3rz rumbling noise.
Discussion in '1st Gen. Tacomas (1995-2004)' started by MrRiverMan, Jun 4, 2015.
  1. Jun 4, 2015 at 4:47 PM
    MrRiverMan
    MrRiverMan [OP] Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    My '96 3rz with 260k+ miles has been making a rumbling noise for a while now. Sounds like it's coming from the motor, but I don't hear well enough to trace exactly where.
    It's a rumbling that sounds sorta like a throaty exhaust or maybe an old carbureted motor burbling. It varies with rpms and gets the most loud under max load - like when the motor maxes out and won't give me any more juice while climbing up a hill or trying to accelerate. It maxes out a lot these days - really low on power.
    I've done a compression test, and the numbers came back pretty low. The middle two cylinders are 130s, and the outside two are 150s.
    I'm pretty sure it's not an exhaust leak - I've replaced all gaskets and tightened all connections, and I have the mini header and not a cast manifold. It's not transmission related - I've put a rebuilt one in and double checked everything - plus the noise is there at idle in neutral.
    Will a bad valve (or valves) make this sort of noise?
    What else could sound like this? A bearing in the motor?
    How do I tell which it is?
    Motor uses virtually no oil. Just drove a 6800 mile road trip from NC to Idaho and back with about 1000 lbs loaded on it, and it only used maybe 1/2 quart through all of that.
    If the bottom end is good, I will throw a new head on and keep driving it. If something is bad in the bottom end, though, I don't want to spend the time and money on a new head.
  2. Jun 6, 2015 at 6:48 PM
    MrRiverMan
    WNC
  3. Jun 7, 2015 at 6:22 AM
    Deere9798
    Deere9798 Well-Known Member
    Charles
    Western NY
    2001 Tacoma 4x4
    Bump for solution.
  4. Jun 7, 2015 at 7:24 AM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    260 k is getting long in tooth even for Toyota have you considered a lower mileage salvage engine?
  5. Jun 7, 2015 at 8:04 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Just a some WAGs, here, but it could be the chain tensioner, if that is still original ...
    or maybe the distributer bearing (do a 'stethoscope' test).
  6. Jun 7, 2015 at 11:49 AM
    MrRiverMan
    WNC
    Yeah, I've considered it. But if my bottom end is still good, I would much rather spend the same for a brand new head than roll the dice on a used motor. Every used motor is a crapshoot unless you know the person who owned the donor truck.
