3RZ Power upgrades?
Discussion in '1st Gen. Tacomas (1995-2004)' started by PATTYMAN176, Aug 15, 2009.
  1. Aug 15, 2009 at 6:55 AM
    PATTYMAN176
    PATTYMAN176 [OP] New Member
    Patrick
    PSL
    03 SR5
    Light bar, K&N filter, Bosch spark plugs
    Howdy guys. I have a 2003 4x4 SR5 with a 3RZ 4 cylinder. I want to eventually make it a mud/offroad truck. I like the 4 cyinder because it is light weight and i think it may give me an advantage to some of those V8 knuckle heads....If it had a little more power. I have a couple ideas i just need some direction.
    -Turbo with bigger fuel pump and injectors?
    -Supercharger?
    -N/A with fuel pump, injectors, headers, chip?
    -Gears
    Or any other suggestions would be greatly appreciated :) thanks
  2. Aug 15, 2009 at 6:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Aug 15, 2009 at 3:13 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    i recommend getting a new exhaust as in full catback and everything with a high flow muffler, i really like my K&N CAI on my 4 cyl would recommend def, and i'm looking into a new header for some increased lower end power. Or if you have $4000 dollars on hand then go with the supercharger haha
  4. Aug 15, 2009 at 4:34 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I threw a flowmaster in her and did the deckplate mod (poor mans CAI). It makes it so i can climb most hills in 4th with 32s!
  5. Aug 15, 2009 at 6:23 PM
    TacomaGus
    Gus
    Morgantown, WV
    yea the deck plate really does seem to provide some good results, close to most CAI. But i love the quality of my K&N intake and it does add throttle response for sure. Did you get a better drop in filter since you put in the deckplate? Cuz that makes an even bigger difference. And i also have a flowmaster i think they really sound good on the 2.7, can't even tell it's a 4 banger haha
  6. Aug 15, 2009 at 6:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually, The deck plate mod gives more gain than any CAI I have dynoed. In fact, the K&N I dynoed LOST 5 h.p.
  7. Aug 15, 2009 at 6:56 PM
    TacomaGus
    Gus
    Morgantown, WV
    well chris i know you are the guru on here but i have no doubt that my K&N CAI added some power, it said more my truck it would add about 7 HP which isn't much but i noticed a def increase in throttle response and i don't have to downshift for hills that i always had to before install. Which one did you dyno? Cuz i think i have the 53 series idk but it's the FIPK kind not the air charger series
  8. Aug 15, 2009 at 7:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The one I dynoed was the FIPK...I cant remember the model number. I know what they "Say" you will gain, but I have never see it match, or come close to the dyno. For example. TRD claims a 20 hp increase for the 1GR-FE intake they sell. I saw a gain of 3 hp. Yes. Only 3. I got my money back. The K&N I tested, showed a loss of 5, got my money back. Airaid claimed 15 hp. I got 0 (or within the margine of error on the dyno), they actually tried to tell me I didnt dyno the truck correctly, and that I had to dyno at part throttle setting. No. Dynos are performed at WOT. They gave my money back.
  9. Aug 15, 2009 at 7:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Another thing to consider, is how the engine may make hp with a new mod. I have some friends that SWORE they gained power, just to find they lost, but for example, in the low range, the drop was not that bad, but it would build a little more slowly than stock, only to ramp up faster than the stock output, and meet the original hp peak of the engine....the "Gain" they felt was the hp building a little faster, even though it was down on power from stock.
  10. Aug 15, 2009 at 7:16 PM
    TacomaGus
    Gus
    Morgantown, WV
    ok i get where your coming from chris, but isn't that the point then, to build the HP quicker and thus create a quicker acceleration and once that HP is built up it is maintained so that's why i would be able to make it up the hill now without downshifting right?
    Or am i completlely missing the point and talking out of my ass? haha
  11. Aug 15, 2009 at 7:18 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    im suprised chris4X4 hasnt told u to go with the tri-y header for ur 2.7. thats what ill be getting as soon as i can get the extra $$ for it! i'll have my afe pro dry s air filter in a few days, i can pm u about it! i did the deck plate mod, & then about 2 weeks later took the intake resonator thingy off as well, & i can tell quiet a bit of difference in my truck!
  12. Aug 15, 2009 at 7:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I understand what your saying, but when I tested the K&N, it never made near the stock power. Butt dyno's are always off, and there is a placebo affect in which you want to belive you have a gain, as you spent money, and have ben told you "would" get more hp. I have fallen into it as well.
  13. Aug 15, 2009 at 7:23 PM
    TacomaGus
    Gus
    Morgantown, WV
    very true with the placebo, and i would prob think i would have gotten ripped off if it wasn't for the hill and downshifting cuz there is no real way to tell if your acceleration or whatever has improved on a flat street especially with the sound of an intake cuz it's louder and cooler so therefore it must be faster haha or atleast that's what my teenage mind would tell me lol. But i'm still impressed with it, and i'm waiting till monday so i can call those guys at North West Off Road bout that header haha
  14. Aug 15, 2009 at 7:29 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    i called them, they said they had a few left in stock, they r a bit pricy, but it would be worth the extra for the gain.
  15. Aug 15, 2009 at 7:33 PM
    TacomaGus
    Gus
    Morgantown, WV
    how much were they???
  16. Aug 15, 2009 at 7:36 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    like $514.95 + shipping, pretty sure thats what he told me, been about 2 weeks ago!
  17. Aug 15, 2009 at 7:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    WOW!!!! They were about $350 when I got mine! I gotta say, though, it DID give the best gain out of the 2 I tested.
  18. Aug 15, 2009 at 7:39 PM
    TacomaGus
    Gus
    Morgantown, WV
    holy shit! i think i may just go with the DT LT then cuz their only like 250 from URD and i'm sure the NWOR would be better but idt they'd be $250 better haha
  19. Aug 15, 2009 at 7:44 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    yeah, steep for it, but ill just keep saving for it, i reckon. thats y i was going to try the pacesetter header for a $170, just to see, but ill stick with the tri-y!
  20. Aug 15, 2009 at 7:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It IS very well built! and a sexy header too. :eek:
