up, just like that! Anyway hopefully this will help someone somewhere on a google search or something.
