3rz rear main seal replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Levisbustedtacoma, Jun 7, 2023.
  1. Jun 7, 2023 at 5:26 PM
    Levisbustedtacoma
    Levisbustedtacoma [OP] Well-Known Member
    Levi
    01 4x4 extracab
    Bilstien 5100s eibach coils Dakar leafs Chinese balljoints
    What's up yall. I'm about to pull this 3rz tranny and slap in a new clutch. My question is about the rear main seal. Who makes it. I just ordered a timken. Anyone had any luck with those or should I even replace it if it's not leaking
  2. Jun 7, 2023 at 5:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Timken tends to be decent quality.
    I guess it depends on the mileage and if you have any other leaks?
    Typically, if you have, or have had, other leaks at other seals, it’s a good idea to replace the hard to get ones while you are in there. But…….if you’ve never had any leaks, and the seal looks good, you might consider leaving it alone.
    It’s a coin toss. My luck sucks.
    It would probably leak either way:frusty:
    And probably not long after I did the job.
    Cucvfan and Bivouac like this.
  3. Jun 7, 2023 at 6:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    Can't help on the brand, but on keeper vehicles I *usually* replace everything I touch going in or out for a repair. Including things normally hidden, like the rear main in this case.
    Of course it can depend on other circumstances as well.
    Like @TnShooter, if I don't do that, too often I pay a short time later.
    TnShooter likes this.
  4. Jun 7, 2023 at 6:15 PM
    TnShooter
    Deogee
    STOCK
    Yeah, my knowledge and expertise says to “replace it”.
    My luck says, “It leaks either way”……..errrrrrrr:annoyed:
  5. Jun 7, 2023 at 6:23 PM
    Levisbustedtacoma
    Levi
    01 4x4 extracab
    I left the old one in a 87 22r and it's still holding up. I guess I'll figure on it when I can see it's condition. Really would like to know who manufactured the original. I'd hate to replace it with a not so good one
  6. Jun 7, 2023 at 6:25 PM
    Levisbustedtacoma
    Levi
    01 4x4 extracab
    Also on the replacement itself. Many guys said they leaked bad AFTER all the work. Maybe they got impatient and installed it incorrectly or they put a timken in lol. Anything special about install?
  7. Jun 8, 2023 at 4:17 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Mine was not leaking no doubt if I changed it then it would leak. I also have the worst luck.
    About 100,000 miles so far so good.:amen::fingerscrossed::fingerscrossed:
    In this case how many also would change the front seal in the transmission as well?
    TnShooter[QUOTED] likes this.
  8. Jun 8, 2023 at 4:23 AM
    Falkor1
    Falkor1 Well-Known Member
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    2,000 Tacoma rear axle with E-Locker.
    Just go with OEM, and replace the pilot bearing while you’re in there.
