3rz radiator recommendations
Discussion in '1st Gen. Tacomas (1995-2004)' started by Levisbustedtacoma, Oct 13, 2023.
  1. Oct 13, 2023 at 9:41 AM
    Levisbustedtacoma
    Levisbustedtacoma [OP] Well-Known Member
    Levi
    01 4x4 extracab
    Bilstien 5100s eibach coils Dakar leafs Chinese balljoints
    97 3rz. Want factory radiator new. What's yall using?
  2. Oct 13, 2023 at 9:42 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Denso, repeated tons of times
    /thread
  3. Oct 13, 2023 at 2:48 PM
    F.I.LetsGoFishing
    F.I.LetsGoFishing Well-Known Member
    95.5 4wd 3rz mt
    Neglected Original
    I did that a couple times. In fact, it had 4 in first 10 years. Then went with Napa 15 years ago. Was a little deeper than stock but fit well and best of all, has not cracked yet.
  4. Oct 13, 2023 at 2:56 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Interesting; many here will echo the Denso suggestion and have ran with it for years without issue.
    I ran a Denso in my 4Runner and my Tacoma myself.
    Only went Leiland on the Land Cruiser but that's to eliminate the plastic nipple for the throttle bypass which is prone to breaking; all aluminum.
  5. Oct 13, 2023 at 2:57 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I tossed in a Napa radiator 5 years ago and it's still going wonderfully. Pretty much any of the plastic tank aluminum radiators are going to be about the same. The original manufacturer of the first generation Tacoma radiator no longer makes radiator so pick whatever you can get locally that doesn't break the bank. Best to avoid shipping radiators if you can.
    Wyldeman likes this.
  6. Oct 13, 2023 at 3:16 PM
    Levisbustedtacoma
    Levi
    01 4x4 extracab
    See that's a big concern is it getting broken, this one has lasted since 97. I'd like another one of those bc I don't want to start chasing overheating or not getting hot enough. I've seen koyo makes one
  7. Oct 13, 2023 at 3:17 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I did an OSC about 20000 miles ago. All good so far.
    Speedytech7 likes this.
  8. Oct 13, 2023 at 3:18 PM
    Speedytech7
    as long as it isn't damaged when you open the box it should be good. I had a TYC in my little 4cyl supercharged Tacoma and this Napa one in my current turbocharged V6 Tacoma. Never overheated, even pulling long grades. I'd avoid the all aluminum radiators that are available off the shelf for tacomas because they tend to spring leaks due to being rigid mounted. Makes the aluminum crack.
  9. Oct 13, 2023 at 3:32 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    Agree with the above about avoiding shipping and inspect for damage. I would order from a local vendor and have them do a receiving inspection before taking delivery of it. The local auto parts store received three damaged ones before they received one undamaged when I replaced mine. It would have been a headache if I had to return one via UPS.
