3rz oil filter reverse thread?
Discussion in '4 Cylinder' started by Sloth, Dec 15, 2012.
  1. Dec 15, 2012 at 9:14 AM
    Sloth
    Sloth [OP] Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser
    Stuff
    Yes I searched ....
    Is the 3rz oil filter reverse thread? I've been trying for about an hour to get the fucker off and it won't budge. I think the dealer had he-man put this thing on. Strap wrench nor filter wrench will budge the thing.
    I rented the side of it in, think its alright to fill with oil and drive to a shop to see if they can get it off
  2. Dec 15, 2012 at 3:36 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    canton Ga
    06 reg cab sr5
    General lee horn mod, Bilstein 5100's and maxtrac 4 inch lift spindles. omd spring rebuild w/ s10 springs kenwood h/u and cb, warn trans4mer brush guard level 8 tracker wheels and cooper s/t 33's
    somebody probly put it on with a filter wrench. You might try drilling a hole from one side to the other and putting a long steel bar through it and use that to twist it off.
  3. Dec 16, 2012 at 5:39 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    2010 4 X 2 Regular Cab
    Chrome exhaust tip
    One time this happened to me, I had to use a strip of emery cloth, folded in half, so the strap wrench could get a bite.
  4. Dec 16, 2012 at 6:03 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Normal thread, BUT remember when you're working under the truck, sometimes your perspective can get reversed... helped a few people repair oil pans on motorcycles because they tightened the drain bolt trying to remove it.
    So... laying on your back looking up at the bottom of the filter, you rotate it counter-clockwise. Wrench handle toward the rear of the truck, pull the handle toward the block, not the tire.
  5. Dec 18, 2012 at 9:47 PM
    Tommychu
    Tommychu Member
    Channel locks dude. Or as a last resort pound a screwdriver through the side into the inner web (Don't use a swing press to get it in, just a good whack with the heel of your hand should pierce it. That way if you're too high up you won't wreck the threads on filter boss). But try channel locks first, less mess. And if you don't own a pair you should buy one anyway because they're too handy not to have.
  6. Dec 18, 2012 at 9:51 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    If It is the original filter from the factory Toyota puts those on pretty darn tight.Mine on the first change was a biatch to get off.
  7. Dec 18, 2012 at 10:59 PM
    Tommychu
    Tommychu Member
    It says 3RZ in the title. If he's just pulling the OEM filter now, he's got more problems than a tight filter. Or he's had it parked for 8-16 years.
  8. Dec 19, 2012 at 5:15 AM
    Sloth
    Seth
    07 FJ Cruiser
    Stuff
    Haha, no not the OEM filter. And ya, I was turning it the right (correct) way. Ended up trying a different strap wrench, one of the metal band ones instead of the rubber strap one I was using, and was able to get it off after some considerable effort.
    This was my first oil change since I bought the truck from a Toyota dealer. I suspect it was a combination of not oiling the gasket/ threads and having Arnold Schwarzenegger put it on.
    Thanks for the replies, just wanted to make sure I wasn't tightening it more than it already was.
  9. Dec 19, 2012 at 6:53 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I really like these. The harder you have to turn, the tighter they grip, similar to a strap wrench, but you can use them with a socket and extension and they grip better than straps.
  10. Dec 20, 2012 at 5:20 AM
    Sloth
    Seth
    07 FJ Cruiser
    Stuff
    I actually fried one of those too. Just couldn't get it to grip. Probably user error, or maybe cause I deformed it using the rubber strap wrench.
  11. Dec 21, 2012 at 10:17 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
  12. Dec 21, 2012 at 10:56 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You'd be surprised.
    The factory filters on many vehicles are on there as if it's a critical part that is to never be removed.
    2006 must have been a bad year, as both my 2006 Silverado/Duramax and my 2006 Kawasaki Vulcan, the factory oil filters were on so tight that by the time I got through the progression of hand > cap wrench > strap wrench > oil filter channel-locks > regular channel locks > screwdriver through the case > now the fucking case is destroyed...
    I ended up peeling the cases off completely, removing the element, and placing a punch against one of the holes in the base and hammering it off.
